Build Log
1/3 Scale Cherokee
All,
I've sat on this for a bit but have made enough progress to start sharing my build of a 1/3 scale Cherokee. I based it on my original 1/4 scale plans but have made some changes, primarily for additional strength at the larger size, but also hopefully to improve the performance a bit. The performance change has been to change the airfoil from the original GO549 to the HQ3514. This change was made before the recent discussion on RC Groups about the flying qualities of this airfoil, so hopefully I have lucked out. The general construction is the same, with a few details changed which I will describe during the build log. The truss is still made of balsa, in this case 5/16" sq. hard balsa, which is 50% bigger in cross section than the 1/4 sq. that was used in the smaller version. I can tell you that the fuselage is very strong and that I have no concerns whatsoever about using balsa for the truss. I have changed the rudder build slightly as the original tended to warp and was a bit fragile. With luck this one will keep its form and be tougher to boot. Just FYI, I used blade and box because that is what I had available in my workshop, but steel or carbon rod would work as well. The joiner is made of two blades/boxes. The top one is 14mm wide and extends 8" into the wing. The lower one is 12mm wide and extends 4". Here are the "catch-up" pictures. From this point onwards the build will be in real time, and as I have a bunch of travel in the next few months it may be slow. I am willing to share my plans, but be aware that this version is untested and generally speaking I would prefer to build the prototype and make sure it flies well and is robust before turning it loose. Your call.... ![]() As there are already a number of Cherokee builds posted here, I won't go into great detail; just posting the interesting bits. Dave Smith ImagesView all Images in thread
Reason: typo
Dave - looks like the real thing! Very cool I look forward to following along.
Dave
... great. I have also been thinking about a bigger version every now and then... Considering the flight characteristics of the 1/4-scale version, i would not have the least doubt about this one. Have fun - I shall watch your progress! Herbert |
Dave,
As you know I have been dreaming of a 1/3 scale Cherokee for some time now. My 1/4 scale is a dream to fly and I know 1/3 can only be better. I even have the paint scheme already planned... just need some plans and I can start cutting wood ![]() Tony |
Hi Len,
the rumor is right: 12th of June is the date! After our little grand-daughter`s birthday celebration, I am looking forward to meeting some of you folks - Steve(R), the weather and other good vibrations permitting... :-DDD @ Dave, is there already an up-scaled plan? Or laser-cut data/parts? On the other hand, two meters twenty for the fuselage are already touching the limits of my facilities... Herbert |
Plans
Herbert,
As I mentioned in the first post, there are plans that I am willing to share, but they are a work in process and have to be updated to reflect the "as-built" version, since I am making some slight modifications during building for strength, plus finding out where some parts don't fit as well as I expected ![]() Of course most of the changes are in the fuselage; the wings are pretty straightforward and difficult to go too far wrong. The HQ airfoil puts the high point behind the main fuselage former as you can see in the pictures, and the sheeting is now 3/32" instead of 1/16", but if you were to create some ribs using Compufoil or Profili, you could start the wings while waiting for the fuselage drawings to be completed. With those airfoil programs you could adjust the wood sizes to match the metric stock that you would be using, and the changes at the fuselage would be small. So, yes, I can share the plans now, but I don't want any complaints if things don't fit perfectly or some part isn't as strong as you think it should be. Once the plane is built I will refine the plans and they will be more suitable to create cut files from, plus we will know if it flies like an angel or a pig! David |
Progress
Center section sheeted, and some turtledeck formers added. No glue yet for the formers as I'm working on the alignment. The turtledeck goes from an elliptical form at the wing to a triangular form at the stabilizer, and all the stringers have to lay nicely on the formers or you get a pretty wavy outcome, so that's what I'm playing with now.
The backbone of the stringers is 1/8" x 3/8" here. On the 1/4 scale model it was 1/8" x 1/4". This adds a bit of strength, although the turtledeck is fundamentally a streamlining form and generally speaking, the loads are carried by the truss, so the turtledeck only has to able to manage handling loads. Dave Smith |
Thanks, Dave,
that was a question - there is no hurry as I still have two "wooden projects" on my bench... But I am following closely with great interest! Herbert |
Back in Action
I was out of country for most of June, just returning last Wednesday, but have started up again and made a bit of progress. The turtledeck stringers are in place, as well as the nose keel. Next steps are the wheel mount and the lower formers; then on to the stab mount and the stabilizer. The side stringers will pretty much finish up the fuselage. After that the wing, canopy and covering, and go flying. It all seems so simple, doesn't it?
Dave Smith |
Thread Tools | |
Similar Threads | |||||
Build Log | 1/3 scale balsa usa j-3 cub | Perry Lowry | Trader Talk | 1 | Mar 23, 2010 08:18 AM |
Wanted | Cub wheels 3.5" to 5" for 1/4 or 1/5 scale model | MinneFlyer | Aircraft - General - Miscellaneous (FS/W) | 0 | Mar 13, 2010 01:52 PM |
Discussion | Looking for 1:4/1:3.75 scale ASH-25 Fuselage | SoarScale2 | Scale Sailplanes | 1 | Mar 11, 2010 05:54 PM |
Discussion | 1/3 scale SGP 1-1 Primary Glider from tmrc | eschlitzkus | Scale Sailplanes | 3 | Aug 28, 2009 09:08 AM |
For Sale | Sale: 1/3.5-scale ASW-15 and 1/3-scale Lo-100, both RTF; $1800 and $1200 respectively | ShredAir | Aircraft - Sailplanes (FS/W) | 3 | Oct 13, 2006 05:55 PM |
