Oct 11, 2010, 07:27 AM
Crafter of flying plugs
Owen Hedger's Avatar
Build Log
1/8th Scale PSS Douglas F3D-2 Skyknight
Only 48 weeks until Manilla Slope Fest 2011. Time to get started on another PSS build to avoid the 4 week dash to finish that my first PSS build brought me this year.
My first attempt at a PSS build was a Yokosuka Model 22 Ohka. Wing span ended up at 2M and way over weight at 34oz/sq ft.
Using what I learnt on that build I have decided on an 1/8th scale F3D Skyknight. 1/8 scale gives a fuse length of 1.73m and wing span of 1.93M.
I expect the wings to be expanded to about 2.5M depending on how heavy the fuse ends up. I won't be doing the wings until the fuse is finished so I dont build them too small like I did with the Ohka.
So my intended maximum weight is 6.5Kg. 2 Kg budget for the wings and 4.5Kg for the fuse. I very confident that I can bring the wings in under 2 Kg even at 2.7m total span. So what ever I can save on the wings I can put into the fuse if I have to.
Fuse construction will be a 20x12mm pine spine with 3mm ply bulkheads and filled with EPS foam. Sheeted with 1/32 pine veneer and covered with polyester and glass tissue. Ply bulkheads are to give me a guide to shape the foam rather than being structural and the pine veneer Im getting at the right price otherwise I would use balsa. EPS foam is the Expol underfloor insulation sold at bunnings. Weighs just about 1 lb per sq foot. Can get a usable block from each sheet thats almost a 1/4 of a sheet of blue foam.
Wings to be MH32 which is proving to be popular currently but at 10.5% and root chord of 15". Construction to be some sort of spar, foam, veneer and glass tissue etc.
Progress so far is that ply bulkheads have been cut but some need a little tweaking. Have placed bulkhead on the spine to get my first overall impression of an 1/8th scale Skyknight. That impression is that at 1/8 scale it's still pretty big. As big as I can transport anyway. Frame and foam for the fuse looking good to come in under 2kg.
Although its a long way off I like the scheme and finish of this model skyknight:
Which I presume based on this scheme:
So that's all for now...
Oct 11, 2010, 07:30 AM
Just Toss It !!!
MATIN's Avatar
Owen.
You're scaring me!
Matin
feels a panic-attack coming on.....
Oct 11, 2010, 02:02 PM
Crikey never leave beer behind
steve wenban's Avatar
I like it !! , I'm just waiting for my head to re-attach itself to my neck and I'll be back in the workshop ,got a Hurricane to finish
SteveW
Oct 11, 2010, 02:15 PM
auto-tune remix
slopemeno's Avatar
Cool subject. There's a lot of those '50's early-jet subjects that are under represented.
Oct 11, 2010, 03:30 PM
Embrace the suck
nauga's Avatar
OooRah! I love it!
Around here if you build anything other than a P-39 or P-51 they bring you up before the committee.
Nauga,
under wraps
Oct 11, 2010, 04:52 PM
Gravity sucks
SrWade's Avatar
Originally Posted by nauga
OooRah! I love it!
Nauga,
under wraps
Then there must be a special chair at the table with your name on an engraved plaque, oh master of the wide bodies!
Oct 11, 2010, 04:55 PM
They are not wide bodied they are just big boned
SteveW Its round I tells ya
Oct 11, 2010, 06:00 PM
Feeling lucky .... Punk
joel63's Avatar
Nice choice !
Oct 11, 2010, 09:07 PM
I failed linkage geometry
salisbug's Avatar
Looking forward to this one Owen. Great subject choice.
Not surprised Nauga is liking it...
Can't wait to see this one flying alongside the OZSkunkworx Buckeye (if Shane ever extracts his digit).
Oct 11, 2010, 09:08 PM
soargasm's Avatar
watching with interest
shane
Oct 11, 2010, 10:25 PM
TEAM OZSKUNKWORX
r/c junkie's Avatar
Yer Yer i got the plans done.
Watching with intrest Owen
Shane
Oct 11, 2010, 11:13 PM
Embrace the suck
nauga's Avatar
Can't wait to see this one flying alongside the OZSkunkworx Buckeye...
Now there's something I can get into - a flight of two with its own gravity.
Nauga,
who is willing to pull some fingers to get a Guppy fuse or two.
Oct 12, 2010, 02:32 AM
Dont worry Matin, I have a bit to do before winter gets here, at least one other PSS build. We are already half way through spring :/ There isnt much good weather here after winter and before mid september that one can glass and paint in. We have a bunnings here now so this time around so getting building supplies that dont require me to give up a limb will be much eaiser.
slopemeno, I think it's a great candidate from that period. It's as mid-winged at it gets and I think should have a fairly even weight distribution. CG calculator has the CG alot further back than 30%. Can anybody tell me the merits of a calculator that takes into account the tale surfaces such as this one? http://adamone.rchomepage.com/cg_calc.htm
salisbug, junkie, good to have you along. Buckeye would be a great companion. I cant help but think a Skyknight and Prowler would also make a good pair in a father and son sort of way. If your want to knock one of those out that would be good.
nauga, I had been directed to check out your threads in the past so im happy to have your approval
Gald your like it joel.
Steve, so far my wife has been tolerant of the more physical discipline of this hobby but Im pretty sure she knows this is all your fault Gald you like my choice. Second one seems like it will be eaiser than the first. This one will deserve panel lines and weathering so Im a bit miffed I missed the demo this year. Plenty of time to read threads here before im up to that though.
Still pondering dimensions over the frame, tail may get a 20mm trim. Its interesting how a matchbox model can be more accurate than any 3-view you can find, including the 3-view in the pilots handbook.
My mother is coming to stay the night tomorrow so it will be a few days before I get back to any building
Oct 12, 2010, 08:01 AM
Embrace the suck
nauga's Avatar
Originally Posted by owenthegreat
I cant help but think a Skyknight and Prowler would also make a good pair...
Y'all don't do 'easy', do you? The southern hemisphere chapter of the 'No fuse too fat' club checking in. Time to pack my bags and move south.
I may have something a little more accurate, let me see what I can dig up. There's also one on a stick not far from me if you need detail photos.
Nauga,
with a tip of the hat to Russ Thompson
Oct 12, 2010, 08:21 AM
Embrace the suck
nauga's Avatar
Check your PMs.
Nauga,
the librarian
Discussion Mc Donnel Douglas MD83 - Scratch build from depron Ben_E Scratchbuilt EDFs 176 Jul 23, 2021 06:27 AM
Help! ISR U-2 PSS Build HELP!!!PSS FEST IS APPROACHING!! Jantar2A Slope 6 Feb 28, 2007 10:55 PM
Sold Douglas DC-3 Twin Kit/2-O.S. .40 LA/4Ch Radio Combo Nichole Aircraft - Fuel - Airplanes (FS/W) 3 Nov 28, 2006 12:34 PM
Douglas F3D Skynight Brian Koester Slope 9 Jan 15, 2005 12:49 PM
2 PSS planes for sale: Sailndude Aircraft - Electric - Airplanes (FS/W) 3 Nov 18, 2001 09:24 PM
