I have an older x650 V4 with Superx and it wont hold hover after launch. Its all stock other than gimbal with gopro. im using 3s 2200 mah 25c batt. I tried with 2 batteries and got same results. Any thoughts on this issue?
http://log.xaircraft.com/#2014_11_11...000_71.2.00.17 |
hey guys, sorry to ask this if its already been covered, there is just way to much to read
Im trying to find the best motor & prop set up for my new X650 pro My set up is: Camera type GoPro 4Black 88g Gimbal Xaircraft stella 120g Boscam 5.8GHz 600mW Tx 22g Frsky's X8R 16.8g SuperX fc and osd Xaircraft 30a esc Frskys lipo sensor 18g Im still in air about a battery 4s 8000mAH at 845g 6600mAH at 700g 6200mAH at 589g The motors im thinking would give me good flight time would be a T Motor MN3508 KV700 with 12x4.7 slowfly prop advice or suggestions anyone? Thanks |
Anyone know where I can find the software to the FC1212-P? I looked pretty much everywhere and no one seems to have it..
Well after searching here and low all morning for the software I came home tonight and tried one last place as a ditch effort and decided to share it with anyone who might be looking for it like I did.
https://web.archive.org/web/20140819171859/http://www.xaircraft.com/downloads/ |
Hi guys,
Been away a long time but just browsed through a few dozen pages and wondered; I bought the X650 V8 with the gps, ahrs and all that junk, which never really worked Threw it in the cupboard, and pretty much wrote it off as a bad investment. So now i'm entertaining the thought of possibly getting the SuperX or MiniX stuff so I can actually get it flying. Any recommendations? (Assume i'll have to dump the ESCs, Motors and Props as well). thanks |
Apr 09, 2015, 02:23 PM | |
BretRhines | |
A moderator felt this post violated the following rule: Off Topic Advertisement.
Jim |
Hey all! i am pretty new to rc forums but allready experienced with rc planes helis and recently with multicopters (fy680 and now t810)
I have a questoin regarding the osd v2 connections... Its not to easy to explain so i will post a picture attached to this post. Where should i connect the av in GND cable? Thanks! |
Are you using 3 batts? 1 for flight, 2 for vtx and cam...?
Ground loops... Not picking right 1, I use 2 batts, vtx, cam, osd, ( well, osd has second ground...voltage moniter) are together on 1 small batt, flight is on a big batt, of filters was not working with the esc's and motor combo I was running |
Does the current shown on the osd is measured from the battery its AVin GND cable is connected to? Or from the one connected to Superx (flight battery) ?? |
I don't have the superX, Xaircraft 650 with both v1 and v2 ahrs gps is ceiling queen until....
I have been watching superX for a while, I think I would rather find one on eBay or RCG classifieds before giving xair more money, that said.... From superX. Osd gets batt voltage from fc thru IO to osd, along with the flight info. If you power vtx and camera from Flight bat, a power filter should smooth out most interference from flight bat and ecs/motor noise. Cons: flight batt noise, more weight less flight times Pros : less weight, better flight times, https://www.rcgroups.com/forums/show...49&postcount=2 |
Reason: Added typical osd hookup....
Thank youQuote:
anybody interested - http://download.xaircraft.cn/Softwares/
Thread Tools | |
Similar Threads | |||||
Discussion | Xaircraft X650 Quad Owners and Testers Thread | Z06 Tony | Multirotor Drone Talk | 459 | Feb 07, 2014 03:54 PM |
Discussion | x650 Technical Documents Translation:XAircraft X650 LED Module | infmetry | Multirotor Drone Talk | 9 | Nov 22, 2011 07:03 PM |
Discussion | WANTED:Test-Pilots for X650&Letter to XAircraft Pilots/The final namelist determined | xaircraft | Multirotor Drone Talk | 35 | Jan 11, 2011 08:28 AM |
Discussion | X650 the new quad from XAircraft to be launched very soon | bob.titus | Multirotor Drone Talk | 558 | Nov 20, 2010 12:33 PM |
Discussion | Official!!!!!! Parrot A.RDrone USA owners thread | Quad_Addict | Multirotor Drone Talk | 59 | Oct 27, 2010 11:48 PM |
