Jan 17, 2018, 08:00 AM
Squall's Avatar
That's a big 3D Delta!
Jan 17, 2018, 10:09 AM
I meant to do that. Honest!
JamesPotts's Avatar
It won't be a delta, it's going to be a conventional mid- wing airplane. I don't really know enough about deltas to be able to design one. I've designed a number of airplanes made from balsa and ply but I'm kinda new to using foam. This will be my second foam design.
One of my balsa designs can be flown as a low wing or a shoulder wing or a parasol wing or a biplane. It has two wings, one wing saddle cover and, and a removable cabane assembly. I don't think anything like it has ever been done before.
Sep 10, 2020, 07:13 AM
Captain Dunsel's Avatar
Decided to give scaled-down versions another try. The 'big' delta is about 205 in. sq, whilst the little one is about 76 in. sq.
RTF Weights (with battery): Big Delta, 123 gm., Nano Delta 32 gm. Both are made from pink house foam cut down to 1/8" thick. Power & radio for the big delta were left over from my wife's deceased 22" RA Cores Yak, whilst the gear for the nano delta comes from Minimum R/C and HobbyKing.
I deleted the KFM steps and I added a 1/8" bamboo skewer for a spar on the bigger delta.
Originally, I had a direct drive system on the nano delta, but it was horribly underpowered. Replacing it with a geared drive made a tremendous difference. I also had to move the CGs on both deltas forwards, to avoid the tendency for the model to hang on their props.
Note; The pad under the models has 1" squares on it.
CD
Sep 11, 2020, 05:24 PM
Just a note about the Nano Mambo; I'm posting it in the scratch-built micro forum.
CD
Sep 22, 2020, 06:03 PM
Build, crash...repeat
AleRRon's Avatar
Can you use a prop saver? Then you practically canít break a prop. Almost never anyway.
Sep 23, 2020, 08:56 AM
"Some do, some don't"
old_coastie's Avatar
They ought to call them "plane savers" does alot more than just save the prop, saves the motor and the motor mount, thus protecting the airframe
Sep 23, 2020, 10:36 AM
Kit Manufacturer
coreman's Avatar
Good to see you posting!
Latest blog entry: Release of our 40" EPP Yak55 XL
Sep 23, 2020, 10:50 AM
I'm back....
Sep 25, 2020, 12:41 PM
Lost the nano Delta today, when one elevon pushrod failed. It was heat-shrinked and CA'd, but it still failed. Oh well, now I have a free receiver to build something else for.
CD
Cool Hokusei Primus EPP BX - A fantastic 450g EPP 3D foamy! groovejet 3D Foamies 66 Sep 22, 2014 05:37 PM
Discussion Hobbyking EPP-3D unbreakable EPP foam model Kit (oversized) CrashingDutchman 3D Foamies 8 Nov 01, 2010 05:27 PM
Build Log Foamie epp 3d jet build with MAIDEN FLIGHT AND CRASH VIDEO!!! j3tman Pusher Prop Jet Models 38 Jul 13, 2010 10:31 AM
Sold Freeair EPP JAS-39 Gripen with NIB Jet Screamer Park Jet 2800kv phoneguy Aircraft - Electric - Airplanes (FS/W) 1 Feb 17, 2010 11:40 PM
Discussion Micro EPP build-delta/jet qacermacer Foamies (Scratchbuilt) 0 Dec 22, 2009 11:40 AM
