Oct 27, 2010, 08:57 AM
P. Tritle's Avatar
Moving Forward - Then Back
The Firewall was glued in place followed by the middle top former. An alignment stick was taped in place and the IP former added, using the stick to insure the alignment.
Then it was back to the tail where machinists squares are used to align the tail post. The post was held in place with a cloths pin and glued together.
Oct 27, 2010, 08:59 AM
P. Tritle's Avatar
Formers, Formers, and More Formers!!!
The top formers aft of the cabin were added next. Then the rudder mount was glued in place and the centerline stringer added.
Oct 27, 2010, 09:01 AM
P. Tritle's Avatar
Adding the Remaining Bottom Formers
Now that all the top formers are in place, the frame was turned over and the rest of the bottom formers were added....
Oct 27, 2010, 09:04 AM
P. Tritle's Avatar
Starting on the Strings
The top stringers were added beginning with the shaped upper cabin stringers. From there, the rest of the stringers were added, then the aluminum wing joiner tubes were fitted and glued in place.
Oct 27, 2010, 09:07 AM
P. Tritle's Avatar
Adding the Bottom Stringers
The bottom stringers were added next, beginning with the cabin area, then moving forward and back until all the stringers were in place..
Oct 27, 2010, 09:10 AM
P. Tritle's Avatar
Cutting In the Hatch and Mounting the Servos
The equipment access hatch was added by cutting the stringers between the formers and the side stiffeners added. The servo rails were then added and the rudder and elevator servos mounted.
Next up, the landing gear.....
PAT
Oct 27, 2010, 09:40 AM
One cell short of a Pack
steve1814's Avatar
Servos are nicely tucked toward the back- that long nose sure helps out in that regard . I supposed Sparky is going to be doing his usual terrific job on the plastics...Are you going with a formed canopy on this one?
Cheers,
Steve
Oct 29, 2010, 04:09 PM
Cut it twice, still too short
dglo's Avatar
There is something quite elegant in a stick frame fuse. Strong, light, beautiful. Another great job, Pat, but we kinda expected to see some pre-flight photos by now, after all you started this build three days ago!
Doug
Oct 29, 2010, 04:28 PM
steve1814's Avatar
He's probably out flyin' right now
Cheers,
Steve
Oct 29, 2010, 09:16 PM
mistairjoe's Avatar
So many builds, so little time.I could get one to put on a shelf and open the box every so often to look at it.Lots of great color schemes also.Joe
Oct 30, 2010, 08:16 AM
P. Tritle's Avatar
Soldering Up the Landing Gear
The LG components were bent from 1/16 wire, fitted onto the fuselage and soldered together in place. A bass wood stick was clamped to the gear to hold it all in place for soldering.
And while we're at it, the tail wheel strut was shaped up and lashed to the tail post.
Oct 30, 2010, 08:21 AM
P. Tritle's Avatar
Finishing the Fuselage
The last thing up on the fuselage was to get the window frames in. As luck would have it, the frame JUST fits a file folder, so were cut from a folder rather then 1/64 ply. But for those who prefer ply to paper, go for it, it'll work fine to.
Then it was on to the cowl plug. The mold was carved from blue foam and is winging its way to Sparky even as we speak, so you know it's going to be nice. Will also include the spinner in the plastic parts pack.
Oct 30, 2010, 08:32 AM
P. Tritle's Avatar
Building Up the Tail Section
The vertical and horizontal stabs are both airfoiled so they'll be thick enough to be self supporting. The horizontal stab span is over 20", and being un-braced, I didn't think the flat plate style would be the way to go on this one. Once framed and sanded to shape, the rudder and elevator hinges were cut in to finish up the tail planes.
Oct 30, 2010, 08:40 AM
P. Tritle's Avatar
Getting Started on the Wings
The wings on the Porter are EASY! Just a simple Hershey Bar panel with flaps and ailerons the full lenth of the rear spar -- no cut in's or cut out's, just straight lines everywhere you look. After building the Stinson Reliant and a couple of Cessna's, this one is a no-brainer!
And yes, the flaps on this wing are HUGE!. The flap span is just shy of 17" with a 2" chord, so there's no doubt in my mind that the Porter is going to slow down real well.
The full scale Porter is also built with no dihedral. On the model I went with one degree as I've learned over the years that a flat wing on a model literaly kills the roll stability in level flight and the model will "hunt", requiring constant correction to maintain wings level. And the good news is that a flat wing looks droopy, with one degree of dihedral, they look flat.
Next up, the other wing -- then we'll be on the home stretch.
PAT
Oct 30, 2010, 09:22 AM
supercubman's Avatar
17" and 2" with flaps, wow this one will be an awesome floater.
Trey
Wanted ICARE (TopModel) Pilatus Porter JPHen Aircraft - Fuel - Airplanes (FS/W) 3 Sep 12, 2010 12:54 PM
Pilatus Porter crashed, any idea? RookieOne Beginner Training Area (Aircraft-Electric) 6 Dec 18, 2001 04:04 PM
8ft Span Pilatus Turbo Porter EAMRC Scale Kit/Scratch Built 9 Sep 24, 2001 12:54 AM
plan for Pilatus Porter? partoftheproblm Scale Kit/Scratch Built 6 May 19, 2001 05:58 AM
