Jun 18, 2010, 03:18 AM
Why walking when you can fly ?
fmelle's Avatar
Hobbyking SS Series 18-20A ESC High PWM firmware ?
Hello all,
I build myself a quad using KapteinKuk FlightControl board design and software and I have on it 4 SS 18-20 ESC with 4 FC 28-22 motors and 10x4.5 pros on a 40cm frame.
I fly OK but I am wondering to make it even better. To have it work better, it seems that a way is to flash ESC with High PWM firmware. I already did PWM to I2C conversion of TowerPro so I wonder if there is some High PWM software for these SS 18-20A ESC ?
So if any have done a conversion for stock SS ESC to High PWM ESC, I am interrested !
Aug 17, 2010, 04:24 AM
fmelle's Avatar
Originally Posted by darek53
Thank-you for the link (sorry for delay).
Yesterday evening I finally had time to try the mod. I opened my SuperSimple 18-20A non programmable ESC and hooked a programming connector on it : 4 wires directly on ATMega and 5V/Gnd from pads on the PCB. It was not so difficult as now I have done many PWM to I2C ESC conversion.
Then I flashed fuses and firmware on ATMega : all was OK, no error
For testing purposes, I connected the modded ESC to my receiver, to a motor of my quad and then powzering it using a 3S lipo. The receiver turned on (BEC is working) but no matter what I do (full throttle or no gas), the ESC stay mute and isn't working.
Does any of you have an idea ? Is this because the software is for programmable SuperSimple ESC only ?
Thank-you for the help !
Aug 17, 2010, 01:56 PM
fmelle's Avatar
OK, I will answer to myelf : SuperSimple 18-20A non programmable ESC have the same design as 17A ESC controllers.
Files can be found both for PWM and I2C mode here
I flashed mine just at once and now the ESC works. Differences seems to be both on fuses and software.
The point is that I don't know if this new firmware will change SS18-20A non programmable ESC behaviour on my quad ...
Question Hobbyking SS Heli Series 50-65A ESC jp.electrik Power Systems 2 Oct 03, 2013 03:33 PM
Help! Programming and settings for Hobbyking SS Series 8-10A ESC? flitelab Power Systems 1 Jan 14, 2011 08:06 AM
Discussion Hobbyking SS Heli Series 50-65A ESC throttle range issue ? netdudeuk Power Systems 4 Sep 22, 2010 01:19 AM
Sold Hobbyking SS Series 40-50A ESC brand new jamesrini Aircraft - Electric - Power Systems (FS/W) 4 Oct 31, 2009 06:42 PM
Sold NEW- Hobbyking SS Series 50-60A ESC Geaux4it Aircraft - Electric - Power Systems (FS/W) 6 Oct 16, 2009 09:25 PM
