Jungmeister - Aerobatics With a Teutonic Twist! - Page 9 - RC Groups
Oct 08, 2010, 11:42 PM
vonJaerschky's Avatar
Some good progress on the elevators. It looks like the scale hinging will work out quite slick. The CF hinge pin will not be permanently fixed until after the model is covered and painted. At that point, the pin will be inserted through a hole in the elevator tip and through the aluminum tube bearing and the ply hinge support arm thingees. Then a small patch to cover the hole in the tip and a bit of touch up paint, and it will be good to go. Tomorrow I hope to fix the tubes in place. But I'm short one length of aluminum tubing, so must go find or order one.
Oct 09, 2010, 12:56 AM
bwoollia's Avatar
That's awesome!
Latest blog entry: Crash Compilation
Oct 09, 2010, 10:04 AM
What? Awesome that I ran out of construction material and must now stop? You 3D helicopter flying guy, you. Fingers crossed that Flite Supply has some. I'm going to head out there later in the afternoon.
Oct 09, 2010, 11:30 AM
bwoollia's Avatar
I was there last night, looked like they had a selection. Picking up bits for the T-33.
Oct 09, 2010, 11:47 PM
Hey, this is actually going to work! The hinge is totally slop free and seems as strong as can be. At first I wasn't too sure this would be worth it, but this definitely adds to the scale "Wow Factor".
Oct 10, 2010, 01:37 AM
Balsa Lover
gupi's Avatar
Very cool!
Oct 10, 2010, 07:35 AM
Jungmeister 55
simano's Avatar
Looking great!!
Gerry.
Oct 10, 2010, 08:50 AM
PeteSchug's Avatar
Looks really great.
I would make sure I have dual rates on for takeoff just in case they are much more effective than you expect. I think they will react pretty normally since there are no reports that the Jungmeister was hard to fly, but it pays to be safe. Murphy is always watching for his chance!
Once again, LOOKS GREAT.
Pete
Oct 10, 2010, 08:58 AM
D-Rock's Avatar
That elevator detail is very slick, and the construction quality is very impressive, almost too pretty to cover .
D-Rock
Oct 10, 2010, 09:53 AM
youngun's Avatar
Will you make any plans, or maybe a kit of some kind available?
Last edited by youngun; Oct 10, 2010 at 11:16 AM. Reason: (sorry - got a bit carried away)
Oct 10, 2010, 10:09 AM
Originally Posted by PeteSchug
Looks really great.
Pete
Thanks Pete. Yes, I always set up some very conservative dual rates, just in case. I always program in a good amount of expo. too, just to keep things soft around the middle in case I find I have a tiger by the tail.
No, not likely! The vast majority of the construction is based on a set of plans drawn by somebody else, so I can't really re-sell them. I got the plans here, as well as the cowl.
Oct 11, 2010, 03:21 PM
A few photos with the tail group in place. Time for turkey now! (Canadian Thanksgiving today).
Oct 14, 2010, 11:01 PM
Onward and Upward
CatManDu's Avatar
Looks very nice, Von J,
Randy
Oct 15, 2010, 10:12 AM
Mike Smart's Avatar
Have you finished the turkey yet? I'm waiting for the next instalment
Oct 15, 2010, 11:03 AM
Yes, the turkey was great! I'm hoping to start the wing in a week or two. I'm also working on a tiny little Fokker D.VIII for indoor flying which has started up at our local gym, so I' like to keep moving on that; shouldn't take long. The Jungmeister doesn't need to fly until April some time, so I'm not in a huge rush.
I have found myself in a bit of a quandary now. I have chosen YR-PAX as a colour scheme, but it is of course one of the only two Bu-133B built, and there are slight differences between it an the C model. Mainly the headrest. So I may need to make some changes on the fuselage.
Question Tony Nijhuis 62 1/2 Mk 9 Spitfire With a Twist drifter_uk The Builders Workshop 2 Aug 21, 2010 10:31 PM
Question Tony Nijhuis 62 1/2 Mk 9 Spitfire With a Twist drifter_uk Electric Warbirds 0 Aug 11, 2010 03:24 AM
Video Toxic Toast F14 with a Maybz twist ksqm Electric Plane Talk 3 Aug 09, 2010 11:36 PM
Discussion RFM spinner with twist Paint Man High Performance 8 Aug 09, 2010 01:06 PM
Discussion Plane stuck in tree...with a twist 94'325is Electric Plane Talk 8 Jul 29, 2010 02:02 PM
