Mar 05, 2019, 11:55 AM
serjuro's Avatar
https://photos.app.goo.gl/qgGrJYtHPg7kLyx18
Mar 08, 2019, 04:29 PM
Build, crash...repeat
AleRRon's Avatar
Serjuro
I suspect it was just bad luck launching. I've had that happen quite a few times and had to figure out how to hand launch it. I rev up the motor to half throttle or so, and then try to launch it slightly upward, making sure it's not banked to one side, using a gentle push; not too much. Also check your control surfaces again to make sure they're moving correctly and make sure the CG is right. I bet it'll fly when you try again!
Mar 09, 2019, 02:25 AM
serjuro's Avatar
Thanks AleRRon for support ! I dont know if the maiden launch could be seen on the link attached by me. I was on rc and one guy throw it . I was on 60% gas, ready to compensate but it nosed down in an instant.... Cg was right but the guy throwned it weirdly....like he did not let go at the top of the arc and kinda late....resulting in a crash....It broke in half. Now I ve glued 4 spruce spars, 2 on thr upper deck and 2 on the lower deck along thr nose....Maybe the 3s2200mah lipo is too heavy and needs more power to launch...I ve added down thrust to the motor, upped the elevon reflex to 10mm.....I wil try again if the rain lets me... Cheers
Mar 09, 2019, 07:12 AM
I Look, Listen, and Learn
Timbo383's Avatar
Serjuro, also hold the plane vertical "safely" and see if you are getting enough pull at 60 to 70 percent throttle. If the battery is too heavy then the plane will be wanting to drop to the ground instead of pushing gently upwards. You don't need to be vertically taking off but it shouldn't drop like a rock either. The biggest problem is you say the cg is correct, so I'm assuming you need all that weight up front to balance it. So the only solution may be a more powerful motor.
Mar 09, 2019, 08:07 AM
serjuro's Avatar
Exactly, I had to push the lipo into the canard spar....Maybe i ll buy a 2400kv motor with a 3s1600mah lipo...Thanks
Jul 29, 2019, 02:26 AM
serjuro's Avatar
Hi again, I"ve build another PrimeJet .... Maiden was OK ...
PrimeJet depron maiden(2) (1 min 18 sec)
Jul 31, 2019, 01:45 PM
skumgummi dave
Looks good in the air! Thanks for the video.
Dave-
Aug 03, 2019, 04:34 PM
Careful,.. confident,.. CRASH!
Dukejet's Avatar
Beautiful PJ. Love the color scheme
That prop sounds like it's very unbalanced or was on backwards.....
You've probably already fix it...
Flew great, balanced perfectly.
Aug 26, 2019, 11:05 AM
57sailplane's Avatar
Oh I think I need one of these. What is the fastest set up so far?
Aug 28, 2019, 04:32 PM
Ken's CAD Models
dz1sfb's Avatar
I've gone 117 mph with mine with a Propdrive 28-36 3000Kv with a 4.75 X 4.75 APC modulated by a Turnigy AE-65 esc with a 2200 mAh 4s battery. That's the 32" version.
Ken
Sep 11, 2019, 11:13 PM
Dukejet's Avatar
Wow guys this will be fun to watch......
Watch "Reno Air Races? - X Project Jet Update - Top Gun 2 the People??" on YouTube
Reno Air Races? - X Project Jet Update - Top Gun 2 the People?? (12 min 27 sec)
Oct 24, 2019, 01:48 PM
You're Killing Me Smalls
Ken
It looks like Hobbyking discontinued that motor.
Does anyone have any other recommended motors for a 3-4S setup?
Alot of the motor recommendations I see on here are for 3S max.
Or is using a 3S motor on 4S not a big deal.
Jay
Jay
Oct 28, 2019, 01:41 PM
It seemed like a good idea!!!!
Hookit's Avatar
Jay
Jay
These look great but I have no personal experience of them but have seen siblings of these motors used at my club.
https://uk-m.banggood.com/T-motor-F6...ottom-alsolike
But I have tried these (also in green) and for the money a really potent motor on 3S or 4S.
https://uk-m.banggood.com/Racerstar-...rmmds=myorders
Certainly the sort of thing I would put on a PJ when I get around to building one.
Jan 12, 2020, 12:33 PM
SpeedJet plan? Which PDF was used?
Originally Posted by gcok
One version of this fast bird:
https://youtu.be/TFVWvAgbVgs
Hi
Hi Gorazd
I loved your version of the PRIME JET8 mini funjet clone! Which plan did you follow from the PDFs lised on the first page of this build log?
I look forwarf to hearing from you.
Simon
Jan 14, 2020, 10:24 PM
XDmToter's Avatar
Jay
Jay
Hello Jay,
Sorry I'm late to the party here... I've heard good things about the GepRC GR2306 2750KV motor on 4S. They are about $20 if you can handle waiting for the shipping from China. Once in a while I see them on eBay from a US seller for a bit more $$.
https://usa.banggood.com/Geprc-GR230...p-1240972.html
Check out E3Scott's series of videos on this motor.
T-Motor T5150x3 prop GepRC GR2306 2750 kv motor on 4S (5 min 54 sec)
Here is a playlist of all his videos on the GepRC GR2306 2750KV:
https://www.youtube.com/watch?v=jI-1m_B9y-8&list=PLKu3yFqYM98mnGcvLqpHQPTYrRXbq6dug
I think this motor might be a good fit for Ken's scaled up 32" model:
https://www.rcgroups.com/forums/show...postcount=1188
Build Log A Mini funjet - type thing ( full fuse ) Prime_8 Scratchbuilt Indoor and Micro Models 168 Nov 18, 2010 02:37 PM
Discussion Prime Cut + 20 KevinSheen Giant Scale Airplanes 1 Jul 27, 2010 07:48 AM
Discussion Yet another Funjet FPV hakuna FPV Talk 0 Jun 02, 2010 10:15 PM
Discussion Another FPV Funjet JohnyGab FPV Talk 21 Jul 30, 2009 10:17 AM
To prime...or not to prime Simon_au Slope 12 Dec 18, 2004 09:04 PM
