I see from a post by Abin about the X650 spares on the, "Machine shutdown, accessories will continue to provide at least six months or more." See http://bbs.5imx.com/bbs/redirect.php...tpost#lastpost
Only 6 months. That is not a long time |
Thanks Josh for confirming it. For some bizarre reason I had thought the model number was tied to the size. I can see they might want to do that for increased stability.
Anyone with suggestions. Edit ops forgot about the motor mounts ....... Edit: Just thinking aloud....Arms can be made from Aluminium square tubing and maybe not need the motor mounts at all. Can be made from G10 which fixes to the square tubing. Graham is this possible to make some smart looking mounts. Must check the weight of square tubing. Okay weight of 20x20 square tubing for the same length arm is 72grams vs 17.4 so with a hexa one will add a total of 327.6grams onto the weight. Not and option. Edit: Have some 14mm carbon fibre tube and using this the section of the same length is 14.4 vs 17.4 so there is a small saving. Back to the problem...motor mounts and fuselage arm mounts. Need to stock up on these. And also need to figure out how to drill the holes accurately |
AVRoto 2814 770kv motors (similar to Pulso/MK XL motors) -HobbyKing Blueseries 30A ESCs |
Prop APC 10x4.7 SF APC 11x4.7 SF APC 12x3.8 SF
Max Watts @ 11.1V 122 163 201 Max Thrust Oz 30.4 39.3 46.3 Prop APC 10x4.7 SF APC 11x4.7 SF APC 12x3.8 SF Max Watts @ 14.8V 266 346 423 Max Thrust Oz 50.9 60 60.3 just on a 4 rotor quad you can have 7.5 to 15 pound motor lift but safe payload weight is half of the lift weight. an octo can have 15 to 30 pound lift depends on prop and battery size but i will ask josh to check up on my math to see if i am right because he knows better than i do. |
Just about to buy an X650 |
If this is the case, I will be furious, I've only just bought an X650 and have no wish to pay out for / downgrade to the X650V. I expected I would get a few years use out of this, and now it turns out that unless I go the route of completely replacing the frame, I will not be able to repair my X650 when the inevitable happens and it takes a tumble.
I had faith that XA would fix the GPS in time and was prepaired to wait for that, but this is far worse, this represents a cutting off of any future support for what is a better platform, so we have the choice, pay for a costly downgrade, or completely replace the frame, just keeping the XA electronics. I guess there's always option 3, buy the MK that I should have got from the start! |
I recall they ceased making any spares for the X500 and X600 soon after they stopped offering them for sale too, It seems to be common practice in China from what I have seen
I designed some stronger legs for the X650, so you can get them easily, I also designed some hexa and Y6 centre plates too, I could do some standard centre plates if there was any sort of demand. I guess the things you wont be able to get would be the metal parts such as brackets, spacers and arms. as already mentioned you could use alloy or carbon box section for arms and GF for motor mounts if desired, they would be easy to design. I know it's not the ideal solution, but its something at least... here is my mk clone which uses X650 centre plates and 10mm alloy arms Quote:
Generally the other parts can be sourced from other sources such as your design and Graham(quadframes), delrin clamping blocks from AGL Hobbies (although they do not fit the 14mm arm used...only 12mm and 16mm). I for one will not be buying a 650V and for few reasons...IMO they will discontinue that in 6 months time and ... it does not lend itself to modifications as well as the X650...and I do not have any more cash that I am prepared to lay out.....etc etc...... Like your MK clone Cheers Rob |
Thread Tools | |
Similar Threads | |||||
Discussion | Xaircraft X650 Quad Owners and Testers Thread | Z06 Tony | Multirotor Drone Talk | 459 | Feb 07, 2014 03:54 PM |
Discussion | x650 Technical Documents Translation:XAircraft X650 LED Module | infmetry | Multirotor Drone Talk | 9 | Nov 22, 2011 07:03 PM |
Discussion | WANTED:Test-Pilots for X650&Letter to XAircraft Pilots/The final namelist determined | xaircraft | Multirotor Drone Talk | 35 | Jan 11, 2011 08:28 AM |
Discussion | X650 the new quad from XAircraft to be launched very soon | bob.titus | Multirotor Drone Talk | 558 | Nov 20, 2010 12:33 PM |
Discussion | Official!!!!!! Parrot A.RDrone USA owners thread | Quad_Addict | Multirotor Drone Talk | 59 | Oct 27, 2010 11:48 PM |
