Jun 01, 2012, 09:36 AM
Originally Posted by jbalat
Some awesome flying truly unbelievable looks like trick photography
I have a remzibi OSD/gps but not connected to my multiwii, also a nun chuck.
What would I need to get that system going with gps hold and return to home on my y4 ?
Excuse my ignorance but what is an "r33", are you talking about the dev version of the multiwii firmware ?
for gps u need gyro, acc, mag and gps.
r33 is the revision of the code. its a level before dev version. but afaik the gps should be implemented in the actual dev now.
Jun 01, 2012, 10:33 AM
Ceros007's Avatar
Ok That is awesome!
You have Return to home but is it possible to lock a position that is not home just to stay there. Like you fly 1km away and you want your quad to stay there. Is that possible?
Jun 01, 2012, 10:40 AM
Did you see how it stayed in one spot for like 5 minutes while he was screwing around with another quad? So.. Yes.
Jun 01, 2012, 10:41 AM
Ceros007's Avatar
But that was home no?
Jun 01, 2012, 10:42 AM
Look on the right side of the video, it said something like PH - Position Hold.
Jun 01, 2012, 11:09 AM
very nice, finally we will have gps on mwc.
Which gps modules will work?
Jun 01, 2012, 11:27 AM
Originally Posted by Ceros007
Ok That is awesome!
yes u can. its called gps position hold. in the video gps ph.
activate it wherever you want and the copter will try to keep this position.
in the video the copter was 12min in gps ph before i tried the gps ch.
Jun 01, 2012, 11:44 AM
CD-ROM Junkie
Art Newland's Avatar
WOW... GPS!!
Wondering if anyone could point me in the right direction?
I'm flying a 600mm T-Copter with a gopro FPV. It has WM+ and nunchuk, really flys well except for one quirk. In FFF it wants to yaw to the right. I currently have MultiWii 1.9 installed, only reason I haven't gone to 2.0 is that I'd need to move the D12 wiring to 5v input, no biggie, but it flys so well otherwise I hate to change it. It really didn't bother me flying LOS, but I need it to be more stable for FPV flying.
FPV flight;
T-copter FPV 5-30-2012.mp4 (6 min 3 sec)
LOS flight;
More T-Copter (5 min 34 sec)
Jun 01, 2012, 11:50 AM
Ceros007's Avatar
Ok thanks!
Jun 01, 2012, 12:02 PM
Registered MisUser
whiteturbo's Avatar
So where does the barrometer fit into this equation? or is it now surplus to requirements(never was too keen on barro's) or will it be used to get even better position hold.
As always, nice flying Warthox but i cant see you using GPS very much, but nice toy anyways.
Ray
Jun 01, 2012, 12:04 PM
Friend is a 4 letter word...
JussiH's Avatar
gps ph / ch test.
software revision 33. afaik the gps code is now integrated in the actual dev version.
all values default except PosR P 3.6
https://vimeo.com/43211223
Multiwii looping circles around a multiwii?
Looked good!
Jun 01, 2012, 12:09 PM
Quad lover.
chaosdestro0's Avatar
Originally Posted by Art Newland
snip
I had this problem on a quad, usually I find the default PIDS too careless about Yaw.
You need to put a bit of integral on yaw and a low D value.
Jun 01, 2012, 01:24 PM
FC flux'd
Katch's Avatar
eeeek just ordered Fatshark Preds and GoPro HD 1080p.... just wanted to share that.
Jun 01, 2012, 02:00 PM
WOW... GPS!!
FPV flight;
http://www.youtube.com/watch?v=lP6wmCBdipY
LOS flight;
http://www.youtube.com/watch?v=4eRuNdQLl6I
Have you got cw and ccw props on the front and a cw/ccw on the rear. If you have two cw or ccw on the front then that is what is causing your problem. SouthPawPaul had this problem recently.
Jun 01, 2012, 02:50 PM
CD-ROM Junkie
Thanks, I'll try that.
