This thread is privately moderated by HuffDaddy, who may elect to delete unwanted replies.
Jun 19, 2010, 11:50 PM
No Guts, No Glory!
HuffDaddy's Avatar
=Worthy Links to Mods & Such=
"How far down should I take my Li-Po?"
https://www.rcgroups.com/forums/showthread.php?t=855787
Proper Li-Po Management
https://www.rcgroups.com/forums/show....php?t=1330647
Lipo Storage Voltage and Dead Battery
https://www.rcgroups.com/forums/show....php?t=1074181
looks like the magic number is 3.75v per cell:
https://www.rcgroups.com/forums/show...ostcount=25299
https://www.rcgroups.com/forums/show...ostcount=25295
LiPO voltage (lowest/storage/full)
3.75v x cells --> lowest
3.8v x cells --> storage
4.20v x cells --> full
1s = 3.75v (lowest)
(3.8v storage)
(4.20v full)
2s = 7.50v (lowest)
(7.6v storage)
(8.40v full)
3s = 11.25v (lowest)
(11.4v storage)
(12.60v full)
4s = 15.00v (lowest)
(15.2v storage)
(16.80v full)
5s = 18.75v (lowest)
(19.0v storage)
(21.00v full)
6s = 22.50v (lowest)
(22.8v storage)
(25.2v full)
using the example of fully charging a 3S lipo, it should\will read 12.60v when full... then the lowest voltage to fly that same bat down to is 11.25v
"The Parkzone Mustang Makeover" video series!!
https://www.rcgroups.com/forums/show...postcount=6606
Cool Plane Rack (for cargo area of Burb)
https://www.rcgroups.com/forums/show...8&postcount=11
"Parkzone P-47 Thunderbolt Diamond Lite Wheel Mod"
Took the T-Bolt out for a test run to check the tracking of the Diamond Lite Wheels I’d installed a few days ago.
I only flew one flight as the tires tended to rub the strut leg causing it to pull pretty hard to the L or R. I was able to taxi around well enough though to where I felt I could take er up and land her without a major incident so that’s all I did.
Basically it needed a thin 2mm or so spacer to sit in-between the wheel hub and where the axle meets the strut to prevent the tire from coming too close to the strut allowing the tire to rub the strut… anyways, I did a revamp of the 2 ¾" Diamond Lite Wheels by Du-Bro (part #Du-Bro 275DL) http://www.horizonhobby.com/Products...rodID=DUB275DL
Remember the set of various sized prop spacers we get with the APC props that we only use one or two of and have a dozen or so sets laying around? Well, those little spacers worked perfectly
I recut some 5/32” brass tubing (dbl checked it at LHS for size), this time a tad longer than before, cut it at 1-1/8” long. Using a drop or so of CA onto the axle, slide the 1-1/8” ‘axle extension’ on… hit it with some kicker. Then slid the APC prop spacer I took off on of the leftover sets, slid it all the way onto the axle, then slid the wheel on, attached the collar to the axle using a smidge of thread lock on the set screw as well as on the inside of the collar then using the Dremel I buffed the end to remove any burs.
Now there is the tiniest of space in-between the inside of the wheel hub and the prop spacer, like 1mm, maybe less, just enough to barely see the brass sleeve. The wheel has hardly any wiggle/wobble and spins quite freely now… no rub-a-dub-dub on the ol strut.
I might get to try it tomorrow as the weatherman promised good flying weather (like today’s)
Here’s the pics of what I did:
quick video of the 2-¾" Diamond Lite Wheels by Du-Bro (part #Du-Bro 275DL) on my ParkZone P-47D
Discussion links to any brushless msr mods out there?? user0125 Micro Helis 0 Jan 15, 2010 01:16 AM
rogallo wing flyer mods, tips and hints...such as for the gymallo www.blac.net kirkpul Scratchbuilt Indoor and Micro Models 19 Sep 29, 2006 07:21 AM
Worthy Tiger Moth 400 mods BJAZ Parkflyers 9 Nov 06, 2004 03:53 PM
Great page o'links to AP info sources and such MRX2099 Aerial Photography 4 Nov 10, 2003 11:01 AM
Funny Park: pics, mods and such av8rOC Parkflyers 145 Apr 03, 2003 12:50 PM
