Jun 16, 2011, 08:12 PM
More jets than a carburetor
skydve76's Avatar
Originally Posted by Tamjets
Just let you guys know.
I ran up the E-Flite fan for the customer. It was horrible sound and vibration.
So put the E-Flite rotor on my dynamic balance machine to find out how far off it is out of balance.
Wow....is was so out of balance and hope you guys take time to balancing it well if want to run high power.
I try to balance one and let see what the different it would make.
Nevermind, I found it, the TJ80
Jun 16, 2011, 08:53 PM
SoCal, Year Round Flying!
bmiller's Avatar
Originally Posted by ZACATTACK
Really..I thought it was rated for 6S?? Spent all that money upgrading to 8S for nothing!!??Get the proper stuff in there before dropping in 8S batteries Buddy!! Trust Me!! Maybe the Fan can hadle it but not the rest of those stock compenents! On 8S stock you better bring along marsh-mellows and weiners ..your gonna have a BBQ!! There's a video in here on a guy dropping in 8S into a stock-set-up..he fried the motor...I'll get the thread posting and edit it in here..
Let me clarify: The fan can handle 8S, not the stock motor.
Gary, got the struts, thanks for the fast service!
Jun 16, 2011, 08:59 PM
ZACATTACK's Avatar
Originally Posted by skydve76
210 pages akes longer than 30-40 minutes. I hate it when people say that.
Thats not all I said in the response Dude..Dont start bashing on me cause I try to help.. I hate that even more!!!
Jun 16, 2011, 09:06 PM
efflux RC's Avatar
Every one ive seen needed to be balanced
Latest blog entry: Updated blog - Oct 2017
Jun 16, 2011, 09:08 PM
bmiller's Avatar
Originally Posted by carguy1994ca
Looking back at the pic previously posted, the little cord gets pulled by the strut when the gear goes up and that closes the door ? So when up, the cord doesn't pull on the door, it appears loose ?
In the retracted position, The cord is under the strut, keeping the door shut. Cord is elastic so it's slightly stretched, keeping the door tightly shut.
Jun 16, 2011, 09:10 PM
Tamjets's Avatar
I don't think so.... I can hear the fan out of balance and sound very angry.
Only one that know how to balance will do it right.
Most just put it together and fly.
That why PNP unit are for. There is works to assemble and balance the rotor.
It took me 1/2 hour fine tuning on the balancing machine and I balance both plane for precission balance.
Static balance only can get to run O.K. That why I bought the dyanamic balancer for if in the business making fan and it the most valuable tool to have.
BTW,
Just ran it up and smooth as silk. As not noisy as before.
Jun 16, 2011, 09:12 PM
skydve76's Avatar
Maybe I mis understood but a lot of guys post "read the manual" type comments and I hate that, why even waste the time posting something like that, if you are going to pose maybe point people to the correct posts.
Do you have any links to relevant posts? That would help alot.
Sorry if it seems like I was attacking!
BTW guys I got the mn48s, after reading about them:
http://www.horizonhobby.com/Products...rodID=JSP20040
Hmm, should I get different servos?
Jun 16, 2011, 09:26 PM
Tamjets's Avatar
Dynamic Balance
Here is the sample of none balance rotor and finish balance rotor.
Look at the number both plane of the rotor and comparethe finish balance rotor.
Jun 16, 2011, 09:29 PM
skydve76's Avatar
So how much do you charge to balance on for me?
Jun 16, 2011, 09:34 PM
Tamjets's Avatar
Good question and had answer before.
My hour rate are $85 an hour during business hour.
Off peak hour $65.
So you get the figure what it cost to balance the rotor.
Jun 16, 2011, 09:37 PM
skydve76's Avatar
Off peak hour $65.
Cool. Thanks for the info.
Jun 16, 2011, 10:09 PM
tulz43's Avatar
Tam, there is going to be a custom motor made by Steve especially for the TJ80SE?? 9S or 10S . Maybe 2 weeks for completion Tam??
The motor not be a week or two.
Test motor we goes through good trial test before production was made.
Yes the design of the motor to be run from 8s-10s.
Depend how customers want to use the power.
8s around 2.2kw for light weight set up.
9s around 2.7kw is where we had been doing.
10s is for hot rod for speed freak.
The ICE HV120 custom made heat sink from us to kept the ESC cool and light.
TJ80SE is really special. A lot custom works to kept it light and right KV motor to be works in many different application.
Whom know what the future hold.
80mm size jets might be the ticket and I had the power plant can push to the limit.[/QUOTE]
Tam - any idea what the amps would be on the 8s setup with the se fan? I love my stock setup because I can get an easy 5 minutes of flight.
Jun 16, 2011, 10:25 PM
Tamjets's Avatar
Tam - any idea what the amps would be on the 8s setup with the se fan? I love my stock setup because I can get an easy 5 minutes of flight.[/QUOTE]
Here is the 9s set up I flew few days ago.
9s 3600mAh 3kw at 95A
With the special motor for TJ80SE.
8s should be 2.4kw around 70A-73A range.
Just imagine light weight 8s 3600mAh at 2.4kw will do. The flight time as good as this video or better.
This video pretty much easy on the throttle most of the flight and got over 6 minutes.
The other video pretty much mostly flying with more throttle and still do 4:30 average with a lot high speed run.
Habu 32 Tamjets TJ80SE (7 min 11 sec)
HABU 32 TJ80SE part 2.wmv (9 min 13 sec)
Jun 16, 2011, 10:37 PM
tulz43's Avatar
Thanks Tam - not sure what happened with the quotes but you answered my question!
Jun 17, 2011, 12:31 AM
skydve76's Avatar
Been reading in this thread, the size comparison between the foamy and the 32 got me down a bit, but I have a fly fly mig29 anf the 32 isnt much smaller at all.
Atually, the 32 isnt small, the foamy is huge! I think I will have to pick one up but for a 70 mm sized edf it will be slow, the airframe is too big.
Odd as well, the stabs are in diffrent spots...
Discussion Fiberglass Habu Airframe Calvin_220 Electric Ducted Fan Jet Talk 92 Nov 10, 2012 03:53 AM
Sold New in box Habu EDF PNP flyboy1945 Aircraft - Electric - Jets (FS/W) 2 Aug 01, 2010 08:24 PM
Discussion ESC very HOT - Sorry the discussion is moved to the Habu thread SalamSyed Foamy EDFs 0 Mar 20, 2010 11:15 PM
New Product New Fiberglass EDF Jets!!! Starfire + EDF Trainer nitroplanes Vendor Talk 0 Jan 24, 2009 10:58 AM
Discussion Baja SS Speculation and hopup thread. DaveESPI Large Scale Cars 3 Feb 03, 2008 08:39 PM
