Jul 11, 2010, 03:00 PM
WAPilot
Hangar 9 12v HD Starter / Starter Source
As described in the subject, I went and bought a Hangar 9, 12v PowerPro HD Starter, and it's associated, attachable, Starter Source. The Starter Source comes with a 12v 1.3Ah gel cell, to power the Starter.
After charging it overnight, the battery was at 13.5 volts. The wallcharger showed the charge cycle was completed.
However, when I put it all together and tried to turn over my Alpha's .40 motor it couldn't turn the prop over even a single revolution. It seems to be way under powered.
Am starting to realize that 1.3Ah might be pretty weak, but why would Hangar 9 pair this together if their Starter combo can't even turn over their Trainer's engine?
Any thoughts? Should I get a different Starter combo?
My desire is to get away from carrying a motorcycle/lawn tractor battery. Everything else I have (remote glow plug igniter, manual fuel pump, etc.) has been purchased with this in mind.
Jul 12, 2010, 08:27 AM
WAPilot
Bump
Jul 12, 2010, 01:06 PM
Arceenut's Avatar
Try starting the motor with the starter by first turning the prop backwards by hand to the point of compression to give the starter and engine a bit of a running start before it hits compression. The inertia will help the starter get the engine past the first compression stroke.
I use a similar setup but the starter is powered with 12 C sized NiCd cells. It will start a 120 without any problem.
Jul 12, 2010, 02:50 PM
WAPilot
Thanks. Good suggestion about pushing the prop back a bit.
Btw, do I understand correctly. Are there 12 C size batteries in that NiCd pack, equating to 1.5v each or 18v total?
Jul 12, 2010, 03:15 PM
Arceenut's Avatar
That is correct. !8 volt will spin the starter over quite smartly and will start my 120FS and 130FS twin with no trouble. I have been using this setup for several years with NO problems, the starter will handle the 18 volts easily as it is run for only a few seconds at a time. The other advantage of the NiCds is the fact that they can supply a much higher current than the lead acid type (much lower internal resistance) so there is less voltage drop under load.
Jul 13, 2010, 01:02 AM
EloyM's Avatar
NiCd cells are rated at 1.25 volts each - 12 of them will provide 15, not 18 volts. Just after charge, NiCds in good condition will read over 1.3 volt per cell, especially if teted withou a load. However, this excess will bleed off in a few seconds under the heavy load that a starter will place on them. They will then hold a steady 1.25 for the remainder of their useful charge life.
Jul 13, 2010, 07:31 AM
WAPilot
Thanks about letting my know the voltage in the NiCd being at a steady 1.25v. I also found out that the stock Hangar 9 NiCd pack comes wire 10 to a series (the pack made for this starter).
Holding at 1.25v for 10 still gives me only 12.5v unfortunately.
Sold Hangar 9 12v starter moosemanty Aircraft - General - Miscellaneous (FS/W) 1 Apr 13, 2010 04:18 PM
Question Anyone tried the H-9 PowerPro HD starter? FuntanaS Engines 3 Oct 17, 2009 07:03 PM
Discussion Webbie HD camera mounted to Hangar 9 Piper Cub Matt Gunn FPV Talk 22 Sep 08, 2009 05:47 PM
For Sale Hangar 9 12v Batteries (NIB) BD Flyer Aircraft - Electric - Batteries & Chargers (FS/W) 3 Jan 28, 2008 09:14 PM
