Jul 22, 2010, 02:10 PM
Cool Can't wait
Jul 22, 2010, 08:25 PM
Ken's CAD Models
dz1sfb's Avatar
3D Delta Plans are here.
Here are the much anticipated plans for Leadfeather's 3D Delta.
Enjoy,
Ken
Jul 22, 2010, 09:25 PM
Winging it >
leadfeather's Avatar
Ken,
Thanks once again for an awesome set of plans!!!
Note: cg is from 13" typical outdoor to 14" typical indoor.
Dan
Below are the graphics I used on mine for the "kind of" Thunderbird look.
Jul 22, 2010, 09:45 PM
Winging it >
Build instructions
Recommended build instructions:
1) Make templates and trace on foam.
2) Cut all foam pieces.
3) Hinge control surfaces. Recommend rudder hing on left side.
4) Cut the notch for the stick motor mount into the lower KF wing layer.
5) Laminate KF surface to upper wing surface. Recommended 3m Spray 77.
6) Glue in stick mount. 0 down thrust, 0 or slightly right thrust. The mounting screw should be just ahead of the airframe for easy access.
7) Shape the leading edges. I used a drywall screen tool.
8) Laminate the front lower fuse side pieces. Recommended 3m Spray 77.
9) Lightly mark the positions for the upper and lower fuse on to the wing.
10) Glue the lower fuse in place. Recommend Welders glue.
11) Glue the upper fuse in place. Recommend Welders glue.
12) Join the lower rudder hinge
13) Mount the motor and esc. Recommend esc goes to left side. I extended the ESC wires about 3 inches on mine.
14) Mount the 5 gram rudder servo very far back on left side. I used a servo extension for the rudder servo.
15) Plug all of the servos to the Rx position the elevon servos and Rx so all the wires reach and the cg is correct.
16) Power up your system and make sure the servos and esc/motor are operating properly.
16) Secure servos and Rx in place.
17) Install the control surface horns and push rods
18) Mount the battery on the right side so that the cg balances properly. Preferably the battery will be at the cg. Mount the prop saver and propeller
19) Do an awesome paint job.
20) For the first flight, elevons slightly up, rudder straight, about 1/2 throttle and toss gently up at about a 45 degree angle. Trim as required.
21) Have fun!!!
Jul 23, 2010, 05:59 AM
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Thanks to Ken and Leadfeather. September will be here before we know it. I expect to have a couple of these flying for the indoor season. Come to think of it, most of my indoor fleet is by Lead. 2 fireflies for combat, 5 Yaks for 3D (I know, I know) and a couple of these.
Azarr
Jul 23, 2010, 06:21 AM
I may have to build one of these! Have you tried it with a KFM4 airfoil?
Jul 23, 2010, 08:07 AM
Winging it >
So far only one of these jets exist. I think if you want to build for more speed for outdoor flying, a 6mm Depron, KF4 build will work well.
Jul 23, 2010, 10:43 PM
I have about 8 sheets of 6mm depron so thats what I would use... Im thinking around 28-30" wingspan with a 50g motor and 1250mah 3s
Jul 26, 2010, 05:42 AM
Well,now there are at least two!
Installing electrics,hope to maiden Tuesday.
Great plans,easy build.
Thanks for sharing
Jul 26, 2010, 08:43 AM
When pigs fly rc
rcrich's Avatar
Enjoy,
Ken
What is the difference between tiled a4 and tiled letter ? Im not sure which to use. Thanks RICH
Jul 26, 2010, 09:18 AM
Azarr's Avatar
The difference is the paper size. Since you're in the US, use the letter size. A4 is based on the metric system and is 210mm x 297mm.
Azarr
Jul 26, 2010, 11:50 AM
When pigs fly rc
rcrich's Avatar
Thank You
Jul 27, 2010, 09:39 AM
Thanks Dan for the cool plane and Ken for the great plans. I built one yesterday and maidened it today. It is a great flying plane. Here is a video of the third flight. I was to excited about flting it and forgot to take my camera out on the first two. Now I need to add an awesome paint job.
Russ
3D Delta (4 min 58 sec)
Jul 27, 2010, 09:59 AM
Ken's CAD Models
dz1sfb's Avatar
Nice Job Russ!
Any idea of the AUW in FFF there?
She looks rock steady.
Ken
Jul 27, 2010, 10:06 AM
Thanks Ken. The AUW is 12.25oz with a 1000ma lipo. I am running a E-Max 2812 on it.
Russ
Cool Hokusei Primus EPP BX - A fantastic 450g EPP 3D foamy! groovejet 3D Foamies 66 Sep 22, 2014 05:37 PM
Discussion Hobbyking EPP-3D unbreakable EPP foam model Kit (oversized) CrashingDutchman 3D Foamies 8 Nov 01, 2010 05:27 PM
Build Log Foamie epp 3d jet build with MAIDEN FLIGHT AND CRASH VIDEO!!! j3tman Pusher Prop Jet Models 38 Jul 13, 2010 10:31 AM
Sold Freeair EPP JAS-39 Gripen with NIB Jet Screamer Park Jet 2800kv phoneguy Aircraft - Electric - Airplanes (FS/W) 1 Feb 17, 2010 11:40 PM
Discussion Micro EPP build-delta/jet qacermacer Foamies (Scratchbuilt) 0 Dec 22, 2009 11:40 AM
