Jun 13, 2011, 04:01 PM
Originally Posted by msev
So it still stands that a 2s lipo would be good? Nontheless I'll have to bench test it to see... Do I have to cool the vtx with some fan if I do bench testing?
It sounds like the answer may be "Lawmate needs full 12 volts, others probably work down to 8 volts or a little lower". I would use this for advice, but test my system to make sure.
A good rule to follow is that if the vtx is too hot to hold firmly (don't flex the case by squeezing too tight) in your hand then you should power down and supply more cooling before powering back up.
Security video transmitters have an extruded aluminum heatsink case and are designed to work without a fan. FPVer's usually take the heavy heatsink case off, mount them on the outside of the aircraft so the breeze can cool then, and then need to make sure they stay cool if run without air flow for an extended time.
On the one hand, there are reports of fried transmitters (high powered versions of some brands) from a few minutes of ground operation. On the other hand, you will have less of a problem in cold winter weather and some stuff doesn't get destructively hot, but better safe than sorry.
Cliff
Jun 13, 2011, 04:09 PM
Originally Posted by idletime
Ok, I have to ask what might otherwise be a stupid question (but I know questions aren't stupid....only answers can be stupid )
Why is no-one using their standard tx (DX8 for example) with better antenna's - tracker / diversity - all that stuff at 2.4Ghz??
Use what you have to start with. Don't use 2.4g video with 2.4g RC or 1.2x video without an antenna filter with 2.4g rc. "Park flyer" systems (short range RC) will get you in trouble because you will want to fly farther than you can.
Other than that, do whatever line of sight ground range tests you can with your the video transmitter switched on and before flying the first time.
When flying farther than you have done before, shield the transmitter a little and if you get a lock out, unshield, fly back and use that for your max range (which can differ from day to day).
I would give this advice regardless of what frequency your RC and video is.
Cliff
Jun 14, 2011, 05:07 PM
VisionLeon
a heve one of this from hobbyking and is not working any more , i use mine 3 months and when i conetc to a new eagle tree system stop working , and a try again whit 200mw and burn too
Jun 16, 2011, 05:53 PM
Still broken after you disconnect from Eagle Tree?
Is the power correct (voltage and plus/minus) with new Eagle Tree wiring?
Cliff
Jun 17, 2011, 08:56 AM
What are freq, of Sunsky 1.2Ghz 800mw aka Fox-800
Jun 17, 2011, 09:02 AM
https://www.rcgroups.com/forums/show...8&d=1261432777
Jun 17, 2011, 09:20 AM
Thanks HF ATL
Jun 18, 2011, 03:33 AM
Hi,
I need serious reviews of the Systems sold on 1.2Ghz by Hobbyking to add to the first page.
Jun 18, 2011, 03:39 AM
Originally Posted by iacei
Hi,
HK is selling 1.2Ghz systems now??
Jun 18, 2011, 03:44 AM
You can't take the sky from me
Rastislavko's Avatar
AFAIK there are no 1.2GHz systems sold by HobbyKing.
Jun 18, 2011, 03:59 AM
Indeed
Jun 18, 2011, 02:59 PM
Up up and away!
FpvKiwi's Avatar
Originally Posted by FpvKiwi
I opened up my VRx, thinking the RSSI wire might pick up RF noise. But look.. the crystal is RUSTY! It's not older than 6 months. I don't know if it degrades image quality but I'm certainly not comfortable with it. The crystal on my other VRx reads "F4.000" so I'll replace it with a new 4MHz crystal. Thoughts?
I replaced my rusty crystal with a new 4 MHz one. The VRx still works so it's the correct frequency.
Now to proceed to replace the SAW filter.
Jun 28, 2011, 04:09 PM
imdone's Avatar
answered.
Jul 03, 2011, 05:47 PM
The way of being is doing.
IMEIV's Avatar
Hi,
someone has actually measured the real power output from the Sunsky 1,2ghz 800mW ?
Jul 03, 2011, 05:58 PM
Daemon's Avatar
Originally Posted by IMEIV
Hi,
It varies but last I heard it was measured at about 500mW on ch9 (1280Mhz).
I've been out 6 miles with Vee on the FOX800 Tx and 8dB patch on the Rx and
could have gone further. It's more than enough power for 99% of the FPV pilots here.
ian
Discussion Lawmate vs BOB Fox 700 Tx/rx combo which one has the 1160? iacei FPV Talk 24 Jul 22, 2010 08:49 AM
Discussion 1.2Ghz Tx Only: Where to buy a cheap one iacei FPV Talk 9 Jun 07, 2010 02:03 AM
Question esc all one, can i change to different tx/rx? Fossy313 Beginner Training Area (Aircraft-Electric) 4 Jan 30, 2010 05:07 AM
Discussion 1.2Ghz 800mw video TX/RX on Ebay for $2.98 Euro _Spud_ FPV Talk 1 May 23, 2008 12:31 PM
Are 1.2ghz Tx and Rx any good. JustFly Aerial Photography 3 Apr 22, 2005 11:46 AM
