I wish I could recall what battery lead I used, but with the larger gage wire, overall performance in both main and tail was improved. Slight opening of the holes in the board was required..... that's how much bigger the wire was. I'll look those up next chance I get.
I thought about trying to use a NCPx BL kit on the tail awhile back, but never followed through on it. Motor Kv is much higher... would have to use smaller tail rotor to get away with it. I may try again after I finish the projects I have going right now.
Anyhow, the reason I asked about a BL main motor in a 120 SR / 120 S is that my 120 SR w/ CX2 Jet Ranger fuselage conversion requires a 1250ma 1S in the nose to get the C/G correct, but the added weight only gives me a few minutes of useable flight time. It is rock-solid though, with the longer tail. |
I wonder if a MCPX-BL power system would work...... or maybe another of similar size heli? |
The MCPX BL conversion motors that I have are much smaller than a Brushed 120 motor. Don't think they'd put out enough power. I have a BL motor for an FJ-46 (?) that might work, but I'd need a signal converter and ESC.
Great..... now I'm going to have to look at an MCPX motor next time I go to LHS.
The mCPX BL motor would be more suited to the smaller mSR. Many have tried to use it as a "longevity" replacement for the brushed motors in the UM/UMX 1S brushed planes mostly with unsatisfactory results and there's a lot of stuff you need to know and figure out to even attempt it. Last time I looked into it, in most cases, in the end, it didn't even produce as much thrust as the stock brushed motors that come in those planes.
Walkera V120D02S parts maybe? |
I might not even be talking about the same motor, it's a small 1S brushless, it might be for the tail or something. I'll look it up later, just heading out.
Man it was great taking the old girl out for spin...it was a bit windy so should I say a little wind surf ride. lol I moved up to the next level from FF to CP (K110) and wanted to hold up from flying this beauty till I was a little more comfortable at CP flying, then I would start working the brain muscle.... Wasn't as bad as I thought.... Love and miss the sound of those blades cutt'in that wind.
Yeah, I bust mine out once in a while too, just for some easy flying out front of my house. I remember when it was soooo hard to fly this heli
For me, it wasn't that it was hard to fly, but getting the banked turns down so I could avoid smacking walls. |
Thread Tools | |
Similar Threads | |||||
New Product | Blade SR RTF Electric Micro Heli by E-flite | ghost2212 | Micro Helis | 6660 | Dec 05, 2018 05:53 PM |
Discussion | Update Blade CP or buy E-Flite Blade SR or 400? | markhwing | Electric Heli Talk | 10 | Aug 06, 2012 03:16 PM |
E-flite mSR batteries E flite 110-120 Hyp.CX 120 and others | everydayflyer | Batteries and Chargers | 45 | Apr 08, 2010 04:55 AM | |
For Sale | Did you just buy a new E-Flite Blade SR? | Z06 Tony | Aircraft - Electric - Helis (FS/W) | 3 | Feb 28, 2010 01:01 AM |
New Product | Blade SR RTF Electric Micro Heli by E-flite | ghost2212 | Micro Ready-to-Fly | 2 | Jan 07, 2010 10:36 AM |
