Which wires go where?
Hey guys. I have a question for all you electronical geniuses out there.
On the Big Dog I have two JJC sound units for the "gas turbine " engines. Now in order for them to be proportional to the speed they have to be plugged into the throttle slot in the Rx. Now the ESC has to be plugged into the throttle slot too. The sound units have white,red and black wires and the ESC has dark brown,red and light brown wires. (It's a Proboat ESC) So the question is which wire colors on the ESC match the wire colors on the sound unit? If ya need a picture I'l post one. Pete |
I am not familiar w/ Proboat, Norgale.
Best way is to Look to battery pack plug in line with servo if it takes one. Center is red and is always positive, Traditionally lightest wire is signal wire Dark brown or black are usually negatives Nobody every makes contacts like the old Airtronics anymore with everything reversed Here is nice reference for everything else: \http://www.repairfaq.org/filipg/RC/F_Servos.html |
On your JJC unit green plug, the two connections on the left are for the speaker and the two on the right are for the battery power.
Ok thanks guys. I don't have any "Y" harnesses that have the right plug for my new 2.4 Rx so I'll have to solder the wires together. Only prob with that is the ESc will have to stay in that boat.
I wish all these stupid electronics companies would get together and standardize their plugs. I have four kinds of wires and none of them will fit each other. I'll be damned if I'll spend one more penny on any more of this crapola electronics. I'll just make my own and the hell with those jerks. And ya want to know why the American model maker won't support American model mfgs. This is one good reason. Pete |
Can you show a picture? It may simply be the tab that some connectors have, and you can just cut that off.
If you have any left over dead Rx chargers, or charging switches, you can cut the female plug off and then make your own Y-harness. That is what I just did for my 47' MLB. |
Here are a couple of pictures of the wires I'm talking about. They all have to plug into the throttle slot on the Rx so I thought I would solder them all together with one plug. I will try and make a double "Y" harness before I do that though. That would be more gooder. Ha! Pete
Yeah, you have all male servo plugs. You need two female plugs to make a y-harness. You can often find the female plugs on wall wart chargers, Rx switch and charging cables too. Or you can buy them but I know that is your least desirable option right now.
Remember if you let the smoke out of the wires you did something wrong.
From the photos it looks like you have futaba and hightec connectors . Like Grumptom said the wires are just a differant color. Just cut the extra tab off the side and it will all go together. |
Thread Tools | |
Similar Threads | |||||
Question | Which wires do you switch to change servo direction? | Flyextreme | Radios | 10 | Aug 29, 2010 02:42 AM |
Help! | Bandai - Where do these wires go? | DragonAX | Car Talk | 2 | Feb 01, 2005 09:36 PM |
What wires go where (CC25 to Brushless motor) | Leafy | Electric Power Systems | 5 | Nov 05, 2004 11:23 PM | |
"HELP Please which wires go where on new PJS Motor | KOMET 44 | Electric Power Systems | 4 | May 30, 2003 01:26 PM | |
Help! Servo lead tore loose from ESC, where do these wires go?? | All__talk | Electric Plane Talk | 4 | May 09, 2002 07:51 PM |
