Jul 16, 2010, 10:14 AM
Help!
Future Hobbies 1.3 GHz Tx - voltage level and channel selection
Hello!
I recently bought a 1.3 GHz Tx/Rx set from Future Hobbies.
http://www.futurehobbies.com/products/details/210/25/transmitter-&-receiver-sets/1-3ghz-transmitter-&-receivers-sets/500mw-rx/-tx-set-[1-3ghz]
Seems like a good set, got a rubber duck antenna with the Tx.
But I have two problems:
There was no documentation following the set, and therefore I have no idea how to change channels on the Tx or what voltage it requires! - I tried looking at the help pages on FH, but I could only find wire diagrams, no specs.
In the picture in the link there seems to be some kind of plug attached to the pins next to the antenna connector on the Tx, but I didn't recieve anything like that.
I know the Rx uses 12V, but I'm afraid that the Tx uses 5V.
(I think it uses 12v, but I wont connect it to anything until I'm sure about it ).
Is there anyone here who knows the voltage requirements of and how to change channels on the Future Hobbies 1.3 GHz 500 mW transmitter?
Jul 16, 2010, 11:38 AM
bump
Jul 16, 2010, 11:50 AM
That is the same as Bestofferbuy.com 700mw FOX transceiver.
http://www.bestofferbuy.com/av-wirel...o-p-15758.html
But there is one different, you paid twice
OOHHH , Ifound you did not get the power adapter too, the BOB FOX system comes with two switching 12V power adapter+ better quality antenna+ usermanual
Here is the user-manual
https://www.rcgroups.com/forums/show...9&postcount=17
and here is the thread with help full information
https://www.rcgroups.com/forums/show....php?t=1162250
Jul 16, 2010, 11:55 AM
Thanks alot!
Jul 16, 2010, 12:00 PM
Will it work on a 3S 11.1V Li-Po?
Jul 16, 2010, 12:15 PM
Thats what you need, it will work great with a 3S 11.1V.
The transmitter is very low noise sensitive, I mean normally must use an separated battery for video TX but this one you can use the same battery that you are using for your brushless power system.
Its recommended to use the balance port of battery to power up the TX.
Jul 16, 2010, 12:17 PM
Thank you, finally I can start soldering up!
What du you mean by connecting to the balance port? - How would I do that?
But I use a seperate battery anyways!
Jul 16, 2010, 12:23 PM
If you are using a single battery then you can make a connector like that one use on balance charger and connect the video system to the balance charge port of battery.
If you are using separated batt then no need to connect the balance connector.
Jul 16, 2010, 12:45 PM
too bad they couldn't include a harnes, like Range Video does..
But thanks for your help!
I'll let you know if it works!
Closing thread.
Discussion Connecting a tx in 2.4 ghz to a Rx in 1.2 ghz catamar FPV Talk 1 Dec 29, 2010 04:30 PM
Discussion Damaged Future Hobbies Tx danops FPV Talk 1 Mar 01, 2010 01:04 AM
Discussion Future scale 1:3.33 Schweizer 1-26E (SGS 1-26E) kit Harry v. Melick Scale Sailplanes 0 Dec 28, 2009 03:17 AM
Discussion Can I get a future hobbies TX to work with Hobbywireless? Gun Jam FPV Talk 8 Nov 25, 2009 02:23 AM
Discussion Future Hobbies 1-watt RE-1000 2.4 gHz kit For Sale (minus camera) SOLD replayreb FPV Talk 6 May 28, 2007 11:49 AM
