May 20, 2010, 01:16 AM
Always Ready!
warhead_71's Avatar
Help! DX7 and AR6000, mixing for flaps and ailerons
I built a DHC Beaver with 2 servos for ailerons and 2 servos for flaps... a servo for each control surface. How do I program the DX7 so the ailerons work normally and the flaps work with the 3-position flap switch? I only have 6 channels... so either the ailerons or the flaps need to be Y-connected.
I have the Y-connector... but should I:
(A) "Y" the ailerons together, then plug the 2 flap servos into AUX and GEAR... then how do I mix those so they use the 3-position flap?
or (B)
"Y" the flaps together, set the ailerons to "Flaperon" with the right aileron servo plugged into AIL and the left into AUX... but then how do I disable the 3-position switch from the flaperons and instead mix it to the flap servos? The problem with "Y-ing" the flaps together is that I'd have to mount one control arm backwards so they'd rotate opposite of each other instead of together.
May 20, 2010, 01:34 AM
registered user
I have crow mixed to THR so flaps down and AIL up.
Then ELE to THR down trim
I will have a look at my mixes tonight and no Y leads needed. But I did use all 6 mixes
May 20, 2010, 07:37 AM
Always Ready!
warhead_71's Avatar
Brilliant - that explains everything I asked. Seriously... any help?
*edit* --- okay - that was harsh.... haven't had my coffee yet.
May 20, 2010, 09:23 AM
Always Ready!
warhead_71's Avatar
I ended up getting it to work... kind of.
I have the 2 aileron servos on a "Y", and the flaps I have plugged into GEAR and AUX. I have the AUX channel controlled by the 3P switch, then I have GEAR mixed to AUX.
Not sure if I did it right... not a lot of travel in the flap servos -- only about 30degrees but I maxed-out the end-points for more travel at full flaps.
The big problem is that the GEAR toggle still independently works one of the flap servos... so if I bump it in-flight, I'll certainly go into a spin.
Something can't be right....
May 20, 2010, 09:29 AM
Try this:
DX7 DUAL AILERONS AND DUAL FLAPS
Aileron Setup
1. Power off the TX and turn on. Go to normal
programming
2. Scroll to Pmix #6. Set Aileron as master and
AUX#2 as slave. Set mix levels at 100%
(This requires movement of the Aileron Stick)
3. Set the Sub trims on the aileron and aux#2 to
match each other.
1. Scroll to Travel Adjust and set the desired
Travel for the right aileron and left aileron
(AUX#2)
2. If the ailerons are backward..go the reverse
Switches and correct
Flap Setup
1. Scroll to Pmix #5. Set Aux#1(Flap) as master
And Gear as slave. Set the mix levels at 100%
(This requires flipping of the gear switch)
2. Scroll to Pmix#1. Set Gear to Master and Gear
To Slave. Set mix levels to –100% -100% (This
May require flipping of the Gear Switch)
This will inhbit the gear switch.
3. Set Sub trims on the Aux#1 (Flap) & Gear (Left
Flap) to match each other
4. Scroll to travel adjust and set 100% on Aux#1
And Gear.
5. Scroll to FLP SYS screen, Set the desired
Travel for each of the switch settings.
You can also set any elevator compensation.
Set Right Flap to Aux#1, Left Flap to Gear
May 20, 2010, 09:42 AM
65 years of RC flying
Daedalus66's Avatar
Why not just two Y-cables, one for ailerons into channel 2 and one for flaps into channel 6. I can think of reasons why you might want more adjustment flexibility, but if you want simple, that should do it.
May 20, 2010, 09:46 AM
Always Ready!
warhead_71's Avatar
Sweet... that's just what I was looking for.
I am using an AR6000, so I only have BAT, THR, AIL, ELE, RUD, GEAR, AUX .... I don't have 2 auxillary channels. But I will simply keep the ailerons on the Y-connector and set up flaps using GEAR and AUX as you detailed above.
Thanks a bunch.
May 20, 2010, 09:50 AM
Always Ready!
warhead_71's Avatar
Because putting flaps on a Y means they move in unison (CW/CW)... like ailerons -- there's no way to reverse just one of the servos, (unless I also get an inline servo reverser). I'd have to remount a servo so the arm can be put on backwards so they move in opposition (CW/CCW). I don't want to move servos at this point... or have control linkages that don't line up in a straight line.
May 20, 2010, 10:32 AM
Daedalus66's Avatar
Understood. That's what I meant by more flexibility. I just hadn't seen this requirement explicitly in the previous discussion.
May 20, 2010, 10:52 AM
Always Ready!
warhead_71's Avatar
I didn't realize it was a problem until I started into it myself.
I think I'm headed in the right direction now... I'll report back tonight to let you know how it goes.
Sold RDS hardware full set for flaps and ailerons sbxcflyer Aircraft - Sailplanes (FS/W) 1 Apr 08, 2010 08:05 AM
Discussion DX7 - Flaps, Ailerons, 4 servos, mixing. Kurts Radios 2 Oct 17, 2008 09:23 AM
Discussion DX7: Using Ailerons as Brakes/ Flaps jvthert Radios 2 Dec 16, 2007 08:49 PM
Mixing ailerons to flaps on Optic 6 charlie tasto Hitec/Multiplex USA 0 Feb 08, 2005 07:58 PM
Question Evo Problem mixing flaps and ailerons avince Hitec/Multiplex USA 1 Dec 22, 2004 12:51 PM
