Oct 28, 2010, 08:04 AM
SILURIA / UK
Shikra's Avatar
RMILEC was $10 - (now a bit more!) OSD review
Purchased from www.cnchelicopter.com (xmseller of ebay)
$8.99 plus shipping
Excellent service for this US based company. Good communications and fast shipping/delivery to EU. Highly recommended
Detail
Weight: 4 grammes
Dimensions: 35mm * 17mm
Connections: Voltage 1(also supply), Voltage 2, video and ground
Voltage Range: Unspecified, but tested with 2 and 3s. 2s is reported to be an issue when the battery gets too low
Will probably support 4s, but not able to verify
Durability: board protected by heatshrink.
Power type: this unit uses a 78L05 linear regulator onboard.
Build quality: fairly good. Joints appear well done although flux residue not cleaned off from some components.
Status indicator: LED flashing red for no video detected. Continuous when synched and working
GPS support: NO
Display
Shows supply voltage(s) and elapsed time since power up
If connected, also shows a second voltage
At power up, Manufacturer logo displayed briefly
First impressions
Wow - this is small and light. And a very good price. And such a perfect solution for small / weight critical aircraft. Maybe too good to be true... ?? Only one way to find out....
Connecting up
The OSD arrived with different connectors to some of the pictures out on the web - 2 pin servo type rather than the larger and heavier screw terminals
Connecting up
Hooking up the OSD is very simple. Three wires only for a single battery FPV setup. Four wires for a dual battery.
Connections are clearly printed on the rear of the board
Unusually there is no vid in and vid out. Connects directly to the vid signal and provides overlay
Testing
No interference noted against UHF rx or GPS
No impact on video quality
Powering off / on did not impact video
Voltage accuracy of 98% compared to a calibrated meter. Happy with that. Good enough for FPV
Minimal current draw. Hardly noticeable
Configuration
Very simple and straightforward.
A number of pre-set layouts are available and easily accessed via the single configuration button.
Pressing and holding the button for several seconds puts you into layout selection mode.
Subsequent presses toggles the various layouts.
Once the desired layout is found this will be automatically selected after a short period of no further key presses. This is retained after a power cycle.
Improvements Needed
This is a very basic OSD and improvements can always be made such as on/off control from rx, but for the price it's very good value and should be judged against that.
The only real criticism is the characters cannot be viewed against a bright background. The dark bands intended to address this do not work well and take up a large part of the screen. Dark outlining of characters as in some other OSD's would address this considerably.
It would be nice to have the option to disable the timer if needed.
A manual isn't really needed, but would be advantageous for some. Details of voltage ranges supported should really be provided.
In use I had absolutely no problems with this once the characters were positioned lower in the display.
Test flown with a TriCopter and this provided a massive improvement in knowing when the battery was about to give out. Not wanting the weight or expense of a full blown GPS OSD makes this a perfect choice on a Tri.
Having that voltage in the display means you know exactly when you are at your limits - fly longer with security of knowing when it is time to land.
At this price I'll never fly without an OSD again.
Summary
Simple. Easy to connect and setup.
This is not a replacement for GPS OSD
Ideal OSD for those on a real tight budget - or as interim until can get a GPS capable OSD.
No excuse to fly without an OSD ever again...
Sample video showing OSD in use....
This was taken just before sunset so really demonstrates how the characters show against bright areas in the sky
Sample video showing OSD modes....
(In hindsight I should have recorded this against a better background, but if nothing else it also demonstrates choosing mode is important)
Some pictures...
Oct 28, 2010, 08:17 AM
Nice review.
This will be perfect for my Slow Stick.
Thanks.
Oct 28, 2010, 08:50 AM
Flying like an Angel.
BlueAngel2000's Avatar
thanks for the great review.
Oct 28, 2010, 08:51 AM
wallaguest1's Avatar
yeahp same problem than simpleOSD, the parallel connection with video signal return that kind of flashing problem with the black background, usually camera got stronger signal and flash it,
an in/out design would not return this.
What the 6 pads in the PCB are for? maybe ICSP ?
Oct 28, 2010, 09:04 AM
Fly fast, Dont crash.
Thepasty's Avatar
Great review
Being new to all this it gave me the confidence to order one.
thanks
Oct 28, 2010, 09:09 AM
Did you get it on video?
Flying-Monkey's Avatar
Originally Posted by scrape
Nice review.
Thanks.
My thoughts exactly!
Oct 28, 2010, 09:32 AM
WHEN IN DOUBT FLOOR IT!!!
G-unit's Avatar
Nice review, this is a good OSD for the price, I'm very happy with it..
Oct 28, 2010, 12:57 PM
Thank's for the nice review.
Patrick
Oct 28, 2010, 02:02 PM
Falling with style
metalfred's Avatar
Great review thanks!
One thing I don't understand, how can the video be overlay ed if there is no vid in / out? How is the cam / vtx connected to this?
Oct 28, 2010, 02:20 PM
G-unit's Avatar
You still hook the Video and ground to this...
Oct 28, 2010, 02:26 PM
Falling with style
metalfred's Avatar
Yes, I understand that.
So I guess you connect both the VTX and the CAM on the video pins?
Oct 28, 2010, 02:37 PM
G-unit's Avatar
Yes just "Y" them in..
Oct 28, 2010, 02:38 PM
Falling with style
metalfred's Avatar
Ok thanks for clearing that up
Oct 28, 2010, 06:45 PM
Thou who know not
Po73's Avatar
Nice review, I ordered 2 and why not? They are perfect any plane that doesn't need an amp meter and GPS guidance.
Oct 28, 2010, 11:50 PM
I wonder what the input impedance of the 2nd voltage input is. Is it suitable for RX RSSI? (I ordered 4 of them BTW, waiting for shipment)
Discussion The long range 2.4gHz module (Rmilec) from BEVRC Talajouy FPV Talk 71 May 05, 2015 07:08 AM
Fly-In Mid-South War Bird Flyin 10/2/10 & 10/3/10 jstanton Fuel Power Events 2 Sep 30, 2010 09:41 PM
