Mar 07, 2011, 11:58 AM
Some.. call him Tim...
Ducati Mechanic's Avatar
Originally Posted by mbritt View Post
Canopy sets down fine, why would that be bad? There isnt anything but the heat sink on the outside of the BEC and its not overly tight just enough to keep it from moving.
I just thought the Thickness off the zip tie might interfere with the canopy cross support, but I guess the canopy dosent have a piece there..
I choose the position for the Receiver based on what Herc and some of the other guys had done. It also seems to be the best position for maximum airflow across it to keep it cool. Keep in mind when its 95+ outside other parts of the plane may not offer enough air flow to keep the ESC cool.
I hear ya!! Airflow is key... In my experience interference is a strange thing.. I did notice that there's a interference ring on those wires, which leads Me to believe there could be a problem? I try to stay away from Carbon fiber with wires when ever possible...
Again, very clean work! It looks great..
Mar 07, 2011, 12:13 PM
Team Extreme! Team Twisted!
hercdriver7777's Avatar
I've got my BEC on the cross member over the wingtube too. It works great. There is no problem with CF and a BEC IMO. CF and an RX yes but not the BEC.
https://www.rcgroups.com/forums/atta...mentid=3313000
Mar 07, 2011, 12:31 PM
Good to know..Thanks...It looks like a great spot.. Thanks for the pic with the canopy on..
Mar 09, 2011, 07:36 AM
Live for Jesus, Fly For Fun
crazyflyin's Avatar
Though I am not quit done with the assembly yet, I weighed everything and AUW came to 9.26lbs. My goal was 9.5lbs or less and I should get that. I have to put a deans on the BEC yet and glue the aileron hinges, that is all, so I am guessing once it is done, AUW should be around 9.4lbs. I am flying on 6s5000mah, A50-15s, hitec servos, BEC pro, and a CC 85HV.
Mar 09, 2011, 09:29 AM
mbritt's Avatar
Here is a spread sheet that might help you. I documented all the part weights before I began assembling. Some of the electronic weights are after connectors and wire trimming. Maybe this might be some help to you when trying to trim weight where you can.
Mar 10, 2011, 07:16 PM
3D crazy
dukeofearl's Avatar
Can someone please tell what the length of the motor stand off mounts are for the Scorpion 4035-330.
Pete
Mar 10, 2011, 07:22 PM
I show pics of mounting that exact motor in the first post with all the build info, including standoff length. Check it out: https://www.rcgroups.com/forums/atta...mentid=3312983
Although from experience the APC props flex a lot and I might go with slightly longer standoffs to keep them rubbing the cowl in KE spins.
Mar 10, 2011, 07:47 PM
3D crazy
dukeofearl's Avatar
Thanks I found the picture with the standoffs 1/38 inches or (35mm).
Regards
pete
Mar 13, 2011, 05:15 AM
3D crazy
dukeofearl's Avatar
Is anyone using a DLE 30cc setup yet. I would love to here what its like compared to an electric setup
Mar 13, 2011, 07:23 PM
Some pics from Sat.
Mar 13, 2011, 07:25 PM
Here's a pic of my BEC and battery om the cross member:
Mar 16, 2011, 05:00 AM
3D crazy
dukeofearl's Avatar
I have started ordering some gear for my build and would like to know what size prop I should use on a Scorpion S-4035-380KV running 5000mAh 6S 30C batteries.
Also can you suggest any alternatives to the Hitec HS985mg servo's for the ailerons and rudder. I would like to stay analog if possible.
Pete
Mar 16, 2011, 05:17 AM
3DHS Addict DownUnder
grizzlymatt's Avatar
Pete,
Where about are you ordering this plane from.
Does DA Australia stock them as I don't see it on there website.
Matt
Mar 16, 2011, 05:28 AM
3D crazy
dukeofearl's Avatar
Originally Posted by grizzlymatt View Post
Pete,
Matt
I spoke to DA about a week ago and they said they expect them in stock with in about a month..... hopefully.
Mar 16, 2011, 06:22 AM
Wicked
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 10554 Jun 16, 2023 01:18 PM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 08:07 PM
Discussion Extreme Flight 70" Extra 300 EXP!?!?!? Safety Hawk 3D Flying 104 Sep 10, 2012 11:33 AM
Sold NEW IN BOX Extreme Flight Extra 300 EXP ARF 48" red - will ship xraydoc Aircraft - Electric - Airplanes (FS/W) 6 Jan 16, 2010 09:55 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
