May 31, 2010, 06:45 AM
Help!
Dumb prop adapter / prop question
I want to use a 6x6 Graupner prop on a 3mm motor shaft, the prop appears to be listed as having an 8mm center hole.
Should I look for a prop adapter for a 3mm shaft with 8mm threaded hub (that doesn't seem to exist), so what is the right way to mount this prop..
May 31, 2010, 07:13 AM
eflightray's Avatar
Is this UK one any good, (you don't show what country you are in, but it may be available in others) - Aeronaut prop adapter for 3.0mm shaft, 8mm thread
I have used tape to build up the diameter of a standard prop adapter to suit the prop bore, works fine.
May 31, 2010, 07:31 AM
two good ideas, cheers .. I like the tape one for now as I can use what I have!
May 31, 2010, 05:07 PM
Sussex, UK
RobinBennett's Avatar
I wonder if you've finally found a use for some of the spare APC spacer rings that everyone has lying around?
Find some that are a tight fit on your prop adapter, spin it up and gently sand them until your prop fits. (or clamp several on with a nut and just sand the ones in the middle)
Discussion Prop adapter question for Power 32 emillard Electric Power Systems 2 May 10, 2010 08:39 AM
Discussion dumb question Can my motors be fixed propjobbill Electric Motor Design and Construction 5 Apr 21, 2010 10:48 AM
Discussion I have a dumb question about tx... Forever_Noob Beginner Training Area (Heli-Electric) 26 Mar 27, 2010 10:21 AM
Another dumb question about prop rotation. bc-slowflyer Flying Wings 4 Apr 12, 2005 07:56 PM
Last dumb GWS prop question! CSI Vendor Talk 2 Jun 13, 2004 07:01 PM
