A little bit of F3B history - Page 13 - RC Groups
May 22, 2017, 02:35 PM
UAS Test Pilot
SpeedMaster's Avatar
Hi Reto,
It is in fact an Avant Butterfly from Jaro Müller with the one piece wing...
Kjell.
Originally Posted by RetoF3X
Hi Kjell
I take a guess:
The fuselage looks like an "Avant Butterfly" from Jaro Mueller (one of the first commercially available moulded planes). That plane also had a one piece wing (what a pain...) But the wing shape does not match. Maybe a later version?
Or is it a copy of Ralf Decker's NoName aircraft?
I heard Espen has a nice collection of vintage F3B planes.
Best,
Reto
May 22, 2017, 04:26 PM
Originally Posted by SpeedMaster
Hi Reto,
Kjell.
Actually, the wing shape does match the original Avant. There should be LE break at 810 mm from center of the wing. The root chord - 240 mm, at 810mm -220 mm, at 1360 mm - 180 mm plus 90 mm tip. 2900 mm wing span
May 22, 2017, 05:57 PM
F3B and F3K
RetoF3X's Avatar
Hi HPdrifter
Do you have an Avant or a technical drawing you could share?
Maybe there were multiple iterations of the Avant Butterfly? The one I have seen in the early 90ies had TNT wingtips, which where highly popular at the time (see also here under "TNT Randbogen": http://www.aerodesign.de/aero/randbogen.htm)
@Kjell: do you have more mystery planes from Espen's hangar?
Reto
May 23, 2017, 06:52 PM
Hi HPdrifter
Reto
Hi Reto,
yes, I do have Avant's 3-view drawing and some tech info on what was involved to make it possible. Unfortunately, it's in Slovakian language. The Avant (full name is "MAB-2000 Avant") was a team effort of about 10 people under leadership of Jaro M. The project had started in 1984 and was finished in middle of 1985. The molds were eventually sold to Hungary. Whatever had come out of those molds in Hungary was called "Avant Butterfly". It's possible that people in Hungary made a new wing mold and that could be what you have seen. However, it's been a while and I might be wrong.
Jul 16, 2017, 02:22 PM
Balsa breaks better
Thermaler's Avatar
Okay guys, take me back . . .
From the 1st World Championship, who can share pictures of the following guys WITH their plans. . .
What other info can you share?
To here from these guys would be great!!!
Frikkie Roos - Jonathan
Joris Tenholt - Alba 2
Sean Bannister - Algebra VI
Mike O'Reilly - Altos
Stephan Smith - Own Design
Nevellie Mattingly - Own Design
Friedholm Schiborr - Own Design
Bene van Leeuen - Bommel IV
Peter Keim - Chaimara
Willem van der Meulen - Kwibus
Paolo Casadel - Vagabound
Albert Saager - Own Design
Franco Givone - Own Design
Eugenio Pagliano - Vevi 75
Andre Gouverneur - Own Design
Next question . . .
What is a Brillant and how does it different from a Brilliant V??
Joe
Founder of the R/C Soaring History thread . . . .
Jul 24, 2017, 05:50 AM
Hi,
i have sent an emal to Eugenio, is sorry, no pictures ... but he found the design and a picture of rudder.
Regards
Massimo
www.f5j.it
https://www.facebook.com/F5JItalia/
Next question . . .
Joe
Jul 25, 2017, 12:02 AM
F3B and F3K
RetoF3X's Avatar
Hi Massimo
Thanks for contacting Mr. Pagliano! If he has more details to share, like the design goals, that would be very interesting.
Fascinating details, a double hingeline rudder. I wonder why each flap has two linkages (it appears they were not used as ailerons, as they are connected to a single flap servo)?
Best,
Reto
Jul 25, 2017, 01:19 PM
Mark LSF # 3792
Looks like the flap on the rudder is passive, interesting. Bet that took some fiddling to get right!
Jul 25, 2017, 01:50 PM
My guess is the two linkages were to increase stiffness of the surface. Maybe had a flutter problem with only one horn on such a long control surface.
Tom
Jul 25, 2017, 05:26 PM
Balsa breaks better
Thermaler's Avatar
Thank You Massimo, tell Eugenio Thank You for me.
Joe
Originally Posted by mverardi
Hi,
Regards
Massimo
www.f5j.it
Jul 25, 2017, 10:07 PM
Portsmouth & Malta
Cool design...
The outer surface is passive, but it's linkage is permanently attached to the right side of the fin. There by creating substantial camber when deflected either way.
Looks like the wing is set up for camber changing with the central servo. The plan shows a launch or landing camber of some 35 deg, as well as 8 deg of reflex.
Ballast loaded in the wing at cg.
With the wing spec'd for 2 different densities of expanded polystyrene too.
Really cool stuff!
What year was this model from? It may be an exciting candidate for Nostalgia.
Jul 27, 2017, 05:19 PM
Balsa breaks better
Thermaler's Avatar
Originally Posted by alexhallmalta
Really cool stuff!
Yes really cool but I believe the foam core wing rules it out for Nostalgia . . . ;>)
Joe
Oct 15, 2017, 12:22 AM
Everything's A Compromise
Larrikin's Avatar
Who remembers/received one of these?
David.
Oct 15, 2017, 12:32 AM
gliderguide's Avatar
Aussie Aussie Aussie!!!!
Oct 28, 2017, 01:30 AM
Dennis Everett's Avatar
I had one of the caps , couldnt find it , but found this ..
Discussion A Little History on Haiti‏ Kaw1000 Life, The Universe, and Politics 24 Feb 28, 2010 10:18 AM
Sold Hacker B20 18L+4:1 Planetary Gear Box. Own a little piece of R/C History! F7X Aircraft - Electric - Power Systems (FS/W) 2 Nov 28, 2009 05:37 PM
Discussion A Little Bit of History Indubitably Dynamic Soaring 6 Oct 01, 2009 11:07 AM
