Since my last post, I performed a 25km distance with excellent video quality
Need help here.
I make my own DIY dipole antenna and biquad mesured for 1280mhz channel All the dimension match, but i got terrible range (~900m). No short on active and ground. Btw, I know the interference between Crossfire (915mhz) and 1.2 video system, that why i use 5.8 relay to place the 1.2 VRX far away from Crossfire TX, but it's not the reason why I got only 900m on FPV |
Since i found some copper tubes here, I'll use with my feed. My question is: copper tube is soldered into reflector, ok.....but cable shield should be soldered into copper or isolated from copper? Once is soldered to copper tube, it will be automatically soldered to reflector too.
I can't make a good one
I've tried two antennas, both are getting SWR of 3:1. I'm making for 1.160Mhz. section length is 6,42cm and element spacing (heigth) is 3,21cm. I'm using 26x26cm reflector. The first antenna has 63,25mm as section length.....then, I measured and found SWR of 1.4:1 at 1.050Mhz (mor or less). Then I tried another antenna with smaller section lenght....now with 62,3mm.....but still no good SWR at 1.160Mhz What could be wrong? For element, I'm using 1.5mm copper wire. |
Also maybe this is only on pic but I`m seeing that your bowtie is not made from one wire piece. If above is true and not my pic misread - replace metal screw with plastic ones, and make bowtie from one wire piee. You can solder it, but any soldering joints have impact on antenna performance (even solder blobs not rounded or to big). Be patient When I was making my 2370Mhz biquad it took me 6 bowtie`s before it was almost spot on. The hardest with this antenna is that you can`t fine tune it. The only way is trial and error. But if you have some analyzer and 3d printer you only need patience |
This 3D printed bowtie frame influence a lot! I figured out with antenna analyzer. It changes the resonant frequency.
With this frame effect could be bigger. So If I was you @jmaurin - Make new element on frame, analyze and note element length, VSWR, S11, R. To low resonant freq - shorten element (for ease of calculation 5mm shorter) and note parameters and difference between elements lenght . With this data you should be able to calculate how much more you need to shorten to achieve your freq. Pay attention how you measure element length, take into consideration wire thickness. |
Tks for the tips!
I've modified and it's pretty good now! Not perfect, but a wey better! |
Thread Tools | |
Similar Threads | |||||
Build Log | How To Build a BiQuad RX antenna | Talajouy | FPV Talk | 21 | Dec 23, 2010 12:52 AM |
Question | DIY Biquad antenna for a 900mHz | Moosthegoose | FPV Talk | 5 | Jan 14, 2010 04:37 AM |
Discussion | Antenna tutorial | JIMOOO | FPV Talk | 1 | Feb 25, 2007 01:04 AM |
Discussion | looking for a DIY tutorial. | TonyBAMF | Beginner Training Area (Aircraft-Electric) | 8 | Jan 10, 2006 05:56 PM |
I need help to DIY flywire antenna for 36 MHZ RX | GoodHeli | Radios | 5 | Aug 24, 2003 08:05 PM |
