May 09, 2010, 07:49 PM
Sleepy Hollow, IL
Build Log
57" DH Mosquito
I recently found a set of plans for a P. Noel designed Mosquito. I enlarged the plans to a 57 inch wingspan and cut out the patterns so I could convert this design into a profile plane made from FFF foam.
I decided to use a KFm 2 airfoil rather than the full airfoil as on the plans for ease of construction. The fuselage is made from 4 layers of FFF with two pieces of flat CF embeded in the middle two layers. The middle two layers also form the vertical stab. The front of the fuselage going back around the wing mount area is covered with 1/16 inch ply for added strength. The stearable tail wheel is from a Parkzone Corsair and the main gear are from an E-Flite Deuces Wild. The tail wheel is 1 1/2 inches and the main wheels are 3 1/2 inches to more resemble the scale wheel sizes.
The ESCs and the batteries are all hidden under the motor pylons.
The color scheme is for a Mosquito night fighter from 1942 out of the 23rd Squadron.
The P. Noel plans are also provided and I would like to thank him for the excellent design.
The specs for the plane are:
Motors: Headsup 2830-11 (1150 Kv)
Props: EP 9x5 (the picture shows 11x7s)
ESCs: Turnigy Plush 30 A
RCVR: Corona RP4S1
Servos: HXT 900
Batteries: FlightMax 3S 1800
The AUW is 53.5 ounces.
Each of the motors runs at 16 Amps at 11.1 volts giving 355.2 watts total for 106.2 watts/pound. This should provide good scale speed capability.
The maiden will be this week if the weather clears and the winds die down.
ampmaker
Last edited by ampmaker; May 10, 2010 at 12:34 PM. Reason: P. Noel name spelled wrong
May 09, 2010, 09:15 PM
Looks great.
May 10, 2010, 10:14 AM
Zen in the art of foam
djacob7's Avatar
Good job! Good luck on the maiden!
How do I get to P. Noll's build thread?
May 10, 2010, 12:41 PM
Sleepy Hollow, IL
djacob7,
Thanks, and below is the link to the Philip Noel Mosquito build.
ampmaker
https://www.rcgroups.com/forums/showthread.php?t=620228
May 10, 2010, 01:10 PM
djacob7's Avatar
Thanks, ampmaker!
May 30, 2010, 08:52 AM
so how was the maiden?
May 13, 2016, 09:09 PM
Nice work!
Sep 20, 2016, 11:06 AM
Crash,fly,crash again....
Can you please post a video of a maiden?
Discussion My first attempt at micro: dH Mosquito CarreraGTSCS Scratchbuilt Indoor and Micro Models 21 Feb 13, 2010 11:51 AM
Discussion Cloud models DH Mosquito darronm2 Electric Warbirds 11 Dec 22, 2009 08:48 PM
Build Log DH-98 mosquito with MCX board. kase_kopf Scratchbuilt Indoor and Micro Models 42 Nov 04, 2009 11:04 PM
How does the r/c DH Mosquito fly? G.F. Beurling Scale Kit/Scratch Built 17 Jul 04, 2001 10:20 PM
Looking for 8'-9' DH Mosquito Kit. G.F. Beurling Electric Plane Talk 2 Jun 11, 2001 12:11 AM
