Jul 07, 2003, 07:33 AM
Let's fly!
Dandy- anyone flying the stock wing with the EPS 300 C motor?
I have a MM Dandy, with the stock wing, motor, prop combo. I'm thinking about getting the GT wing, and the 300 C motor to go with it. However, I love the way the Dandy flies with the standard wing as well. Has anyone flown the Dandy with the stock wing and the 300 C motor? I'm not looking to hot rod with the stock wing...I like the slow puttin around the sky it does with the EPS-100 motor.
Also, I'm flying with an Etec 1200 2s pack and getting WONDERFUL flight times. How will my flight times be with the 300C motor and those packs?
Adam
Jul 07, 2003, 10:21 AM
Mountain Models Wannabe
CoClimber's Avatar
Adam,
The 300 motor isn't much heavier than the 280 so if you watch the throttle, you should be fine.
Doug
Jul 07, 2003, 10:45 AM
Let's fly!
Great!! Thanks Doug...just ordered the wing and the motor.
Jul 07, 2003, 11:34 AM
ryanl2006's Avatar
I fly mine with the 300 and stock wing. It is just fine but be carefull with throttle.
Jul 07, 2003, 12:13 PM
Motor Maniac
Your flight times will definitely be lower with the 300 motor even with throttle management. It is not as efficient as the 100 motor. Some of it will depend on how you prop the motor. I'm guessing you will get about 2/3 the flight time if you are careful with the throttle.
