Feb 22, 2012, 03:22 PM
ZACATTACK's Avatar
Originally Posted by Michael Paxton
The dual output wires from the BEC Pro are because one servo connector is not rated above 5 amps.
Y'ing them together serves no purpose at all. You're down to one connector again.
Just use one and check to make sure you don't pull too many amps for that connector.
Totally agree...I use both leads plugged into my JR (R-921 RX)... it gives me peace of mind. Servos in a stall position can draw amps...On the ESC lead, I just use a 3" extension before the RX and disable the red wire on the extension,now if I want to program the ESC I simply disconnect the extension at ESC lead and program away..I have made the mistake of disabling the red wire directly at the ESC...never again..just use an extension..
Feb 22, 2012, 03:48 PM
That's what I'm trying to do but I'm out of space on my Rx. I'm going to have to Y the flaps and elevators to get everything else I want and have two power inputs from the BEC. Using a Y on the ESC lead allows me to provide power off one of the outputs of the BEC without tying up another slot just for power. I'm not using the internal BEC so all I need is a signal and ground.
Feb 22, 2012, 06:01 PM
Sponsored by Team de la Peņa
bdelapen's Avatar
Hi Mike,
You missed the point of my previous post, you don't have to give up any channels, your BEC leads will Y into any port, I prefer the first and the last port in my receiver, thus providing power to both ends of the bus.
I'll try to illustrate in a more procedural way. Lets say that the first port of your receiver is Aileron 1 (Yes, I'm a Futaba guy), the last port of your receiver is Flap 2 (port 8 in my example). You remove Aileron 1 from port 1and plug in a Y-Harness, plug Aileron 1 into one of the ends of the Y-Harness and plug one of your BEC leads into the other end of the Y-Harness. Now remove Flap 2 from port 8 and plug in a second Y-Harness there, plug Flap 2 into one of the ends of the 2nd Y-Harness and the second of your BEC leads into the other end of the 2nd Y-Harness.
Ultimate power distribution, all programability preserved!
One final comment (as stated above), you may choose to use your ESC/throttle port as one of the places to plug in a Y-Harness because this way you can clip the red lead on the end of the Y-Harness that receives the ESC lead and thus isolate the ESCs on-board BEC without having to either remove a pin or damage your ESC lead.
Hope this clears things up a little.
- Birger
Feb 22, 2012, 06:21 PM
evo101's Avatar
im not sure where the servo horns in the manual come from, im just using the stock HITEC servo horns they work fine
Originally Posted by bradenj
I ordered the stock servos called out in the manual and I was going to install but realized the the servo arms are diff then the one in the picture. do you have to buy these separate?
Feb 22, 2012, 06:24 PM
Mile High EDF
420flyboy's Avatar
It's them, just cut off the other tabs on the servo horn
Feb 22, 2012, 08:48 PM
Hey Ya'll!! Watch THIS!!
Michael Paxton's Avatar
You are correct. I missed this. It's a great idea!
Originally Posted by bdelapen
Hi Mike,
- Birger
Feb 22, 2012, 10:11 PM
Just started the build tonight
Feb 22, 2012, 10:19 PM
Mile High EDF
420flyboy's Avatar
Should go together nicely
Feb 22, 2012, 10:33 PM
bdelapen's Avatar
Just trying to help
Feb 22, 2012, 11:13 PM
Hit Me! Please!
jwjohnson's Avatar
Hi Mike,
- Birger
Good explanation Birger. That's what I was trying to say a page or so ago, but you did a better job of explaining it.
Feb 23, 2012, 05:51 PM
jamesbuckley's Avatar
Gary Thanks,
I have the motor, very nice and thanks for the mod. I'm green on the
electric r/c and was not even sure how the sink, fairing and motor lined up just yet.
got it now. they don't.
And i was thinking the same thing about the slot between the ducts where they meet.
I also have digital/audio temp and voltage sensors that I have built into my cockpit. if anything
gets to warm or to low i will know it before its too late.
Thanks Again.
Jim
Feb 23, 2012, 06:17 PM
efflux RC's Avatar
Originally Posted by jamesbuckley
Gary Thanks,
Thanks Again.
Jim
I don't use the motor fairing. If your looking at the fan from the out side of the jet (through the hatch with the jet inverted) align the heat sink with the open slot facing you. (apply a few dabs of epoxy to secure the heatsink to the motor)
Then slide a large piece of heat shrink tubing over all three motor wires, just long enough to poke through the thrust tube.
Form the wires so there is only one wire visible along the front-to-back axis, and shrink the tubing. It will stay in that shape and form a very unobrusive fairing for the wires.
Latest blog entry: Updated blog - Oct 2017
Feb 23, 2012, 06:20 PM
Tam,
That looks awesome, I am going to be horsing around with my setup for a while. I'm in no hurry to finish, I live in Michigan and its winter no-fly time..30 degrees and getting ready to snow again.
I have installed digital temp and voltage sensors in my cockpit, I am going to test all setups while waiting for summer to fly.
no hurry for me... let us know when they are done.
Thanks Again
Jim
Feb 23, 2012, 06:54 PM
Jim, could you post a picture of the sensors in the cockpit? Also, what make/brand are they?
Feb 23, 2012, 11:35 PM
Got Brushless?
Friedclutch's Avatar
There's no beer in the photo. Perhaps it is in your hand while taking the photo?
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 03:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Vendor Talk 0 Jan 24, 2009 10:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 08:39 PM
