Jul 28, 2011, 07:20 AM
Compass position
Hi Jingchen
I have been doing a bit of research on where the compass should be positioned in relation to the various electronics and the feeling is that it should be as far away (150mm) from the power cables leading to the ESC's, as this is where most of the magnetic interference comes from.
My hexa uses the 2 x X450 Esc to feed motors 5&6, and the ESC's are located between motor 5&6, and the wires linking the battery to the 2 x ESC's run quite close (60mm) to the compass positioned above the AHRS.
I am thinking of moving the compass to a position located between motors 2&3 on an extended arm so that I will achieve a distance of about 130mm.
What are your and your teams thoughts on this position and will it have an adverse impact on the compass operation.
Rob
Jul 28, 2011, 10:22 AM
You need both the GPS and Compass on 350mm masts sticking out the top of the XA
Just wait til you try to place the OSD module, apparently it has to go in a very dark damp place
Jul 28, 2011, 10:56 AM
XAircraft Centre download
If you open up your config software it will automatically down load the new XAircraft Centre
You will then have to update your FC firmware and the AHRS firmware. Don't forget to change the cable to the respective module.
No GPS firmware yet
Jul 28, 2011, 12:35 PM
No GPS firmware yet
what cable ? where did you read this stuff at ?
Jul 28, 2011, 12:39 PM
Zirt57's Avatar
---Deleted---
Jul 28, 2011, 01:02 PM
hmm, need to play with it a bit seems to parameter stuff missing..
no config files for the 'old' discontinued x450 and x650
no motor start speed option I can find.
Jul 28, 2011, 01:07 PM
Zirt57's Avatar
---Deleted---
Jul 28, 2011, 01:18 PM
Originally Posted by zirt57
Yeah, it blows away your configuration settings in your FC if you aren't using a X450pro or X650v. I'm making an X650-X8 profile and a Hexa profile right now.
- Jeff
cant seem to configure my radio outputs like I could before
Jul 28, 2011, 01:35 PM
Zirt57's Avatar
---Deleted---
Jul 28, 2011, 01:41 PM
Soooo, has anyone figured out how to "export" a profile? I've created one for my X8 and my Hexa complete with pictures but don't know how to export them for posting. Jingchen, any input on how to do this?
Josh, do you mean the way we used to calibrate the RC? If so, they've created a wizard for this. Just pick calibrate then in the RC tab.
- Jeff
I meant assigning channels to things, 5 HAS to be Nor/Att/rth for instance...
I cant change the 'off' of channel onwards to 'on' so I cant enable carefree at the moment
Jul 28, 2011, 01:53 PM
hmm also I dont want camera tilt on channel 9 of my 8 chn radio, i want it on 7 like I had it before...
Jul 28, 2011, 01:56 PM
Zirt57's Avatar
---Deleted---
Jul 28, 2011, 02:02 PM
Hmmm, I bet you could use the new XAircraft Center software to update to 1.32 firmware and then load the old XAircraft Configuration software to make the changes you are talking about until we can figure this out. A bit kludgy but should work.
- Jeff
good idea, unfortunately it doesn't work..
Jul 28, 2011, 02:09 PM
cant get the motors to spin lol
Jul 28, 2011, 02:29 PM
Zirt57's Avatar
---Deleted---
Discussion Xaircraft X650 Quad Owners and Testers Thread Z06 Tony Multirotor Drone Talk 459 Feb 07, 2014 03:54 PM
Discussion x650 Technical Documents Translation:XAircraft X650 LED Module infmetry Multirotor Drone Talk 9 Nov 22, 2011 07:03 PM
Discussion WANTED:Test-Pilots for X650&Letter to XAircraft Pilots/The final namelist determined xaircraft Multirotor Drone Talk 35 Jan 11, 2011 08:28 AM
Discussion X650 the new quad from XAircraft to be launched very soon bob.titus Multirotor Drone Talk 558 Nov 20, 2010 12:33 PM
Discussion Official!!!!!! Parrot A.RDrone USA owners thread Quad_Addict Multirotor Drone Talk 59 Oct 27, 2010 11:48 PM
