Oct 09, 2010, 04:23 PM
BOXFUSE KING!
Kronikpilot's Avatar
Idea
Typhoon delta...FREE PDF PLANS! another HD flight vid added!
Typhoon delta high wing!....
Maiden video.
TYPHOON DELTA MAIDEN! (3 min 33 sec)
Flight envelope!
TYPHOON DELTA FINAL...Kronikpilot's original design. (3 min 38 sec)
Typhoon Delta another day in paradise. (3 min 25 sec)
ELEVON SET-UP
6mm DEPRON
MOTOR: BlueWonder 3000KV
ESC: SS 18amp. HK brand.
PROP: APC 6x4 pusher
SERVOS: HXT 900 9gram servo (2x)
BATTERY: 2s RHINO 30c LIPO
This my standard parkflyer set up for these size birds. it's less than $40 @ hobbyking.
Last edited by Kronikpilot; Feb 23, 2011 at 03:48 PM. Reason: added specs. added video.
Oct 09, 2010, 04:29 PM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
Looks Good !!! Build it !!!
Latest blog entry: Lost plans
Oct 09, 2010, 04:56 PM
Build straight - Fly twisty
Whiskers's Avatar
Could be a good idea to move the v-stab back as far as it can go.
Oct 09, 2010, 06:40 PM
BOXFUSE KING!
I just might!
Thanks. This is my doodle design I usually adjust as I build it.
Thanks for looking guys.
mayday.
....if I get more than 100 VIEWS by the end of the day I will build it!
Oct 09, 2010, 09:07 PM
better get your foam out, you gotta build it now.
Oct 09, 2010, 10:31 PM
BOXFUSE KING!
O.K sir, here we go.....(grabs pencil and paper).
....and Hmmm I GOT IT!...stay tune.
mayday.
Oct 09, 2010, 10:40 PM
Wait... what?
aeryck's Avatar
Concept looks great! Keep us posted on the build.
Oct 10, 2010, 01:26 AM
Foam Av8r
RogueTitan's Avatar
should be a stable flier and a good windy day flier.
Oct 10, 2010, 04:32 PM
BOXFUSE KING!
Thanks guys, I started brainstorming and came up with some cool concepts. I should be able to start the build by today.
mayday.
Oct 10, 2010, 05:35 PM
BOXFUSE KING!
it does'nt look much but once it's built with foam it's going to look CRAZY
I will do adjustments as I build her.
Oct 10, 2010, 08:52 PM
BOXFUSE KING!
Build started!
...Let the fun begin. check my first post.
mayday.
Oct 10, 2010, 09:05 PM
Wait... what?
aeryck's Avatar
Nice! What kinda power system are you thinkin for that bird?
Oct 11, 2010, 08:57 AM
BOXFUSE KING!
Hi aeryck, maybe a 3000kv Blue wonder with 1050mah 2s spinning a 6x4 apc prop.
....I did not like the way it looks, it's not crazy enough so I revised the fuse and got the winglet and vert stab done. I hope to finish her by tomorow. Thanks for loooking.
madyday.
Oct 11, 2010, 09:35 AM
Foam Av8r
RogueTitan's Avatar
looking good
are you going to make a PDF of the plans?
Oct 11, 2010, 09:59 AM
Foam Av8r
RogueTitan's Avatar
looking good
Discussion What's the smallest high wing balsa kit (ARF)? jlcamp7 Micro Ready-to-Fly 4 Aug 08, 2010 12:25 PM
Discussion What's the difference between high and low wing loading? roberted5 Foamies (Scratchbuilt) 11 Aug 03, 2010 07:13 PM
Discussion What's the difference between high and low wing loading? roberted5 3D Foamies 1 Jul 31, 2010 09:26 PM
Wanted HKM "High-End" Sailplane Left Wing or Wing Set Ne-Aero Aircraft - Sailplanes (FS/W) 2 Jan 02, 2010 08:26 AM
For Sale FS Plantraco TX/RX Classroom figther and MISC kushal_22 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Aug 01, 2008 07:51 AM
