Apr 30, 2013, 08:06 PM
cescoforte's Avatar
Originally Posted by jaybird74
Francesco was asking about replacing the minis. You might be able to jam a rudder servo in the back, not sure how much structure is back there.
The micro on throttle has held up great so far. It's the Hitec 5087, metal gear, high voltage. 60 oz torque at .13 sec. I think the key to making a throttle servo live is to back the endpoints down a few degrees to make sure it never binds at either end of the throttle travel.
5087 great servo, i know
Apr 30, 2013, 11:44 PM
Huckin around the Shire
Enterprise7's Avatar
I run them in my 51 Slick. It does not have a lot of flights on it though as it is the old Fantasy Blue/Crimson Bovine scheme and it is not replaceable.
May 01, 2013, 06:52 PM
WindGap's Avatar
Your welcome!
Yes, I used the DLE stand-offs. The spinner gap is a little larger than I like but it's not that bad at all due to the open design of the cowl. Besides, any shorter and the muffler would hit the motor box. I will be home Wednesday night, if you need any more pictures of the setup I would be glad to get them for you then.
Did u have to hack the motorbox? Or did it fit alright? Cant tell from pics. I'd be interested is os gt22 would fit.
May 01, 2013, 08:19 PM
WindGap's Avatar
Nevermind, saw the earlier post about the change. There's bound to be confusion when they post this on their web page, The airframe can handle electric or Gas setup. If the gas engine has a side mount carb, simply bolt it on. If the engine is rear mount carb, then a clearance hole would need to be opened in the firewall. And that's it!
May 01, 2013, 08:47 PM
Aeroplayin's Avatar
Originally Posted by hone1er
I thought i read someone was using a 6s 6600 setup(2x 6s 3300) for this plane. Some info on your setup would be awesome. How does it fly with the extra weight? What kind of flight time do you get?
I use 6s 3300s in my 60'' planes and i was looking for something i could double up those packs with.
Joe, you can use a parallel Deans adapter to put two 6S 3300's together for this plane. You can get the parallel adapters from a lot of place like Tower, Kintec Racing, Esprit Model...
As you know, I was going to use two of the 60 EXP batteries in series for a 12S setup with a 215Kv motor but I decided to do another 78 instead on 10S. The 6S 6600 will be the same weight as I expected for the 12S 3300, which is 10.6 pounds.
The Hacker A60-6XS V2 is the 6S motor I'd recommend, or a Motrolfly with an equivalent Kv... but I know the 28 pole 6XS can swing a 20x10 to 2300W and a Falcon 21x10 to over 2500W, which would be really sweet on this plane.
I can send you some links on similar size planes with the power setup if you're interested.
Jim
May 03, 2013, 09:44 PM
cescoforte's Avatar
extreme flight 70 extra
Your welcome!
.....ehhh......ehhhhmmmmm..... pictures ?
May 04, 2013, 04:09 PM
Team Twisted!
hone1er's Avatar
Jim
Jim,
i'm definitely interested in seeing this setup in action. Sounds awesome and i have a couple 6s 3300s and will be getting a few more when i get the 60'' Laser. Sounds a little heavy compared to the 9.5 pounds that people are coming in at but usually i don't mind a bit of extra weight on my planes.
Joe.
May 04, 2013, 05:15 PM
Aeroplayin's Avatar
Joe... PM sent.
May 05, 2013, 03:39 PM
jaybird74's Avatar
Sorry man, I didn't forget you, just have not been able to get it out until today. Here are a few, anything else you need a pic of just let me know.
Description:
Description:
Description: Name: ImageUploadedByTapatalk1367786365.599111.jpg
Description:
May 05, 2013, 03:43 PM
jaybird74's Avatar
Few more. You can see the spinner gap with the standard DLE standoffs.
Also notice I flipped the carb 180 degrees to make the throttle linkage install cleaner.
Description:
Description:
Description:
Description:
May 05, 2013, 03:46 PM
jaybird74's Avatar
Here is where I mounted the Tech Aero and its LED. It shines really bright through the canopy, easy to see even during flight.
Description:
Description:
May 05, 2013, 08:42 PM
cescoforte's Avatar
nice, very nice arrangement and every thing is lite. you saved weight on fuel dot too !!!
what kind of receiver do you use? i cannot read the brand.
swb arms: 1",5 ?
lipo pack from hobby king, i dare say.
and nice gas tank.... ??? !!!!!???
thank you
May 05, 2013, 08:44 PM
cescoforte's Avatar
how... and the spinner? i have to buy it; where?
ciao
May 05, 2013, 09:51 PM
jaybird74's Avatar
swb arms: 1",5 ?
thank you
It's a FrSky 8 channel receiver, I'm using a Futaba 8FGS transmitter.
The servo arms are 1.5 on elevator and aileron, 3 inch double on rudder.
Yes, the lipo is from Hobby King, and so is the spinner. 3" carbon fiber.
The gas tank is a 330 ml Fiji water bottle with plastic bulkhead fittings.
May 06, 2013, 07:42 PM
cescoforte's Avatar
thank you again !
the hobby shop where i ordered 70 extra called: plane arrived !
Discussion EXTREME FLIGHT 48" Extra 300 EXP. VIDEO ADDED! hemituda 3D Flying 10509 Jan 18, 2020 01:22 AM
Discussion Extreme Flight RC 48" Extra 300 EXP Build mxcop 3D Flying 404 Apr 14, 2015 08:07 PM
Discussion Extreme Flight 70" Extra 300 EXP!?!?!? Safety Hawk 3D Flying 104 Sep 10, 2012 11:33 AM
Sold NEW IN BOX Extreme Flight Extra 300 EXP ARF 48" red - will ship xraydoc Aircraft - Electric - Airplanes (FS/W) 6 Jan 16, 2010 09:55 PM
Video Extreme Flight RC Extra 300 EXP 48" Teaser video! Jvdo Electric Plane Talk 6 Oct 21, 2009 02:48 PM
