Sep 14, 2020, 08:55 PM
How far back on the wing is the balancing point
Sep 15, 2020, 08:56 AM
Jack
jackerbes's Avatar
The location varies a little and is affected by the size and location of the battery and other components. But you can often use the battery location as a the thing that determines the final location of the CG.
And if you did not know it, nose heavy is much less dangerous and easier to fly is than tail heavy. This location explains it all:
https://rcplanes.online/cg_calc.htm
And the image is my home made device for setting a CG, just move stuff around until the plane sets level or with the nose slightly lower than the tail and you should be safe for a first flight. If you use the elevator to trim a plane out for a level glide and land and see it has a little up elevator with the control centered, then it means that it was nose heavy and the elevator trim is pressing the tail down and holding the nose up for level flight. So if you move some weight weight or add some weight towards the tail (not the nose as I said originally) the up elevator trim will lessen.
Jack
Sep 15, 2020, 02:23 PM
IMO ( In My Opinion ) →
balsa or carbon's Avatar
Start at 25% of root chord and then adjust forward/rearward for optimal flight .
Sep 27, 2020, 07:37 PM
Sonex Builder and Flyer
Building a 24"
After building and crashing a couple of Flite Test airplanes I searched for something that would most likely give me some success. I'm building a 24" version of Russ's great design. I'm building it as light as possible. It's built with Wal-Mart's Ross foamboard with the paper removed. Going with a single step kfm2 airfoil. Here are a few photos of my progress. By the way, my first scratch built airplane was a full scale Sonex with an 85HP VW conversion engine.
Sep 27, 2020, 08:02 PM
Let us know if you have success with this build ...... if not , I have some suggestions for you .
Sep 27, 2020, 09:56 PM
Thanks. I will let you know if this build works for me.
Sep 28, 2020, 03:22 PM
apburner's Avatar
Originally Posted by potshot
I had somewhere mentioned to Russ40 that this drawing was scaled to 75%. My bad. It is actually 2/3 original size, which makes the original 6mm foam become 4mm. I had figured on using 3mm Depron for everything except the tail group, for which I might use some 5mm Cellfoam I have laying around. I guess a 3mm tail group would be OK for indoor, which is where I will most likely fly mine.
If your still on here Potshot I am wondering if Dollar tree foam would work well for your 66% plane. I have lots of that and no depron. Lol thanks.
Oct 12, 2020, 01:08 PM
Slow Flight
Same question..6mm depron to 4.5mm DT foam may require some reinnforcement. I do not know the impact on wing load.
I wait for that answer.
For Sale New Type of Trainer rorrock Aircraft - Fuel - Airplanes (FS/W) 5 May 04, 2010 08:05 PM
Question Indoor "plane"- type plane?? sidecar53 Scratchbuilt Indoor and Micro Models 1 Oct 04, 2009 01:28 PM
Wanted New or Used Electric Trainer type plane........... mtdoramike Aircraft - Electric - Airplanes (FS/W) 3 Mar 06, 2007 06:38 PM
Micro trainer type plane? docprego Electric Plane Talk 13 Sep 26, 2005 12:54 PM
t-ifo's the best trainer type plane flyinjim Beginner Training Area (Aircraft-Electric) 4 May 27, 2002 07:52 PM
