Jul 05, 2010, 01:20 PM
recep
recep's Avatar
Build Log
FPV plane with a built up wing
Plane will look something like this. Wing span 190 cm, root chord 36cm, tip chod 33cm . Aimed weight around 1.5 kg (52 ounces) up to 2 is OK.
Jul 05, 2010, 01:25 PM
recep
recep's Avatar
Shear webbing the key to strength
Jul 05, 2010, 01:27 PM
recep
recep's Avatar
Joiner box construction. Joiner will be 6mm carbon rod.
Jul 05, 2010, 01:31 PM
recep
recep's Avatar
Matching the ailerons with the wing.
Jul 05, 2010, 01:35 PM
recep
recep's Avatar
As I used the tite bond for bonding the d box sheeting, I first applied the glue then wait till it dries and reactivate it by heating. No need for weights on the sheeting.
Jul 05, 2010, 01:38 PM
recep
recep's Avatar
Tip panels are nearly done. Center is on the way.
Jul 05, 2010, 02:48 PM
ashdec87's Avatar
nice looking good.
Jul 05, 2010, 02:59 PM
Praying for better weather
Coyote64's Avatar
Looks an interesting build, looking god
Jul 05, 2010, 03:09 PM
Wow! Building things from scratch out of balsa.... A soon to be forgotten art!
Especially in this forum's section...
I admire you since I have lost my patience and luxury of having so much free time long ago.
Keep on posting photos from you build!
Dimitris
Jul 05, 2010, 05:54 PM
recep
recep's Avatar
Thanks , I hope I will finish it in a month maybe a little more. Talking about time the worst part is cutting out the ribs. Video is actually speed up of 6 minutes and one of the 26 ribs.
(0 min 46 sec)
Jul 07, 2010, 06:37 PM
recep
recep's Avatar
More on center panel
middle section is 2mm plywood.
Jul 07, 2010, 06:44 PM
recep
recep's Avatar
This is how I prepare the shearwebs. First a shallow cut with a balsa stripper to mark the height then go deep with a razor saw
Jul 07, 2010, 06:47 PM
recep
recep's Avatar
A little dihedral on tips. And a few steps left for center panel.
Jul 08, 2010, 07:51 AM
Videopilot
Derek_S's Avatar
Looks good. Love scratch jobs.
Sold Ray Hayes Osprey 2m kit glass fuse, built up wing $120 shipped USPS CONUS be69ar Aircraft - Sailplanes (FS/W) 8 Jun 23, 2010 12:32 PM
Discussion fpv in built up areas mark the shark FPV Talk 4 May 30, 2010 05:33 PM
Discussion Advice for lights in built up wing RMac Night Flying 3 Apr 02, 2010 06:23 PM
Discussion Scratch built FPV Plane 3 daveyedgar Foamies (Scratchbuilt) 0 Jan 09, 2010 08:02 PM
Discussion Scratch built FPV plane project part 2 daveyedgar FPV Aircraft 0 Dec 31, 2009 02:07 PM
