Aug 16, 2010, 08:52 AM
What happened to printer ink???
Ok, I copied a portion of some plans yesterday and went to iron on the transfer to the balsa. Uh... no transfer. WTH? I couldn't even get it to go with a solvent.
Aug 16, 2010, 11:34 AM
The transfer technique does not work with ink from an inkjet printer. It may work when you have a copy produced by a Xerox machine. The Xerox-type copier uses graphite which in turn, transfers to the balsa when you apply heat (or a solvent).
Alan
Aug 16, 2010, 01:20 PM
Laser printer or photocopies generally work great.
I've never known an inkjet image that has worked properly...they take a lot of trouble to keep the images fixed and these days they really are fixed .
Steve
Aug 22, 2010, 05:52 AM
Will fly for food
Laser printers/copiers use a plastic toner powder that is heated to melt into the image.
So ironing or solvent (that melts plastic) will soften the image and allow transfer.
Ink jet inks are water or alcohol based and dry like paint. If printed on the proper material, they will transfer. Use the material in the make your own T-shirt transfer kits.
Question what happened to epoxy? ariesmars The Builders Workshop 10 Aug 02, 2010 11:44 PM
Discussion What happened to Tuff Planes? Miami Mike Slope Soaring 1 Jul 27, 2010 01:10 AM
Discussion What does a printer have in common with a 250 class? ziomatrixacs Mini Helis 8 Apr 11, 2010 03:41 AM
Discussion Decal paper for ink jet printer? Marty C... Australia 14 May 06, 2006 05:58 AM
Idea Decals with Ink Jet Printer Mesnik Foamies (Kits) 0 Mar 21, 2004 03:10 PM
