Jun 09, 2004, 07:27 PM
Got CAD ?
PLANE FREAK's Avatar
Copied your JIG
Here is my version of the JIG built by Balsastaub.
Formers will be cut out with tabs on the bottom for correct height placement.
Jun 09, 2004, 07:35 PM
Got CAD ?
JIG closeup
Closeup of the front of the JIG.
Balsastaub is this how you did yours ?
Jun 10, 2004, 02:16 AM
Balsastaub's Avatar
Exactly
Jun 10, 2004, 03:41 AM
Professional Goofball
OCModels's Avatar
Hey Plane Freak?
What is the plan on the wall behind your jig??? Is that a Tucano?
-Jeff
Jun 12, 2004, 08:14 AM
Hmmm. Did something go terribly wrong on the maiden? I'd really like to see some pictures or at least some information on how the maiden was... Such a pretty bird, but what happened to her?
Jun 13, 2004, 10:39 AM
Hey Guy's
Just wondering how you are covering the fuselage, are you using all 10mm planks or sheeting some? Also wouldn't the two radiator cowels make a lot of extra drag?
Jun 14, 2004, 12:10 AM
[QUOTE=PLANE FREAK]Closeup of the front of the JIG.
QUOTE]
Are those uprights just butt glued to the base? Is that aliphatic or hot melt?
Jun 15, 2004, 08:45 PM
Got CAD ?
Building the Spitfire Mk.IX
georgeg
"Are those uprights just butt glued to the base? Is that aliphatic or hot melt?"
Yes they are butt glued with yellow carpenters glue. That way the JIG can be torn apart and used for another model.
OCModels
"What is the plan on the wall behind your jig??? Is that a Tucano?"
! ! ! BUSTED ! ! ! It is a Nigel Hawes Tucano for speed 400
Here are the updated pictures.
Jun 15, 2004, 08:57 PM
Got CAD ?
The drawing on the wall is one I traced from a set of plans my friend has.
It is for a 0.90 powered Mk.IX and is very similar to the DXF plans we are all building from.
I finally got my light plywood so I can start cutting.
Jun 15, 2004, 09:05 PM
Got CAD ?
F3 and F6b glued to the two F11 pieces.
The two F12 parts glued to F2, F3 and F4.
Jun 15, 2004, 09:11 PM
Got CAD ?
Here we can see the clamps that hold everything straight while the glue sets.
Jun 15, 2004, 09:13 PM
Got CAD ?
All glue joints are medium CA without using kicker for maximum strength.
Jun 15, 2004, 09:15 PM
Got CAD ?
Keep it straight and square.
Jun 15, 2004, 09:18 PM
Got CAD ?
Front view showing the tabs that were added to the bottom of each former to maintain the correct height. Tab size is from the side view in the CAD file.
Jun 15, 2004, 09:22 PM
Got CAD ?
F10 glued to F5 and F6b.
Note the addition of servo rails that are not in the plan.
