Sep 14, 2010, 09:07 PM
First to go over 106K feet
Crist Rigotti's Avatar
Spektrum DX7 and DragonLink
Here is how I installed my DragonLink to my DX7. If you decide to do this to your transmitter you do so at your own risk!
1) I removed my 1W 2.4ghz booster.
2) I then removed the battery.
3) I removed the 6 screws and opened up the case. I was carefull not to pull on the battery connector wires.
4) I located the 3 wires that needed to be used for the DL on the RF board. They were located on the lower left side.
5) I removed the 4 screws that hold the board to the case.
6) I removed the 3 pin connector from the circuit board.
7) I cut off the connector and installed my own 3 pin connector to the wires just removed from the board.
8) I installed a mating connector back on the board. This will be used when restoring back to 2.4Ghz. A 3 pin servo connector would work very well if you just cut the 3 wires and splice them into the wires. This will save you from desoldering/soldering a connector to the RF board.
9) I then installed the board using the 4 screws removed earlier.
10) I made up a 3 wire cable from a 26awg servo extension. This goes from the connector I just added to the 3 wires coming off the RF board to the input of the DragonLink.
11) I used some zip ties to run the cable out the side of the battery box in the rear case.
12) I removed the handle by removing the nuts that hold it to the back case.
13) I removed the clear button cover for the binding switch.
14) I closed up the transmitter cases and replaced the 6 screws.
15) I then used a 4 pin servo connector that would mate with the DragonLink input connector on the other end of the cable that was just installed.
16) I then used some pieces of 3M Dual Lock SJ4570 from DigiKey to attach the DragonLink to the back of the transmitter.
Sep 14, 2010, 09:16 PM
Balsa addict
Kev.au's Avatar
I like how you added the mating connector, makes it easy to swap back to 2.4ghz.
Good job.
Cheers, Kev.
Sep 14, 2010, 10:45 PM
teebok's Avatar
hello crist,
By adding the dragonlink to the DX7, will the DX7 no longer transmit in 2.4ghz thus allowing you to use a 2.4ghz video transmitter?
Sep 15, 2010, 12:17 AM
Fishie
Fishbone4u's Avatar
If there is no power or PPM signal to the RF board on the DX7 then nothing is being transmitted.
I added a switch to the power lead going to the RF board and a connector in the back to power up the Dragonlink.
So switch off - no 2.4 transmission
Switch on - 2.4 transmission
I wanted the option to switch quickly back and forth since I still use 2.4 for my helis and small foamies.
Nice clean job there Crist!
Originally Posted by teebok
hello crist,
Sep 15, 2010, 01:30 AM
Alcyon13's Avatar
Why did you stop to use the 2.4ghz + booster ?? Seems you had great results with it ?!
Sep 15, 2010, 07:26 AM
hello crist,
Yes. I disabled the RF board by connecting in the DL.
Sep 15, 2010, 07:29 AM
I got a great deal on a used DL. The booster works very well and is a good economical solution to getting a lot more range on with your DX7.
Oct 08, 2010, 10:42 AM
Kostas
kstmark's Avatar
Hello Crist. I've follow many from your posts. I have a x9303. They don't have modules and I don't want to open it to add or change anything. I've also a turnigy 9x for the flights by the sea. Do you think that it would be a good idea to try the booster to the turnigy 9x?
Oct 08, 2010, 11:08 AM
I have no idea because I don't know much about the Turnigy. I am currently flying a DL with a XP9303.
Oct 15, 2010, 01:24 PM
Bill0's Avatar
Is this doable through the trainer plug?
Oct 15, 2010, 02:13 PM
I'm not really sure, but I think so. When you plug into the trainer jack, the transmitter turns on even if you have the front switch off. Also the DX7 will still be transmitting 2.4.
Oct 15, 2010, 03:58 PM
Registered Loon
Blackrat's Avatar
i read that the Tx doesnt transmit when the trainer port is in use ?going to try this with my sim and see if it still works :-)
or that it transmits at a lower rate ?
Oct 15, 2010, 04:02 PM
Bill0's Avatar
Thanks, didn't really want to open it up, but...........................
Oct 15, 2010, 05:01 PM
14s 180mah should be enough...
IFLYOS's Avatar
When you plug into the trainer port, JR/Spectrum radios DO NOT power up the RF deck. They have been like this since way back in the day of the Century series of transmitters
So..if the DL module just needs PPM from the radio, then you can use the trainer jack without broadcasting a signal on 2.4, or 72, depending on what radio you have.
Tim
AG4RZ
Latest blog entry: Intro..a few years to late!
Oct 15, 2010, 05:06 PM
Tim
AG4RZ
Thanks Tim.
Discussion DragonLink UHF RC igorp FPV Talk 29 Aug 02, 2009 07:01 AM
Sold Spektrum DX7 w/AR7000 & Spektrum Case sdstick Aircraft - General - Radio Equipment (FS/W) 4 Jun 14, 2009 10:30 PM
Found Will trade Spektrum DX7 w/AR7000 receiver and Spektrum Case for a Revo 3.3 sdstick Cars - Trucks and Parts (FS/W) 0 Jun 14, 2009 05:37 PM
Sold Spektrum DX7 (heli version) + AR6100 + Spektrum neck strap + neck strap adapter generalbacardi Aircraft - General - Radio Equipment (FS/W) 4 Dec 15, 2008 07:42 PM
Sold SPEKTRUM 7 Channel Air DX7 Radio w/Spektrum Case Randy -- Aircraft - General - Radio Equipment (FS/W) 17 Apr 06, 2008 12:10 AM
