Sep 16, 2010, 09:50 AM
Hangar9 Blue Nose P51 Mustang with Benedini Soundsystem
Hello,
Iīm still happy, my P51 is waiting for the maiden.
I checked the thread about this Beauty ( thanks for the hints ) - only thing Iīm a bit worried about is the Take of Weight , around 13,5 Pounds.
CG is on the safe side ( 120 mm )
Setup is:
AXI 4316 with APC 17 x 10
Hyperion 6 cells 4000
Yeti SPIN 77 amps OPTO
Thrust around 10 Pounds
Hereīs a little Video , hope Youīll īlike it
Hangar 9 Blue Nose P51 Mustang with Sound (1 min 22 sec)
Itīs a Benedini Sound System with 2 Speakers, one in the Cowling, one in the middle of the Wing )
http://www.benedini.de/
Best Regards
Andy
Sep 16, 2010, 12:33 PM
paracanary's Avatar
Originally Posted by Spitty123
Hello,
Setup is:
http://www.youtube.com/watch?v=4VmttbilZac
Best Regards
Andy
I do not know how many watts you are pulling or the kv of the motor but I would bet that you have too much static thrust and not enough pitch speed for this plane. I would recommend that you have a pitch speed of at least 80 mph and be in the range of at least 1500 watts minimum. Maybe a apc 16X12 would be a good choice. Mine flies nicely on 8s at 1800 watts with a 16x10 with a pitch speed of 80 mph static and mine weighs in at 10.7 lbs.
Sep 16, 2010, 02:51 PM
3DHS Junkie
800mZero's Avatar
thats going to be overflowing handful at that weight---watch yourself and keep our spped high---did you do anything to reinforce the gear area?
Who's spitfire kit in the background?
Sep 17, 2010, 01:41 AM
Paracanary, yes, maybe the Pitch Speed is slightly to low, but with the Drivecalc.de Program I should have a Speed from around 60 Miles but a lot of thrust, if the bird will survive the Maiden I will check a higher Pitch , 16x12 sounds good for me.Thanks.
800mZero: the Spitty behind is a 1/6.5 from a Mick Reeves Kit, and yes , I will reinforce
the gear today...My Kit seems to be the latest of the first production run, everything looks okay.
Will keep You advised
Andy
Sep 18, 2010, 02:02 PM
paracanary's Avatar
Hi Spitty - Good luck on your maiden.
If you are going to fly it with your power system, I would suggest that you do very shallow climb out to altitude to avoid the snap. In your turns, do not bank the wings pasted 40 deg by using a lot of rudder. In other words flat turns. I would also start out with a little down trim in the elevator and have very little throw. If you are worried about too little throw then set up dual rates.
Good luck, keep us informed.
Sep 20, 2010, 02:45 AM
Paracanary, thanks for the nice wishes ! Yesterday I did the maiden, everything worked fine, nice scalespeed , but Youīll fell it in the sticks : itīs a high wingloaded , heavy little warbird.
I normally use a lot of elevator throw ( with a lot of expo ) but after reading the Threads
I reduced it to 19 mm Up. Thatīs to less, while landing with full flaps I did need full up elevator to get things right. And I will reduce the throw of the Flaps because Mustangs seem a bit critical, the elevator will come in the deadzone of the airstream ( sorry about my english ).But anyway , she sounds so nice in the Air and itīs really a
beautiful Mustang with her " Blue nose "
Try to post a video in a few days
regards
Andy
Sep 20, 2010, 04:34 AM
Ldm
Ldm
Ldm
Ldm's Avatar
NIce job Andy , , I did not know the system would be feasable on a plane this size but you did a great job , makes me think that on an esm 75" bird its very doable
Again great job
Sep 20, 2010, 07:14 AM
3DHS Junkie
800mZero's Avatar
Glad to hear it went well spitty!
Sep 20, 2010, 12:12 PM
i dont use it[img]/sig/31/smile.gif[/img]
Sep 23, 2010, 02:28 PM
Sunday I did the Maiden, I am still very happy , need some more up Elevator throw to avoid noseovers.
Regards
Spitty / Andy
Sep 23, 2010, 02:29 PM
Sorry,hereīs the Link 1 ( 4 Parts )
Hangar9 Blue Nose P51 Mustang with Benedini Soundsystem Maiden 1 (0 min 21 sec)
Sep 23, 2010, 03:54 PM
paracanary's Avatar
Wow, get videos. You make it look a lot lighter than 13.5 lbs. That flare on landing was perfect. You had me on pins and needles. Sound system sounds realistic
Sep 23, 2010, 09:46 PM
flmlm's Avatar
Very nice thanks for sharing.
Regards
Sep 23, 2010, 09:52 PM
Ldm
Ldm
Ldm
Ldm's Avatar
Now that is COOL !!! great job , really cool !
For Sale NIB Hangar 9 Blue Nose P-51 Mustang tmsn Aircraft - Electric - Airplanes (FS/W) 3 Feb 15, 2011 05:08 PM
For Sale H9 Blue Nose Mustang ARF w/electronics no motor $325 DbleX Aircraft - Fuel - Airplanes (FS/W) 1 Sep 04, 2010 11:43 AM
Sold Hangar 9 Blue Nose P-51 Mustang NIB tmsn Aircraft - Fuel - Airplanes (FS/W) 1 Sep 01, 2010 11:22 PM
For Sale Hangar9 P51 Mustang Retracts chris8105 Aircraft - Fuel - Airplanes (FS/W) 3 Jan 11, 2006 10:19 AM
Question Hangar9 P51 Mustang Maiden Flight chris8105 Fuel Warbirds 9 Dec 24, 2005 07:37 PM
