Oct 03, 2010, 10:16 PM
New Product
XAircraft X650 Technical Documents Translation
Hi guys,
Due to most of xaircraft X650 documents are chinese that hard to get the details of it, for convenience I will translate(poor translation) all article on their website and post it in www.xaircraft.org, also this forum.
XAircraft X650 QuadCopter(QuadRotor) Flight Controller Architecture Design
XAircraft has designed several flight controllers for internal research and development and testing without sell since 2007.
In the R&D process, in order to achieve standardization and scalability in flight control, we repeatedly modified the architecture design. The picture below shows the final design of flight control architecture which we we called "standard flight control system".
The master control chip ARM of standard flight controller provide 100MPIS processing power to meet the requirements of complex and high-speed control. Flight controllers support 7 exptend modules, two of them are built-in input signal capture module(input module) and control signal output module (output module).
Input Signal Capture Module(Input Module) Features:
* Support 12-channel remote control signal capture.
* Each capture channel has 1us pulse width identification ability.
* Compatible with any type and frequency remote control, such as Futaba, JR, Spektrum, etc.
* Support two or more remote control devices to capture the signal at the same time, on some special occasions, often requires two people to execute a remote control mission, as one person control flight, another control camera mount, requires two remote control devices to work simultaneously.
* Detect the pulse width of remote control input signal, for some advanced remote control, this feature can be used as control protection and signal stability testing.
Meanwhile, users can adjust parameters and check the working condition of input signal capture module by using
XAircraft Flight Control Management(Parameter Adjustment) Software and XAircraft USB-Link PC Connector.
Control Signal Output Module (Output Module) Features:
* 12-channel output capability.
* Each channel output control accuracy: 1us
* Support the general and high-speed digital steering engine, 12 channels are divided into 3 groups, each pulse signal can be arbitrarily adjusted.
* Support High-Speed (UltraPWM mode) Electric Speed Control Device(UltraPWM ESC), low-speed mode are also available.
Although the X650 is a quadrotor (Quadcopter) products, but it equipped with the standard flight control can support up to 12 rotor, usually retaining four output channels for the camera mount, means the X650 flight control can drive 8 rotor(8 propeller) without need to purchase a new flight controller.
Except the two built-in modules, XAircraft standard flight control module also has 5 extend ports, they are PortA to PortE, one of them used for AHRS (Attitude and Heading Reference Systems) which provides Pitch & Roll Angle and heading. As the flight control get the AHRS attitude and heading signals, like 30 degrees tilt, 18 degrees yaw, the flight control algorithms adjust the aircraft's attitude to achieve a smooth flight.
AHRS module is a standard configuration on X650.
The remaining extend port can also be used to connect other modules, such as GPS Module, Range Finder Module, LED Module(indicate aircraft status), Power Monitor Module and so on.
There is a special interface called the connector port (Link Port) in flight controller. All devices connected to the port are called connectors (Linker). Player can set the parameters of flight control Via USB-Link, or upgrade firmware for the flight control.
USB-Link is a standard configuration on X650. Users can also install the Bluetooth device (Bluetooth-Link), OSD-Link and so on. We actively cooperate with several universities in China to improve the control instruction of this interface. It will be announced to help the secondary development of flight control system.
Oct 03, 2010, 10:19 PM
XAircraft X650 QuadCopter-Problem About I2C Brushless Motor Speed Ccontroller
All along along, the brushless motor speed controller (ESC) of four-rotor aircraft mostly use I2C digital communication. It put all brushless motor speed controller connection in series on the bus through two data lines (one for the clock SCL, one for data SDA), and send the control signals to brushless motor speed controller at regular time. MK products used this communication mode, as well as our early X500D X600D.
I2C communication mode looks perfect, you can save the number of communication cable, moreover does not need to modify the hardware and interface when extended the four-rotor to six or eight rotor, just directly attached to the existing communications bus. This is a economy design that easy to extend.
However, there are some problem in actual use:
1. As long as one of brushless motor speed controller broken down, will affect all the other brushless motor speed controller on I2C bus, this failure is fatal. Although we can change the software to make the all brushless motor speed controller to enter the normal working condition after broken down. But the I2C communication mode has greatly increased the probability of failure, for expensive camera equipment and x650 aircraft, this is clearly not the best choice.
2. ESC is working in Series on the I2C, the more ESC, the more time cost in communication. The maximum communication rate of the standard I2C is 400kbps, for reliability and stability, the general four-rotor will use the communication speed 100kbps, means it can only send and receive data only 10 byte per 1ms. No enough for high-speed and high-precision motor control, as 500Hz and 1000 control level with the increase in the number of motors.
3. There are many ESC in in the field of model airplane before four-rotor aircraft invention, after years of development they are become very mature and reliable and has a very rich type and power output. But I2C are incompatible with these traditional ESC interface, and nothing much in the type, inconvenient to extend.
In order to solve these problems, we used a more stable, reliable interface solution that compatible with current brushless motor speed controller, we called it UltraPWM technology:
All ESC are connect parallel to flight controller, any one of them brokecn down will not affect the work of the entire system, aircraft still able to landed safely via the remaining seven motor. This is essential for multi-rotor aircraft to meet high security requirement.
Motor control frequency 500Hz, 1000 control level. The the control pulse width error between two brushless motor less than 1%.
Compatible with the existing ESC interface, without requiring high speed and high precision control, instead, it can work with the general speed controller too.
Oct 03, 2010, 10:20 PM
XAircraft X650 QuadCopter LED Module
All the LED that designed to indicate the circuit status are installed under the X650 body shell. And it is difficult to make out the flight attitude as the X650 are away more than 50 meters from the controler. So we designed the LED module to indicate the system status and flight attitude.
Features:
* Include 56 bright LED, 28 for overlooking, 28 for looking up, help player make out the flight attitude and dircetion of X650.
* Each one LED can be individually controlled light on or off.
* Display the any status you want via adjust the XAircraft X650 Flight Control Management(Parameter Adjustment) Software.
Oct 03, 2010, 10:21 PM
XAircraft X650 is definitely not just a simple four-rotor aircraft toy. It has a very powerful user-defined function that player can fine-tune the various parameters to meet their flight style, such as: Joystick sensitivity, aircraft flight parameters at different load, etc.
In fact, the biaxial camera mount, in order to fit to different types of cameras, also required a powerful software to adjust different parameter, such as: different size camera, camera focus location and trigger time... all need to fine-tuning parameters.
Meanwhile XAircraft Flight Control Management(Parameter Adjustment) Software is a working status monitor that player can check the service condition of x650 to ensure safe flight. It can also help player quickly to find the problem when the aircraft broken down.
Oct 03, 2010, 10:23 PM
XAircraft X650 QuadCopter QuadRotor Instruction Muanual(PDF) Release
Xaircraft release the x650 instruction muanual, chinese and english version.
Download it from here
Oct 03, 2010, 10:24 PM
XAircraft X650-The Difference Between UltraPWM ESC and General ESC
General ESC has been very mature after years of development, many species, current from small ampere to large ampere. But the general ESC are not designed for multi-rotor craft, there are a few common problem if it used in multi-rotor craft:
* Low control frequency: the general ESC used standard PWM pulse width which is only 50Hz(20ms cycle). In fact, most of the general ESC could work in much higher than this range without any problem. The ESC we tested they basically can work well from 200Hz to 300Hz in control frequency, but this frequency can only meet the common requirements.
* Consistency is poor: almost all general ESC have a common basic function called "the start throttle setting" that can be used to eliminate the different throttle pulse width with different remote control. That is you can set all of the ESC to start the motor at a some throttle position. Unfortunately, this feature can not solve the problem in poor consistency, for example, rocker swing 10 degrees from the start position, assuming the speed of motor is 3000 rpm at this time, and the environments are invariant, then change the setting and rocker swing 10 degrees from the start position again, you will find the motor speed may be only 2500 rpm, but also changes speed with the ESC temperature. It is caused by the general ESC have not a stable reference clock source without temperature influence. That is ok for the single rotor craft, but disaster for multi-rotor craft, because the different motor speed in four rotor is difficulty for the craft to fly Stable.
* Constant speed mode, which is the only function for senior ESC. For single rotor craft, the ESC itself is a closed loop control system, constant speed mode can eliminate the effects that output power does not vary with battery voltage drop down. This feature allows craft flight more stable. For Multi-rotor system, ESC is only responsible for driving the motor, it can not achieve and does not need self-loop, that will affect the flight stability of multi-rotor aircraft.
* All ESC are connect parallel to flight controller, any one of them brokecn down will not affect the work of the entire system, aircraft still able to landed safely via the remaining seven motor. This is essential for multi-rotor aircraft to meet high security requirement.
* Motor control frequency 500Hz, 1000 control level. The the control pulse width error between two brushless motor less than 1%.
* Compatible with the existing ESC interface, without requiring high speed and high precision control, instead, it can work with the general speed controller too.
Oct 03, 2010, 10:25 PM
XAircraft X650 ESC-A4 High-Speed ESC Release
XAircraft ESC-A4 is a 4 in 1 high-speed ESC follow the UltraPWM standard and as the standard configuration for X650.
Feautres:
* 4 Electric speed control device designed into one, line connect easy and safe.
* Up to 60 MOS, able to withstand the high current.
* Continue to provide 35A output current in the 3s battery.
* 5A output capacity integrated(UBEC).
* Support UltraPWM protocols and the control frequency up to 500Hz (2ms).
Oct 03, 2010, 10:26 PM
XAircraft X650 AHRS release
AHRS system is used for calculate flight attitude (pitch and roll) and heading, it is an essential device for multi-rotor aircraft. The AHRS of XAircraft include 2 model: attitude calculate and compass. Attitude calculate model is standard configuration, and compass is a extend model for work with GPS.
Feautres:
* + -300 į /s 3-axis gyroscope
* +-2g 3-axis acceleration sensor
* Optional 3-axis magnetic field sensor
* Output: Euler angles (Pitch, Roll, Yaw) (units deg), 3-axis angular velocity (in deg/s), 3-axis acceleration (in g)
Oct 04, 2010, 09:32 AM
Hi, what is the official date for public release?
Oct 06, 2010, 06:52 AM
XAircraft X650 UltraPWM ESC standards
UltraPWM ESC hardware interface:
Using 3 pin connector, 2.54mm pin spacing, pin function description:
+: Positive power, usually +5 v, cable color is red.
-: Negative power, that is GND, cable color is black or gray-black.
Signal: signal lines, cable color is white.
UltraPWM Communication Protocol:
Tp: The control cycle is 2ms(500Hz). Low Level Output Voltage when no control signal.
Ts: Start pulse width is 200us, the brushless motor can not be start if pulse width less than 200us.
Te: Termination pulse width is 1200us, pulse width greater than 1200us is considered as the maximum motor output power, UltraPWM works from 200us to 1200us.
V: 2.7v< voltage < 6v
Resolution: 1us, Te-Ts = 1000us, 1000 control level.
Oct 06, 2010, 06:53 AM
Flight Control Management(Parameter Adjustment) Software Release
XAircraft X650 Flight Control Management(Parameter Adjustment) Software make flight control become more powerful and flexible. Player can also check the working condition from it.
XAircraft Configuration support Chinese and English, can modify the language file to support more languages such as Traditional Chinese, Spanish, German, etc., which the user can complete on their own, we released the language pack.
Oct 06, 2010, 06:54 AM
XAircraft X650 Standard Flight Controller Release
The flight controllor of XAircraft X650 as a standard configuration can be used for 3, 6 and 8 rotor aircraft. It also supports four steering engine outputs to steady the camera mount.
Features:
* 12-channel remote control input.
* 12-channel control signal output, ALL channel support UltraPWM ESC, General Electric Adjustment, high-speed digital servo, general servo.
* 2 built-in modules: input control signal module and output module
* 5 expansion module interface for connecting AHRS, GPS, RF modules.
* 1 Link interface for connecting USB-Link or wireless module.
Oct 06, 2010, 07:03 AM
Subscribed
Oct 08, 2010, 03:51 AM
The Influence of Body Structure Vibration on Sensor Performance
Accelerometer and gyro Sensor are sensitive to vibration. In the X650, we tested the sensor output signals with and without cushion blocking:
Test environment as follows: the X650 fixed on the ground (with propeller), set 1 / 3 throttle, collected AHRS output data.
X650 AHRS Pitch&Roll Angle output(without cushion blocking):
X650 AHRS Pitch&Roll Angle output(with cushion blocking):
As the pics shown, the steady output in front means the motor does not start, the final output means motor is turned off. It can be seen the output angle error of AHRS change from + - 1 degree(without cushion blocking) to + -0.2 degrees(with cushion blocking).
Angular Rate Output(without cushion blocking):
Angular Rate Output(with cushion blocking):
The angular rate amplitude reduced by nearly 5 times with damping.
Acceleration Output(without cushion blocking):
Acceleration Output(with cushion blocking):
It can be seen, vibration put the biggest impact on Z-axis, also the amplitude reduced by nearly 5 times with cushion blocking.
Shock absorption is necessary for stable flight, must pay attention to the cushion blocking installation, and check the damping system before flight.
Oct 08, 2010, 03:55 AM
XAircraft X650 Camera Mount Design
In order to make the X650 fly steady to get a clearly images or video, XAircraft team spend a lot of time and energy on it, resulting in repeated delays product sale.
For small multi-rotor aircraft, in order to maintain the image steady need to overcome the high-frequency vibrations, wind and human operator. From June 2010, we have been perfect X650 multi-axis camera mount, now is the fourth beta version:
The steering engine as shown above are tested during the development of X650, now the fourth version has been able to take aerial photos clear and stable, but due to the virtual displacement and low resolution of steering engine, the video is unable to pass the test. So XAircraft collaborate with steering engine manufacturers to customize X650 special steering engine, it is under testing now.
Discussion x650 Technical Documents Translation:XAircraft X650 LED Module infmetry Multirotor Drone Talk 9 Nov 22, 2011 07:03 PM
Discussion WANTED:Test-Pilots for X650&Letter to XAircraft Pilots/The final namelist determined xaircraft Multirotor Drone Talk 35 Jan 11, 2011 08:28 AM
Discussion X650 the new quad from XAircraft to be launched very soon bob.titus Multirotor Drone Talk 558 Nov 20, 2010 12:33 PM
Data x650 Technical Documents Translation:Problem About I2C Brushless Motor Speed Ccontrol infmetry Multirotor Drone Talk 0 Oct 03, 2010 03:25 AM
Data x650 Technical Documents Translation:XAircraft Flight Controller Architecture Design infmetry Multirotor Drone Talk 0 Sep 29, 2010 11:58 PM
