Sometimes when the plane is flying towards you or away, and the antenna of your transmitter is pointing directly toward the aircraft, you can create a situation where the antenna of the rx and the tx antenna are perfectly in line. This orientation is the worst possible for signal reception, compounded by the fact that the Motor and ESC tend to act as a "block" especially when the plane is moving towards you. Since the airplane is moving, loss of signal in this case tends to be very brief. Point being- you don't always have to have a source of interference to get hit on 72mHz.
Again, only a possibility. Quote:
-B |
The same thing can happen on 2.4ghz, which is why on DSM rx's that have satellite receivers, they instruct you to orient the dipole antennae at 90 deg angles to each other.
In a couple of days I am going to be posting my build log of what I have done with my P-47 so far including:
AR7000 w/ satellite (I think orientation is ok, since I didnt put the RX in the default cutout for it) FY20A Scorpion Commander V2 45 AMP with linear BEC SportBEC from Dimension Engineering Invasion Stripes Servo protectors Also how I glossed the plane (only on the black areas, underneath the fuselage, servo protectors, and the cowl) Will post pics and everything in the coming days |
hey everyone, im getting ready to either buy a replacement eflite retract or the changesun retracts form x-flite. those of you who have the changesuns with the metal trunions, how do you like them? and how difficult were they to install? i would appreciate the feedback.
Got used P 47 about five minutes ago, it has a nice crack in the wing going from just in front of the wheel wells for the retracts back about 2 inches, mixing up some 5 minute epoxy to fix that crack and one at the end of the elevator. Love the looks of this thing! I will be putting the flap servos in as well! Got to charge some batteries to see if I can get out later this afternoon!
snag, i removed the clevis from the rudder in order to flex it and forgot which hole was the default one? anyone know?
My rudder is set on the outside hole and it is stock set up other then Weathering
Thread Tools | |
Similar Threads | |||||
Discussion | World Models p47 1.20 | dards | Fuel Warbirds | 1 | Oct 20, 2010 10:55 AM |
Discussion | E-Flite P47 or Parkzone Corsair?? | Gobstopper | Electric Warbirds | 13 | Dec 02, 2009 10:37 PM |
Discussion | New Parkzone p51 or Greatplanes P47 | casedit | Electric Warbirds | 5 | Sep 01, 2009 09:08 AM |
