Jul 13, 2010, 04:50 AM
How do i bind a new rx to a dx6i without bind plug
Just as the title says, I have brought a new rx for a new model and i dont have the plug for it, when i got my radio it was with a heli that was sent away to be built and i didn't get a bind plug then either.
if there is no way to do it how do i make a bind plug as i don't want to wait for one to be shipped.
thanks
kim
Jul 13, 2010, 05:43 AM
Surface, Air & Water Rc Toys..
If you have old servo leads or old servo extensions you can use these, strip and twist the 2 outer wires on the 3 wire lead and short them together.
The bind plug shorts the outer 2 pins on the BATT/BND port.
If you have a helping hand you can also use small needles nose pliers you can use them to short the 2 outer pins.
Jul 13, 2010, 11:14 AM
awesome, thank you
Jul 13, 2010, 12:46 PM
AMA #953123
VROOMSTER's Avatar
Freechip is correct.
Jul 13, 2010, 01:02 PM
i've done it, thanks you guys
now the plane is built i just have to see if i can fly it
kim
Jul 13, 2010, 02:11 PM
AMA #953123
VROOMSTER's Avatar
Good luck on the first flight!
Discussion How do you tell the diff. b/w Failure to bind(Rx can't Connect) and Loss of bind? Fly2High Radios 40 Jul 11, 2018 09:07 PM
Discussion Can I bind my DX6i to a HBK2 without AR6200? daewon774 Mini Helis 3 Jul 09, 2010 08:38 PM
Sold Dx6i and Spektrum AR6100e w/Bind Plug- *OBO* NEEDS TO SELL - Pictures Attached Draven Aircraft - General - Radio Equipment (FS/W) 3 Sep 21, 2009 06:50 AM
Sold Like New DX6i with original packaging, NiMh batteries, charger, and bind plug Craig9080 Aircraft - General - Radio Equipment (FS/W) 4 Aug 21, 2008 11:22 PM
Found Spectrum dx6 with manualls, bind plug, RX or without RX hamcigar Aircraft - General - Radio Equipment (FS/W) 7 Feb 26, 2008 10:11 PM
