There is a gyro thread here on RCG did you know?
https://www.rcgroups.com/forums/show....php?t=1035605 I have used before: One gyro, Y cable, 2 servos 2 servos on 2 different channels with flapperons and 1 gyro connected to one of the servos. 2 servos on 2 different channels with flapperons, 2 gyros one on each servo. Gain wires connected via Y harness to Gear channel for control When it gets really windy, I won't be flying the glider but I will fly a 30 something inch foamie with 3 gyros. I pretty much use Rate mode only for wind stabilization on aileron or rudder help on take off. |
Thats a good read Melnic. I will be testing the single gyro on flapperon setup this weekend I think, although i am tempted to put it on elevator to control sink rate rather than stabilisation. I have a tendancy to let it dive for longer/faster than intended when i'm flying FPV, plus if i am understanding it correctly, it will factor a bit of trim difference (power on vs power off) out of it
If I could find my head lock gyro, i would throw that on too, but its buried in the parts drawer. |
Messing around with a keychain camera today.
You can see how effective the spoilerons are upon landing, just sets ya right down.
Received my new wings with only slight damage to the tips
They have added C/F to the ailerons back near the hinge, I think it's for hinge reinforcement, they will still need the strips on the trailing edge. Kerry EDIT: The C/F may be there because the servos are mounted at about 1/3 out on the aileron. Previously I had V1 wings and installed the servos at the mid point on the aileron. |
Helitime, when my wings pitch, would it be worth adding any strength to the ailerons, or are the OK stock?
Also, guys. I am new to gliders... but to reduce adverse yaw, which I believe is more apparent in gliders than shorter winged planes, I believe 'differential' is used. Would that be recommended? And am I right in saying that all that is, is to limit the down throw on the ailerons. So, a hard right hand bank would result in the left aileron going full down, and the right aileron maybe a few degrees up, but not full up? And how would this be effected by using 'spoilethons' to reduce landing speed? When I flick that switch, both ailerons would go up maybe 50% throw? And then when I try bank the same way (hard right hand bank), the left aileron would maybe go flat, leaving the right one up? |
Hi Cralis: Not quite on the differential. The up aileron is on the inside of the turn where you want more drag to help turn the plane. Diff. ailerons reduce the down throw on the outside of the turn, so less drag, creating less adverse yaw. Spoileron/flaperon will still work as will the ailerons when spoilerons are engaged.
Your example "a hard right bank" would have the right ail. full up and the left ail. partially down. You can also mix in a little rudder in the same direction as the turn to reduce adverse yaw. Adding C/F to the ailerons will make them much more effective. Stock is fine for crusing around (rolls are very slow) but if you want to fly aerobatics they need to be stiffer. P.S. No mater what your skill level is you will want to fly aerobatics with this plane just cuz it flys so easy Hope this helps Kerry>>>> I'm goin flyin for the REST of the day. |
OK, my plane is somewhere between somewhere in China, and the HK warehouse in Hong Kong. From there it will be shipped to me here in Australia. Soooo... not expecting it for a while.
In the mean time, I am playing with my radio (Futaba 9C), and the idea of Spoilerons is appealing. However, I don't see the option on my radio. I have the option for Flaperon, but no Spoileron. Could someone maybe guide me though how I would use this, and at the same time, make use of aileron differential to assist with the adverse yaw story.... But I am bamboozelled. So, any assistance would be amazing. I have just realised that this isn't a FOX related question though... so, maybe I should start a new thread elswhere? |
Yeah Cralis, everyone is correct. Spoilerons are flaperons, it's just the way you set them up with travel that alters it.
To set spoilerons, select flaperons mix. When tour adjusting the mix for the travel of the flaps, just set it up so they go up instead of down. That's spoilerons. Sounds more technical than it is |
Thanks all!
On my Futaba 9C, I see that I have each aileron with a % value... So I will change those.. However, I can either activate, or deactive the mix. I can't seem to assign a switch or slider/knob to Flaperons.... I was thinking I would select a switch as a flap switch, and then assign that to the 'flaperons/spolierons'. I'll have to hunt down how to deploy them... Unless it's somehow linked to my throttle? How throttle deploys them? I'll hunt about. |
Nah mate, not linked to throttle. You'll have to assign the switch on that remote. Page 70 of the manual. Here's the link to the instructions
http://manuals.hobbico.com/fut/9c-manual-v1_2.pdf |
Thread Tools | |
Similar Threads | |||||
Mini-Review | FOX ST-Model /Kyosho /Hype /Ripmax 1.8m /71" EPO PnP/RTF BL/ Glider | McMoron | Electric Sailplanes | 428 | Dec 03, 2015 02:43 AM |
New Product | HobbyKing Minimoa 2mtr R/C Glider EPO w/ Motor, ESC, Servos Plug-n-Fly | Bowerz | Electric Sailplanes | 8 | Jul 29, 2015 09:28 AM |
Discussion | HobbyKing 3D 30" EPO Yak 54 | Bowerz | 3D Foamies | 39 | May 06, 2011 11:39 PM |
Sold | WindRider Fox EPP Glider $60 + Shipping | ShoGinn | Aircraft - Sailplanes (FS/W) | 1 | Aug 23, 2010 09:21 PM |
Discussion | St model fox glider | Staudacher600 | Electric Sailplanes | 2 | Aug 04, 2010 10:42 PM |
