Sep 17, 2010, 06:01 PM
I Toast Planes
bakon's Avatar
Help!
Good Glue for EPP Foamies?
I just got my first foamie yesterday and I am starting to assemble it tonight but what kind of glue should i use, I have Gorrilla supper glue and elmers ultimate high performance glue. I tested the gorrilla glue and it held a lot longer and bonded faster and did not damge the EPP and that only took 10 minutes but the elmers glue has yet to bond. Any suggestions? And what should I use to make the hinges?
Bakon
Sep 17, 2010, 06:02 PM
#1 for EPP is Welders
Sep 17, 2010, 06:03 PM
I Toast Planes
bakon's Avatar
Thanks, Is that what I should use for hinges also?
Sep 17, 2010, 06:11 PM
still learning
aeroknot's Avatar
welders for epp,
LoctiteŽ makes a similar glue that works almost as well
welders hinges (search forum) by far the fastest epp hinge, very strong and durable - just smear a thin bead along the hinge joint and smooth to a very thin layer with a credit card, cardboard, etc. Can always reapply if too thin but smearing it too thin takes a lot of effort
gorilla glue (white) good for filling gaps as it foams, when dry is mildly pliable and foam and not stiff like the yellow gorilla glue -
gorilla glue misted with water to laminate
2nd lamination method - can also use 3m77 sprayed very very lightly from a distance on both sheets, wait several minutes to laminate
Sep 17, 2010, 06:14 PM
I Toast Planes
bakon's Avatar
Originally Posted by aeroknot
welders for epp,
My gorrilla glue is clear, should i still use it or should i run to the store for welders? I just want to use the gorrila glue for the body parts not the hinges. and is welders a fast cure?
Sep 17, 2010, 08:32 PM
I tested some butt joints on EPP with White Gorilla and didn't feel that it held nearly as well as Welders. The Welders is not a fast cure. It seems to set pretty well within an hour, but I usually give it a good day to fully cure.
Sep 17, 2010, 10:09 PM
Zen in the art of foam
djacob7's Avatar
On EPP I use a lot of hot melt glue and 15 minute epoxy too. Hot melt is the fastest but adds a bit more weight.
Sep 18, 2010, 12:45 AM
matyou's Avatar
I second the hot glue. Even though it adds a little weight its pretty flexible in the bonds it forms.
Sep 18, 2010, 04:11 AM
Good Better Best quest.
olmod's Avatar
If you are trying to glue to a moulded skin epp with gorilla , pin prick the surface plenty times that way you get a really good key.
Sep 18, 2010, 05:56 AM
welders for epp,
Ya the Loctite or Lepages as its sold in Cnaada makes a very similar product to the Welders - Stik N Seal
Sep 18, 2010, 06:38 AM
Foam Av8r
RogueTitan's Avatar
Isn't Amazing Goop and Welders about the same type of glue?
I use Amazing Goop on SPAD's
Sep 18, 2010, 11:16 AM
The Canadian version of Goop isn't the same from my use at least. Goop is thicker and doesn't seem to hold as well. Close but not the same, the Loctite/Lepage is much closer to Welders than Goop.
Sep 18, 2010, 06:00 PM
RJD1234's Avatar
Welders is about the best for EPP in my opinion. UHU works well too but is harder to find. I use epoxy for the wing spar.
Sep 18, 2010, 06:04 PM
I Toast Planes
bakon's Avatar
Will goop work for hinges?
Sep 18, 2010, 06:05 PM
I Toast Planes
bakon's Avatar
Will amazing goop work on hinges? on the back it says do not use on syrofoam but I have epp so does it work on that?
Discussion Best way to paint EPP profile foamies? JGAF 3D Foamies 5 Aug 22, 2010 10:06 PM
Discussion Glue for Foamies Bob Watson Foamies (Kits) 38 Feb 12, 2010 09:47 AM
Is Elmers glue good for EPP? Is white glue same as Elmers? duganderson Foamies (Kits) 4 Nov 26, 2003 08:16 AM
Gorrilla Glue-Is this PVA?Good for foamies? lensrc Foamies (Kits) 5 Jan 06, 2003 09:09 PM
Good "glue" & filler combined for foamies RD Blakeslee Foamies (Kits) 0 Jan 20, 2002 10:03 AM
