Oct 27, 2010, 01:20 PM
Wheels make the world go-round
T-CAT's Avatar
Question
Normal brushless motor temperature range??
From sifting through the threads here, I have seen many people say roughly 160 degrees F is the maximum safe temperature for brushless motors to run.
Does that sound about right, or is there a standard range that is acceptable?
Oct 27, 2010, 01:30 PM
Frequent Flyer
whitecrest's Avatar
80C or 176F is the point when neodymium magnets will begin to lose their strength. You shouldn't need to run nearly this hot for good power.
Oct 27, 2010, 01:32 PM
T-CAT's Avatar
Excellent, thank you very much. I have some motors that i am going to run on a 5S battery and want to make sure the temperature is within reason.
Oct 27, 2010, 01:47 PM
Dr Kiwi's Avatar
I use 60C/140F as a sensible limit. Glues used to hold magnets (even epoxies, other than JB Weld) soften at around 60C. Think what the oil/grease in your bearings is feeling like at 60C!
Oct 27, 2010, 02:00 PM
T-CAT's Avatar
Ha-ha, very true! That is very useful information. This forum is incredible, as I have learned so much in such a short period of time.
Oct 27, 2010, 09:54 PM
If I can't keep my finger on the hot part of the motor (not necessarily the rotating bell), then I think I have abused the motor. I don't know what temperature that would be, but I have a strong feeling it's very close to Dr Kiwi's 140 Fahrenheit limit.
As an aside, using this simple rule of thumb I have managed to keep over $2,000 worth of motors in tip top shape, and running like the day I bought them....
Oct 28, 2010, 02:25 PM
Fourdan's Avatar
Hi
Temperature is a very difficult problem
Temp is depending of where you put the sensor and also running time.
Inside the motor there is a "temp map" showing "temp gradients"
The simpler way is to measure at the stator flange (or fixing cross)
but if you get 50°C at the flange you don't know exactly at what temp are the magnets or the copper.
So my philosophy or politics is to be "conservative", as I don't make "hard competitions or challenges"
There is a ditch between Formula1 car and a "sunday car with childrens aboard". It happens that F1 motors explode ! Not wishable for your full camping car.
Louis
Oct 29, 2010, 06:37 PM
Space Coast USA
hoppy's Avatar
With outrunners, I like to point the non-contact IR temp meter into a cooling slot to get a better temperature readout.
Oct 29, 2010, 06:39 PM
T-CAT's Avatar
Thanks everyone. This is great insight, and will be very useful the next time I fly using my new motors.
Mar 24, 2015, 06:46 AM
flysohigh's Avatar
I have a mother that is in outrunner motor and it does not have the spinning mass on the outside is it ok to take the temperature on the can itself
Mar 24, 2015, 07:12 AM
I am a nice guy! Really!
Golly, I did not realize this thread is 5 years old until I finished it. I am glad it is short. Flysohigh, I think Jack answered your question in another of your posts.
May 19, 2017, 11:21 PM
The maximum operating temperature of a an EH grade neodymium magnet is 200 degrees - celsius, not fahrenheit. 200 degrees celsius is 392 fahrenheit.
May 26, 2017, 08:45 AM
homo ludens modellisticus
Ron van Sommeren's Avatar
But alas, most manufactors use neodymium magnets of lower grade, don't go over 80degrees celsius.
Prettig weekend Ron
Oct 02, 2017, 08:58 PM
tic
tic
thunderscreech
tic's Avatar
Neu says 100 degreesC for his motors
Oct 02, 2017, 09:04 PM
I'd rather be Flying
davecee's Avatar
Back in the day I bought a MaxCim system. I called the company and spoke to Tom Cimato (sp) about temperature range. He told me not to worry about the temperature, run it within the volt and amp specs and I couldn't hurt it.
Discussion Glow Engine Normal Temperature josefvs Fuel Plane Talk 6 Jun 08, 2006 04:25 AM
Discussion Brushless Motor or a normal Motor? ErzBischoff Electric Motor Design and Construction 1 Apr 10, 2006 04:28 AM
Brushless Motor Maximum Temperature Limits JohnnyCakes Electric Power Systems 3 Jul 10, 2005 06:44 AM
Brushless motor temperature? hingus2000 Micro Helis 4 Feb 03, 2005 09:39 PM
Brushless Motor Temperature? ozoneone Micro Helis 13 May 20, 2004 11:37 AM
