How to convert Server Power Supplies - Page 10 - RC Groups
This thread is privately moderated by jj604, who may elect to delete unwanted replies.
May 20, 2016, 12:01 AM
EMERSON - CISCO N55-PAC-750W 25+10 pins
https://www.rcgroups.com/forums/show...05&postcount=6
May 20, 2016, 05:47 AM
Artesyn Model 7000758 - 0000 REV: A
https://www.rcgroups.com/forums/show...16&postcount=7
Jun 03, 2016, 08:00 PM
ancora imparo
jj604's Avatar
Complete instructions for a dual HP DPS-1200
This is the best detailed "How-to" on making a 24V supply from the very popular DPS-1200 supplies I have come across. Extremely detailed step by step instructions with clear photos. Very nicely done.
http://studio939.blogspot.com.au/201...ystem-for.html
Jun 05, 2016, 05:54 PM
ancora imparo
jj604's Avatar
Backplane connectors
If you prefer to connect to a server power supply with the correct mating connector rather than directly solder to the power and control pins, Digikey have a comprehensive range of them.
They are listed under "Backplane Connectors - Specialized" and it looks like some of the more common connectors are the Amphenol PwrBlade series.
You can browse and look for a matching one and check if it is correct by downloading a pdf of the specification sheet. The link for PwrBlade connectors is:
http://www.digikey.com/product-searc...=0&pageSize=25
There are lots of other brands and the Digikey site has a useful filtering system that can narrow the search.
Big thanks to irun4fundotca who alerted me to this.
Jun 27, 2016, 03:41 PM
http://studio939.blogspot.com.au/201...-portable.html
Updated my blog post to address a couple of errors, and messed it up a bit. . . the system changed the URL, so I thought I'd post the updated one.
http://studio939.blogspot.com/2016/0...ystem-for.html
Jun 30, 2016, 06:04 PM
Compaq DPS-600 CB A in series
https://www.rcgroups.com/forums/show....php?t=2693128
Jul 08, 2016, 06:45 AM
Astec AA23340 (Cisco Catalyst 6500) Voltage adjustment
Hi, To increase voltage output from 40v-47.5. I have carried out this mod on several units and works well. Attatched photos shows fitting of a 39k resistor on top panel.
Jul 24, 2016, 04:57 PM
ancora imparo
jj604's Avatar
Excellent "How-to" for twin DPS 800gb
This post has an excellent series of clear pictures showing the build of a twin 24V HP DPS 800gb setup.
https://www.rcgroups.com/forums/show...&postcount=205
Aug 02, 2016, 06:34 PM
ancora imparo
jj604's Avatar
DPS-600PB OVP disable
Lets a DPS-600 voltage go to 14.5V
https://www.rcgroups.com/forums/show...postcount=3611
Aug 10, 2016, 07:26 AM
ancora imparo
jj604's Avatar
Dell dps-800jb
Short thread with solution
https://www.rcgroups.com/forums/show....php?t=1772308
Aug 22, 2016, 05:19 PM
ancora imparo
jj604's Avatar
Ready made solutions
These PS are popular with Bitcoin miners and others as well as modellers and a number of ready made solutions have appeared. There are a number of established vendors selling supplies already converted and ready to go.
In addition however there are also a couple of connection units ready to plug into the very popular DPS-1200 and DPS-800 powers supplies for people who don't want to do any soldering or modding. RCGroups member vimy g eaou has confirmed that these units are of excellent quality.
http://www.buttsimpleideas.com
His eBay shop is here.
http://stores.ebay.com/Butt-Simple-Ideas
Sep 15, 2016, 05:24 PM
ancora imparo
jj604's Avatar
Dell A930p power supply from Power Edge 2900
Update to post #129.
The thread now includes a full pinout description of the supply as well as instructions to get it working.
https://www.rcgroups.com/forums/show....php?t=1810512
Oct 03, 2016, 09:04 AM
HSPalm's Avatar
Ds760sl-3
The DS760SL-3 is a slim and very silent server power supply. I picked it up for $10 at Wierd Stuff Warehouse in Palo Alto.
The fan start intermittently only when you reach about 300-400W output in a 20 degrees C room.
Buy it from digikey if you have lots of money: http://www.digikey.com/product-detai...434-ND/2486047
Datasheet here:
https://www.artesyn.com/power/assets...1456937282.pdf
From the datasheet you read that both PSON and PSKILL must be pulled low for the PSU to operate the +12vdc output. I did that, and then (and only then) did the +12vdc output turn on. Please see attached screenshots and pictures of the specifics.
Oct 15, 2016, 09:29 AM
FlopSter
IBM x3650 M2 Type 7947 AcBel FS7023
AcBel FS7023 pulled from an IBM x3650 M2 Type 7947
T1 T2 T3 T4 T5 T6 T7 T8 12V+
B1 B2 B3 B4 B5 B6 B7 B8 GROUND
Jump T1-T2 (T1 is ground).
Temporary jumping B8 to T1/T2 makes the fan speed go to 100%, disconnecting it afterwards the fan settles back down.
Seems to work just fine.
Oct 15, 2016, 09:20 PM
ancora imparo
jj604's Avatar
DL580 & HP "Common Slot" pinout
Details of the pinout of the PSU connector slots for this series of supplies are linked in this post.
https://www.rcgroups.com/forums/show...postcount=3653
How to make own Power supply at home? convert from PC power supply? HumbleBoss Batteries and Chargers 16 May 01, 2016 02:13 PM
Discussion Convert Server Power Supply mt_100 DIY Electronics 28 Aug 19, 2010 01:03 PM
Discussion Help how to convert to Electric PT-20 Great Planes anteka Glow to Electric Conversions 1 Jul 25, 2010 11:07 AM
