Jul 04, 2010, 08:01 PM
AZ Outback
Robert Burson's Avatar
X5J July 10th/11th Sign-up
Welcome back for a seventh year to X5J eXtreme.
Contest Schedule for 2010
Aug 28th/29th
Sept 11th/12th
Oct 23rd/24th
To enter, please post to this thread your ship and power train information, before the days of the contest. During the day of the contest post your scores.
You may fly any or all of the classes below. In general, all classes use flight time - motor time and up to 30 points for landing.
The goal has been to minimize the rules to stress a Unlimited nature for these events, so everyone with an electric sailplane will have an airframe and motor that will meet the rule requirements.
New rules for X5J eXtreme 2010
TASK: Fly three 10minutes rounds using only thermal updrafts with an electric motor powered sailplane.
X5J eXtreme UNLIMITED rules:
1. Any airframe, motor, battery, ESC, and prop maybe used.
2. Flight time has motor run time subtracted from it.
3. 30point landing tape, in 1 meter increments worth 3pts/m
X5J eXtreme SOR rules:
1. Any airframe, battery, ESC, prop, motor with 28mm diameter and 17mm
magnet bell length or less.
3. 30 point landing tape, in 1 meter increments worth 3 pts/m.
X5J eXtreme AMERICA
1. Any motor, prop, ESC, 2.0kg or greater airframe, four A123batteries,
X5J Energy Limited, if you would like to try this format, calculate your total allowed motor time by
using the following formula: 12000/______watts = motor time in seconds. All the rules are still the
same you just do not exceed the calculated motor time for any round. Also if using this format list
your score with the letters EL (i.e. 1723EL)
General Rules:
1. Any part of the airframe maybe used to determine max. landing points.
2. Round motor and flight times to closest second.
3. Motor must be running at launch.
4. Each second of flight time is one point, seconds greater than 10minutes are subtracted.
5. First and additional motor runs, one point per second, loss of landing points on second motor run.
Hope you can joins us for the fun.
The Best Soaring
Robert
Jul 05, 2010, 05:29 AM
ohmite's Avatar
Hello Robert,
I hope to make it this time. I will be flying my HiAspect again, Hacker B40/9L+4.4:1+15x10+3SXP3600. Let's hope the planets align and allow me to get my flights off.
Best Regards,
-Eric
Jul 05, 2010, 06:10 AM
turn, turn, turn.
I'm in again with my Voltz and Hitec equipped Topas S and New 1509 1D, Jeti opt 77, PQ 2200 45C 3s lipo, RFM 16x17 prop, JR 770 rx, and 1500 Sanyo rx. battery.
Jul 05, 2010, 12:06 PM
I will be able to fly in the July event. As usual, I'll fly an Art Hobby e-sailplane in the range from 1.9 - 2.5 M. I'll most likely fly my 2M Andromeda, unless it is very windy. All of these planes have a direct-drive, brushless inrunner power system driven by a 3S lipo pack, and thus come-in under the “unlimited” category.
FF
Jul 05, 2010, 08:56 PM
Luis Moya's Avatar
In
AVA Flaped
Neu 1506/1.5D 6.7:1
3S Hyperion
CC 125
Aeronaut CAM 16 x 10
Luis
Jul 06, 2010, 04:04 PM
jawarejj's Avatar
Concentrated in the Soccer team but we still have time to fly...
Hello Robert,
I'm in (my friends will be sending me their details):
* Pulsar 3200 Vtail
* MVVS 4.6 Sport 840kv
* 13x8 or 14x8 propeller (still deciding)
* 2650mAH 35C Turnigy
* ESC 70Amps
Max Amps: 35A
Weight: 1580grs
You can see her here:
* Fernando Gordon: Easy Glider, 10x6, 3s, Motor TR35-36C
* Eduardo San JosÚ: Pulsar 3200 - MVVS 4.6 840 Sport - 13x8 - 3500mAH, 35c 3S
* Alberto Abad:Astra - Hyperion - 9x6- 3S
* Julio Contreras: Astra - Hyperion - 9x6- 3S
* Francisco Hernandez: Dragonfly - 4s - 15x10
Jul 08, 2010, 06:21 AM
AZ Outback
In with Trio Plettenberg F5b 10 7:1gb 2s neu 5000 and to be determined prop. Will fly with Mike and Don. Looks like great weather for the weekend, hope everyone has the same.
The Best
Robert
Jul 08, 2010, 02:32 PM
Robert,
Count me in: AH Castor, motor Axi2814/10 = the "unlimited" class
Jan
Jul 09, 2010, 07:04 PM
If it's not windy, Ill fly my O.D.#11. ws 120", 60 oz, AXI 2820/8+4/33, 18.5X12 PROP,
2500 4S.
Jul 10, 2010, 05:20 AM
Here are my scores:
1. 9:59, motor 20 second (2x), no landing points = 579
2. 9:56, motor 23 (1x), no landing points = 573
3. 9:59, motor 31 (2x), no landing points = 568
Total 1720 points
I did fly the AH Castor, motor Axi 2814/10, prop 9.5x5, 2S2200, 180 W, 1100 grams. As they forecast 35 ░C for today I went to the field early. With this low power setup I tried to start directly into thermals that were, however, weak and shortlasting. In the first and third flight I had to restart, in the second one I did not make it back to the point - about 12 m.
So, my worst score in X5J this year but much more fun than to shoot up into 300 m and then fall down (however, I would never even try this approach at the "assembly" contest ).
Thanks Robert for the opportunity to fly,
Jan
Jul 10, 2010, 03:59 PM
Hard to find lift today. It sure looked like a good day for soaring, but it was not.
here are a few photos of Bob's Trio.
Jul 10, 2010, 05:40 PM
turn, turn, turn.
Originally Posted by DingoII
Here are my scores:
Total 1720 points
Jan
Leaving the door open for us Jan!....All we have to do is make the 1800 or above!
Jul 10, 2010, 05:51 PM
Here are my scores for the July 2010 X5J Unlimited:
Flight 1: 600 - 17 (motor run) + 27 (landing) = 610
Flight 2: 600 - 2 sec (over time) - 17 (motor run) + 30 (landing) = 611
Flight 3: 600 - 29 (motor run) + 0 (landing) = 571
TOTAL POINTS: 1,792
Some details for those interested:
Plane: Art Hobby Andromeda 2 M (SD7080 wing). Mega 16/15/5 direct drive to a 9 x 5 prop powered by a 3S 1800 lipo pack. AUW 25.4 oz (720 g).
Flights occurred earlier today (Saturday) between 11:30 and 12:45. Weather: 6 mph (10 kph) N/NE, 83 F (28 C), mostly clear. A nice day for July.
Flight 1: Made time using careful flying and three fairly weak thermals.
Flights 2: Hit decent lift early, and made time easily.
Flight 3: After a couple of minutes, the entire reachable sky turned to light-
moderate sink, and that was that for landing points!
Best to all,
FF
Jul 10, 2010, 05:56 PM
That was also my experience down here in my corner of Indiana. Looked good all afternoon, but decent lift was sparse. Still, I did see a few very high-flying vultures, so there was apparently big lift out there somewhere....
Jul 10, 2010, 06:45 PM
turn, turn, turn.
Nice job FF....real close to the 1800 threshold!
It may hold up.
Yippee! 2010 UK AP Meeting - 10th and 11th July. chargenut SCRAPS (Southern Counties Radio-control Aerial Photographers) 142 May 22, 2010 08:55 AM
Discussion X5j eXtreme Oct. 10th/ 11th Sign up Robert Burson Electric Sailplanes 35 Oct 13, 2009 03:08 PM
Contest X5J eXtreme April 11th and 12th Sign Up Robert Burson Electric Sailplanes 39 May 15, 2009 07:33 PM
Discussion X5J eXtreme Oct. 11th/12th Sign-UP New 1.5M class X5J Robert Burson Electric Sailplanes 37 Nov 01, 2008 08:15 AM
F5J USA VI extreme Sign-up July 10th/11th Robert Burson Electric Sailplanes 112 Jul 21, 2004 12:25 AM
