Sometimes the gear can over flex and break the stop switch. Then the gear doesn't know when to stop and lock. I use to get parts from PW-RC but they are changing and not sure if parts are sold anymore.
I asked Tam via email what I should do about the gear slop, His response was:
"Put aluminum tape to the surface of the trunion where touch the retract. That will fill up the gap to stop the slop " And let me say he was right. That gear is so tight now without any signs of slop. |
The big habu32 and the little brother habu.more than 350 times in the air and both are as new!!!!next step the new habu 32x.
Those look nice. I just got to the party with a used stock 32. I have 8 flights so far and all have been wonderful.
Mine also fly with the stock set up and they fly very nice!!!
Running an 700-60-1865 on 8s in the JetFan. What settings should I use for the edge 100?
Castle - motor timing: "Normal" (5 degrees) PWM: 12 |
Did you put the aluminum tape on the part of trunion that is visibile when the gear is retracted? This way when it extends it would fill the gap? I'm trying to visualize the placement of the tape. Thanks... |
That is exactly what I did.
Another fix for metal trunion retracts is to dismantle the retract and place the trunion in a bench vice and carefully swedge the gap closer again. If you go a little too far, use a drill bit slightly oversize and knock it in edge ways. The slight natural memory in the metal will close it up a touch, that's why one size over works well.
I have restored several metal trunion retracts this way, good as new. It seems to be mostly retracts for large scale models that restore best. Smaller retracts usually have thread strip in the slide bar and that's a fix I haven't sorted out yet. |
With a jet fan 12s setup would a 120amp esc be enough or do you need to go to a 160amp?
Sent from my iPhone using Tapatalk |
The 1500 kv motor is listed, but I don't recommend it for 12s. The normal current limiting setting for the Castle Edge 120HV is 180A. The 160 HV will run cooler and more efficient, but it's very large. |
Latest blog entry: Updated blog - Oct 2017
What setup would I need to get 200mph?
I have an 8s setup that I bought a couple of years ago that i got the motor from you guys and it sustains 150mph maybe 160 (using gps speed off a sensor) I just snagged a rtf stock setup yellow 32x at a swap meet and was thinking of going bigger with this one. Sent from my iPhone using Tapatalk |
Thread Tools | |
Similar Threads | |||||
Discussion | Fiberglass Habu Airframe | Calvin_220 | Electric Ducted Fan Jet Talk | 92 | Nov 10, 2012 03:53 AM |
Sold | New in box Habu EDF PNP | flyboy1945 | Aircraft - Electric - Jets (FS/W) | 2 | Aug 01, 2010 08:24 PM |
Discussion | ESC very HOT - Sorry the discussion is moved to the Habu thread | SalamSyed | Foamy EDFs | 0 | Mar 20, 2010 11:15 PM |
New Product | New Fiberglass EDF Jets!!! Starfire + EDF Trainer | nitroplanes | Vendor Talk | 0 | Jan 24, 2009 10:58 AM |
Discussion | Baja SS Speculation and hopup thread. | DaveESPI | Large Scale Cars | 3 | Feb 03, 2008 08:39 PM |
