Apr 12, 2011, 08:40 AM
Honey Badger
Blue Chip's Avatar
Just to confirm with you... I am going to put a sheet of plexiglass beneath the reflector - and another over the top of the element to protect it.... this will not cause any issues right? Does thickness of the plexi matter?
Apr 12, 2011, 08:58 AM
Engineer for Christ
IBCrazy's Avatar
It will not affect it. It can be an inch thick and you'll never know the difference.
-Alex
Apr 12, 2011, 09:01 AM
Honey Badger
Blue Chip's Avatar
Thank you. Can't wait to scrap the Yagi for this.
Apr 13, 2011, 05:17 AM
rsowder's Avatar
Alex, I am assembling a new antenna tracker made out of aluminum. Will it be a problem to bolt the antenna to the tracker with metal screws or should I use nylon screws?
Randy
Apr 13, 2011, 08:28 AM
Engineer for Christ
IBCrazy's Avatar
Randy
Use anything you want to bolt it down.
Apr 13, 2011, 08:51 AM
Honey Badger
Blue Chip's Avatar
Really? I thought that bolting the metal reflector to a metal pan tilt with metal bolts would somehow screw the performance up...
I guess it's just a reflector?
Apr 17, 2011, 10:43 PM
I should be flying right now!
al1242's Avatar
Alex,
I just flew my Skywalker with the Dragon Link for the first time and went out 2 miles using this BiQuad, the video was totally solid! I had never been that far out as being new to this but I was very impressed with your BiQuad, thanks. We will see in the coming weeks how far I can go with this antenna.
Apr 18, 2011, 06:51 AM
Engineer for Christ
IBCrazy's Avatar
Originally Posted by al1242
Alex,
Not bad, my friend. Go ahead and venture out farther. 2 miles is a walk in the park for a BiQuad. Just be sure to stay in the beam. That's the hard part.
-Alex
Apr 18, 2011, 06:52 AM
Engineer for Christ
IBCrazy's Avatar
Yep, just a reflector. It doesn't even need to be electrically connected like I have mine. I electrically connect mine to balance the antenna.
-Alex
Apr 19, 2011, 08:35 AM
Earth's Mightiest Hero, KC9TBO
Zahnarzt's Avatar
Originally Posted by IBCrazy
Technically, yes. In fact, any dielectric will cause a shift in SWR. That said, use the smallest piece of foam possible. Open cell is better than closed cell. If you look at my other BiQuads I made, I used a small wooden block.
-Alex
What about plastic? Specifically, type 2 or type 5? I have all these small single use syringe plungers that are the perfect size to support the element.
Thanks, Alex.
Apr 19, 2011, 09:06 AM
Engineer for Christ
IBCrazy's Avatar
Those will work fine. Closed loop antennas are fairly good when it comes to dielectrics. Open antennas such as the dipole, Vee, and patch are extremely sensitive.
May 13, 2011, 06:40 PM
CrocEnd's Avatar
Alex Hi
What is affecting the SWR on these BiQuads is it element to reflector distance,
I think I missed it some were.
Thank you
Cheers CrocEnd
May 16, 2011, 01:49 PM
Hi, again a theoretical question, if I would use the biquad also for my radio link, what range can i expect with the unboosted stock setup of about 100mW and the stock dipole antenna that the receiver uses...just an estimation of course..
May 16, 2011, 02:21 PM
Engineer for Christ
IBCrazy's Avatar
I have no idea. Expect about 3 to 4 times your current range with a BiQuad on the radio TX.
-Alex
Engineer for Christ
IBCrazy's Avatar
Originally Posted by CrocEnd
Alex Hi
Thank you
Cheers CrocEnd
Element size and reflector distance both affect SWR.
Build Log How To Build a BiQuad RX antenna Talajouy FPV Talk 21 Dec 23, 2010 12:52 AM
Question DIY Biquad antenna for a 900mHz Moosthegoose FPV Talk 5 Jan 14, 2010 04:37 AM
Discussion Antenna tutorial JIMOOO FPV Talk 1 Feb 25, 2007 01:04 AM
Discussion looking for a DIY tutorial. TonyBAMF Beginner Training Area (Aircraft-Electric) 8 Jan 10, 2006 05:56 PM
I need help to DIY flywire antenna for 36 MHZ RX GoodHeli Radios 5 Aug 24, 2003 08:05 PM
