Jul 05, 2010, 12:24 AM
joy4u's Avatar
help me activating 7th and the 8th channel after the assan hack on FUTABA 6 channel
I have a FUTABA T6EXHP 35Mhz transmitter...
Which is a heli 6 channel TX
I want to convert the transmitter to 2.4Ghz with assan hack module...
Plz give me ideas on how can a put two more switch for using the 7th and the 8th channel...
Jul 12, 2010, 04:35 PM
We want... Information!
Bruce Abbott's Avatar
I added two extra channels to a Hitec Laser4 using a PIC12F615 MPU. The PIC reads in the PPM pulse stream, then generates two extra pulses at the end to produce the new channels. 2 potentiometers are used to provide proportional control of the extra channels, however you can use 2 or 3 position switches instead.
The circuit requires a positive going logic-level PPM pulse stream. In the Laser4 I picked up the signal directly from the transmitter's encoder chip.
The attached zip archive includes assembler source code, and the Hex file (for 6 channel transmitters) for loading into the PIC.
Jul 29, 2010, 08:05 AM
Aircraft re-kitter
ergocentric's Avatar
Thanks! I was looking to max out my Fut7c 72/2.4 switchable hack.
If you make the mistake of plugging a servo in to CH8 it will strip the gears with a HobbyKing 8CH rx.
This should be just the ticket.
Jul 29, 2010, 08:33 AM
joy4u's Avatar
I cant get you...
Can you plz elaborate and say...???
Jul 30, 2010, 12:39 PM
Aircraft re-kitter
With HobbyKing/Flysky 2.4GHz sets, if you plug in a servo to an untransmitted channel the servo will turn, all the way, and beyind the mechanical stop inside the servo. That is what strips the gears.
i.e. eight channel receiver, seven channel transmitter -> channel eight will damage your servo
Dec 21, 2017, 11:32 PM
hi bruce
i have tx guanli 72mhz 4ch. can i adding more channel using that circuit?
thank you for answer
Discussion Futaba T6EXA Assan Hack navionflyer Radios 61 Jan 23, 2012 11:06 AM
Fly-In WINGS OVER CHINO,CA: Scale Fun Fly Nov.7th & 8th T1Callahan Fuel Power Events 0 Oct 14, 2009 05:46 PM
Discussion Assan hack module versus Spektrum Dx6I wolf081 Radios 2 Oct 12, 2009 06:06 AM
Discussion Need help converting Futaba 6XAs to Assan X8D Hack mlanepa44 Radios 2 May 25, 2009 01:22 AM
Help! help me get some 7th & 8th graders into RC jzanutto Electric Plane Talk 11 Apr 19, 2008 01:03 PM
