1.2-1.3Ghz Tx/Rx All infos on one page - updated: 27/10/2013 - Page 361 - RC Groups
May 15, 2018, 01:40 PM
Anyone know why my fatshark 1.3ghz goggle module v2 only gives any usable range on channels,1280,1258,?? and really good on 1360mhz -over 5km on just homemade omnis!
The other channels are really crapp 1080,1120,1160,1200, 1320, all give around 200meters! Its as though fatshark have 'doctored' those channels to be unusable?? really strange and annoying too as I want to use ch1080. Any thoughts?
May 15, 2018, 01:59 PM
Originally Posted by Daemon
Most Yagi designs I've seen do not use even spacing between the directors, but
get progressively wider spaced as you go out the beam, so I
would have been immediately suspicious of your old one.
That said I've also seen ebay Yagis that clearly have random spacing between directors
indicating they pretty much just hand drilled a bunch of holes in the beam and stuck
the directors in to make it *look* like a Yagi.
Thanks Daemon. The old Yagi got me 41km out in range so I know it works, but maybe these other Yagi antennas will do even better based on the test results
May 15, 2018, 02:32 PM
400' ..... NOT
Martin Y's Avatar
Do not use 1080 at all Please. Too close to air traffic ADS-B signals of 1090.
Latest blog entry: 1280mhz vs 1090mhz
May 15, 2018, 06:24 PM
sdigrazia1's Avatar
V2 had an issue with range, mine is V3 but around the 5:30 mark he talks about it....
Fat Shark 1G3 RX Version 3 (FSV2443)Testing (7 min 0 sec)
May 16, 2018, 01:53 AM
Thanks for that but mine is the v3-2443.
Yesterday, 03:33 PM
NutBag's Avatar
Hi All,
After trying pretty much every CP option out there I’m looking to start testing some linear setups.
Anyone know where to get decent quality High gain 1.2G Yagis?
There’s not much avail out there.
Cheers,
Chris.
Latest blog entry: Build Pics
Yesterday, 11:09 PM
Originally Posted by NutBag
Hi All,
Cheers,
Chris.
There is an overseas supplier who calls himself the Antenna Master. He builds very high quality Yagi antennas.
He builds them custom-made, based on how many elements you want and the exactly frequency you want it tuned to.
I am in fact about to place a second order with him. If you want, I can add your request to this order, or I can send you his contact info. Shoot me a PM either way if you are interested.
Regarding gain, 12 elements will for example get you 14.9 dB gain, and 19 elements will get you 17.1 dB gain.
I have personally tried his 10 and 19 element Yagis and they vastly outperformed my old 10 element Yagi. See my earlier post, #5398.
Also keep in mind the 19 element Yagi is definitely nice performance-wise but it is quite long. Just make sure you have a sufficiently rigid tripod if you go that route.
Personally, I noticed that even the 10 element Yagi is highly capable.
You can tell he tunes them very well, in the attached photo you can see that for the 19 element Yagi, it has a VSWR of 1.05 at 1280, and just a few Mhz over at 1271 it is a VSWR of 1.40.
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 04:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
