Oct 28, 2012, 09:15 PM
Redhood's Avatar
Ducati I really want to try that set up out on one of my Thunderbolts. Great Idea.
Oct 28, 2012, 09:18 PM
2 many planes & 2 little time
scootrb4's Avatar
Originally Posted by quitcherbitchen View Post
Did some bench test today. I changed the timing on my Eflite 60 pro Esc to High 25 degrees and here are the results:
Timing set to default 15 degrees on Eflite P-15 with extra 300 prop and 60amp Pro esc on 2250 TP 3s 45c. Peak C 31.49-- Volts 11.89-- Peak W 352.16 -- Energy .991wh-- Charge .089ah
Timing changed to 25 degrees Peak C 34.04--Volts 11.83-- Peak W 378.7w--Energy 1.09--Charge .099ah ESC not noticeable change in temp.
Now I just need to test fly it with the High timing.
Let us know if that makes a measurable difference in performance... and any change in battery voltage at end of flight?
Oct 28, 2012, 09:28 PM
We Begin bombing in 5 Minutes
quitcherbitchen's Avatar
You bet Scootr.
Latest blog entry: Freewing V2 Me 262 revival
Oct 28, 2012, 09:29 PM
Redhood's Avatar
Once the final decals get here from Callie It'll be ready to tear up the sky.
Oct 28, 2012, 09:32 PM
You left the prop off you know that?
Oct 28, 2012, 09:36 PM
scootrb4's Avatar
No sense going out without the final decals on
Your bird looks NICE, good luck with it.
I have planes that never got their decals! LOL, I did have Cali make me a Redhead Doll & 4 Aces for my Big Spitfire, but they were jinxed
Oct 29, 2012, 07:12 AM
I can fix it.
nageotte's Avatar
It is amazing how far we push this plane beyond it's design limits! And for the most part, it handles it well.
Oct 29, 2012, 07:30 AM
Some.. call him Tim...
Ducati Mechanic's Avatar
You won't be disappointed! I did need to find the CG "sweet spot"(just north of neutral) to get it locked in(as you see in the video). When the pack was even 1/4" farther forward it had a bad wiggle at speed. When I moved the pack back, it locked right in!
The guys that design PZ planes aren't messing around! I'm sure that was there intent.
Oct 29, 2012, 12:39 PM
Diverted by planks
tracknoob's Avatar
Rather than a seat of the pants indicator from the in the air flying, an actual static thrust measurement for both setups would be a nice additional piece of info, too. If those extra watts are going to heat only, then it's not a good trade off. But additional thrust...
Oct 29, 2012, 03:15 PM
Never Trade Luck for Skill
MERLIN V16's Avatar
"The guys that design PZ planes aren't messing around! I'm sure that was there intent."
I wish this was the case with their new Corsair! The Thunderbolt it is not!
Oct 29, 2012, 04:04 PM
You can't take the sky from me
copperbricks's Avatar
what's up with the corsair? A buddy of mine flew his at the club, and it looked, and flew great,plus he had no complaints.
Oct 29, 2012, 05:09 PM
MERLIN V16's Avatar
Tell him to check the Flaps,Rudder and the front wing mount. Guys are posting Flaps,Rudder and wing mounting points falling off.
Oct 29, 2012, 07:58 PM
scootrb4's Avatar
Wowser! That is a rare thing for a PZ warbird. Maybe the first design or QC complaints I recall. I have none of that in the 4 models I have of theirs.
Diverted by planks
tracknoob's Avatar
Buddy at our site loves his new version Corsair. He also has like four other various manufacturer's Corsairs, too, including the version one PZ. He has installed the Eflite retracts in the new one, and they are slick - especially with the magnetic attachment of the wheel pant, so it can rotate but still stay attached.
BUT he indeed did have the flap issue and had to rehinge them. Fortunately he is doing what I do these days for hinging and instead of using CA cloth hinges, or pins, or plastic ones, all we do is lay down a VERY thin bead of Welder's glue or Uhu Por (depending on foam type) along the seam, and connect the movable surface up to the airframe a time or two (it's a type of contact cement), then leave it in place. Voila -- instant hinge. After curing for a few hours or overnight, it is the most flexible, but strong hinge you could ask for. He said it worked great on the flap issue.
Oct 29, 2012, 08:18 PM
Oh, huh. I will tell him about that.
Discussion World Models p47 1.20 dards Fuel Warbirds 1 Oct 20, 2010 10:55 AM
Discussion E-Flite P47 or Parkzone Corsair?? Gobstopper Electric Warbirds 13 Dec 02, 2009 10:37 PM
Discussion New Parkzone p51 or Greatplanes P47 casedit Electric Warbirds 5 Sep 01, 2009 09:08 AM
