eCalc: Questions & Answers for propCalc, fanCalc, heliCalc - RC Groups
Sep 06, 2010, 04:18 PM
get your drive right...!
FAQ
Hello RC Pilots!
I have been asked by a few Pilots here to start a Q&A thread for the purpose of answering your questions about eCalc and there usage....
If you have any questions by using propCalc, fanCalc or heliCalc I ask you first to contact the Help-Page of the corresponding Calulator (upper right corner). If you do not find the answer I'll try my best to support you. for this I need your exact setup:
- Batteries (incl. dicharge rate)
- ESC
- Motor & Gearing
- Propellertype and -dimensions
- your Elevation
I will not make any suggestions setting-up a specific rc model - sorry.
cheers
Markus Mueller
Sep 23, 2010, 11:43 AM
New Version 5.00
Hi,
the new eCalc Version 5.00 is with immediate effect available.
What's new?
- a new model to extrapolate no-load current at higher voltage resulting in a even more accurate Efficiency.
- Introduction of the Battery Charge State (full, normal, low) for a better comparability with own measurements, as own measurements are mostly done with fully charged batteries resulting in shorterm higher values.
- the most restricting component limit are now shown in the graphics
- graphics problem with Internet Explorer 9 is now solved.
cheers markus
Sep 23, 2010, 01:35 PM
Fourdan's Avatar
Hi Markus
Very good and serious job
Congratulations
When I will have time, I would like to compare with Scorpion Calc (regarding Scorpion motors, of course)
Louis
Oct 26, 2010, 01:45 AM
New Version 5.10
Hi,
the new eCalc Version 5.10 is with immediate effect available.
what's new?
what's new?
- propCalc does consider twisted yokes when choosing a folding prop typ (remember: when using a none stadard length yoke to adjust the prop diameter!)
- the numbers associated with a warning message will be highlighted in red font color
- wrong decimal entries (, instead of .) will be converted automaticly
- Service Update: warning for exessive Blade Tip Speed (> MACH .85)
cheers markus
Found Canopy for Dreamline / Fly-Q / Omega hp.singh Aircraft - Sailplanes (FS/W) 4 Sep 05, 2010 06:41 PM
Help! improving FanCalc eJets Electric Ducted Fan Jet Talk 6 Sep 04, 2010 01:17 PM
Discussion Newbie Q's for FPV s_mack FPV Talk 15 Aug 15, 2010 05:43 PM
motorcalc Q STREETRAT Power Systems 2 Nov 22, 2005 08:35 PM
ecalc values for eclipse? hmpecker Electric Plane Talk 0 May 01, 2001 08:08 PM
